Infinity Dadonator 8" Stacked Dado Set
Review by knotscott posted 03-10-2009 04:29 PM 7963 views 2 times favorited 7 comments Add to Favorites Watch
Infinity Dadonator 8" Stacked Dado Set No-picture-s No-picture-s Click the pictures to enlarge them
The Infinity Dadonator SDB-800 8” stacked dado set features two 8” outside cutters with 24 carbide teeth each, and six 8” inside chippers with 6 carbide teeth each. Four of the chippers are a standard 1/8” width, one is 1/16”, and one is 3/32” to accommodate today’s odd plywood sizes. It comes with an instruction booklet and a set of plastic shims in a variety of thicknesses. It cuts dados 1/4” to 29/32”, and can me finely adjusted using the supplied shims. The outside cutters utilize a unique tooth configuration that includes a combination of teeth beveled from the outside in at 20° and a flat top grind to ensure a flat bottom dado. The SDB-800 comes in a plain blue square cardboard box that houses all the components described above, all held in place by a nut threaded onto a bolt through the bore of each plate. While this is a far cry from the nifty carrying cases offered by the DeWalt and Delta dado sets, it does offer suitable protection for the set during transit and storage. I’ve since transferred my Dadonator set to a more convenient wooden carrying case.
As with any other Infinity product I’ve tried, the Dadonator gives an immediate impression of world class quality. The feel is hefty, balanced, and solid. Every Infinity product I’ve handled is strikingly polished, shiny, finished, and sharp. Most importantly, performance matches the highly finished appearance. To date I’ve tried five Infinity saw blades, two of their router bits, and now their stacked dado set. Three of the five saw blades I’ve tried are what I’d describe as “Best in Class”, and the Dadonator dado set definitely follows suit. The other two blades are also extremely good (010-124 ripper, 010-040 “General”).
The arbor holes are precisely sized for an accurate and snug fit to the arbor, which eliminates slop and variation from cutter to cutter. Once mounted and put into action, the Dadonator reveals impressively smooth flat bottoms and the finest cuts I’ve seen from a stacked dado set. The first cuts with the Infinity were in a piece of butternut that I had also done some test cuts using my Systimatic Superfine 42T/6T set. Both sets did extremely well, but in every case the Infinity revealed flatter smoother bottoms with less tearout. I literally had a tough time differentiating between the entrance and exit of the cut even though no backer boards was used….tearout is that low. I had previously thought the Systimatic was quite impressive, and it is, but the Dadonator simply outclasses it in many subtle ways that end up revealing it’s superior design and performance overall. The Systimatic uses 42 teeth on the outside cutters combined with a fairly steep hook angle, which helps it feed more easily in lower powered saws, and also has 6 tooth chippers. While more teeth typically equates to a smoother cut, the steeper hook angle does result in slightly more tearout than the Infinity. As I’ve mentioned many times in my blade reviews, there’s never a free lunch, and every design choice offers pros and cons. The Infinity sports cutters with 24 teeth and a zero degree hook angle, which doesn’t cut quite as quickly but does result in lower tearout. I also tested the Dadonator in plastic laminated pressboard and was amazed at the lack of chipout in the laminate. Same was true of dados cut in melamine, plywood, and in hardwoods like maple and oak. The relatively steep 20° bevel angle of the teeth on the cutters helps improve the quality of cut with a very clean slicing action across fibers, plus has the benefit of less chipout in plastic laminates and veneered plywood. The downside to the steeper bevel is lower efficiency resulting in a slower cut, slightly faster wear, and a tendency to leave tiny “bat ears” on the edges of the cut, but Infinity offsets those characteristics by using teeth with an efficient flat top grind (FTG) on every other tooth of the cutters. The result is a very clean cut that’s as close to having a true flat bottom as is physically possible without a tendency for tearout.
One major obstacle of comparing dado sets is the high cost associated with them, so most folks simply don’t get exposed to very many. The Infinity SDB-800 retails for $200, which is close to entry pricing for this caliber of dado sets. I’m just scraping the tip of the iceberg of what’s available, but to put the Dadonator’s performance in perspective, I’ve now owned and reviewed four very good stacked dado sets….Freud SD208 ($95), DeWalt DW7670 ($125), Systimatic 42T Superfine ($300), and most recently the Infinity. In fairness, I’ve yet to try out the Freud’s top SD508 ($200) & SD608 ($275), the Forrest 8” Dado King ($300), or the Ridge Carbide 8” Dado Master ($230), which are all top contenders in any respectable discussion or comparison test. The design elements and construction of the Dadonator should give it an advantage in head to head comparisons with other top sets, but I can only hypothesize at this point and can’t say from hands on experience yet. Sets like the Freud SD608 “Dial-A-Width” offer some convenience features that others don’t but the adjustable hub also takes up extra room on the arbor, meaning that many saws can’t accommodate the entire stack. I’d heartily recommend the Dadonator over any.
View knotscott's profile
knotscott
8137 posts in 3548 days
7 comments so far
View 8iowa's profile
8iowa
1586 posts in 3933 days
#1 posted 03-13-2009 02:17 AM
Thanks for the detailed review. My only additional comment is that if one is using a saw that operates on a 120V 15 amp circuit, a 6” dado would be a better choice.
View David2010's profile
David2010
3 posts in 3119 days
#2 posted 05-02-2010 04:31 AM
knotscott
#3 posted 05-03-2010 09:14 PM
”Is it ok to post a link to this product with the review?”
Fine by me!
View pintodeluxe's profile
pintodeluxe
5783 posts in 2985 days
#4 posted 02-15-2016 04:28 PM
Have you tried the Dadonator cutting tenons with hardwood? I have the entry level Freud set with two wing chippers and while it does great with plywood dados, it will often tearout the side shoulders of my tenons. I tried decreasing the feed rate, and even had it sharpened. If anything, it was worse when it came back from being sharpened.
I guess it is down to the Dadonator or the Dewalt for me now. Any opinions on which dado blade is best for hardwood joinery?
Thanks
knotscott
#5 posted 02-15-2016 10:10 PM
Hi pd – I can’t remember if I’ve ever cut tenons with the Dadonator…probably… but lack of tearout in general is definitely of it’s strengths. The DW is the best bang for the buck < $120 IMO….the Dadonator is just flat out better in all regards except price. If an extra $100 doesn’t cause make you wince or deprive you of other goodies, I can’t imagine that you’d ever regret investing in the better set. I did miss the carrying case that the DW came with, so I ended up building my own from an old wood box for the Dadonator. Good luck, and get back to us with your impressions of whichever one you get.
pintodeluxe
#6 posted 03-02-2016 05:17 PM
I went with the Dadonator. It seems to work well for hardwood joinery. Tenon corners are crisp without tearout. This should help with my through tenons.
A big improvement compared to my old 2-wing chipper set.
knotscott
#7 posted 03-02-2016 06:29 PM
Congrats….enjoy! Still love mine.
