Grip-Tite Sub Fence Clamp
Review by Chris posted 03-09-2009 05:39 AM 6274 views 0 times favorited 12 comments Add to Favorites Watch
Grip-Tite Sub Fence Clamp Grip-Tite Sub Fence Clamp No-picture-s Click the pictures to enlarge them
This has to be one of the best things I have laid my hands on in a while. I needed a better way to mount my sacrificial fence quickly and I saw these at Woodcraft for less than $20.00 US. Just drill a couple of 1/2” holes in the sacrificial fence and clamp it to your regular fence. That’s Easy!
My only very minor gripe is that the little knobs that you tighten them with tend to loosen when you try to remove the clamps. A couple of drops of 5-Minute epoxy in each threaded hole fixed that.
The pictures are courtesy of the Grip-Tite web site.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Chris 's profile
Chris
1879 posts in 3860 days
12 comments so far
View jack1's profile
jack1
2093 posts in 3896 days
#1 posted 03-09-2009 06:10 AM
glad to know it works. I bought a pair and haven’t used them yet
View tooldad's profile
tooldad
660 posts in 3584 days
#2 posted 03-09-2009 06:40 AM
need to get me a pair. had a close call with my sac fence just the other day. narrow piece making a rabbet, my homemade push stick was too long, and kept hitting the c clamp. so I shortened it. It was a pine push stick and as i applied pressure to keep the board down, the stick broke. Thank goodness for featherboards! I was using the mag lock from Ridgid and had it tight enough to hold it and prevent kickback. otherwise I might have landed on the blade.
View RedShirt013's profile
RedShirt013
219 posts in 3530 days
#3 posted 03-09-2009 07:11 AM
Thanks for posting this. I was looking at the similar one from Rockler and wanted to get a pair, but couldn’t find a way to get in in Canada without paying a substantial shipping fee. Maybe have better luck getting this.
-- Ed
View dalec's profile
dalec
613 posts in 3757 days
#4 posted 03-09-2009 07:46 PM
Hi Chris,
How about a drop of locite on the thread of the clamp?
Dalec
Chris
#5 posted 03-09-2009 10:27 PM
Dalec, I suppose that would work. However, I did not have that on hand.
View Homers's profile
Homers
42 posts in 3277 days
#6 posted 03-09-2009 11:22 PM
I have the Rockler version and I like the concept a lot. I have an issue with mine though. As I tighten them down I seem to get a bow in my sacraficial fence that I don’t get when using regular clamps. I suppose this could be from my wholes not being drilled staight or something. (I have not trouble shooted it yet.)
-- Homers / Murphy, TX
View jacktheripper's profile
jacktheripper
7 posts in 3215 days
#7 posted 03-29-2009 02:50 AM
Thanks for the good feedback, Chris. I invented the HoleClamp about 4 years ago and am still waiting for the patent to go through the system. We obviously needed to use more locktite to keep the thumbscrew on tight. One quick fix is to put a 1/4” nut on below the thumbscrew and double nut it.
The knockoff Rockler clamp has a big flaw (aside from stealing the idea and cllaimiing it was their’s) in that the clamp ends are not parallel and cause the sub fence to pull away from the main fence. The Grip-Tite clamp is a solid 7/16” bar to avoid that problem.
We would appreciate anyone giving us a call at 1-800 -475-0293 if you have any problem with or feedback on any of our products.
Jerry Jaksha
Grip-Tite.com
View WayneC's profile
WayneC
13751 posts in 3966 days
#8 posted 03-29-2009 02:55 AM
I’m going to have to get a set for my table saw. They look pretty nice and good to know about the limitations of the Rockler version.
Jerry, nice to have you on the site. Hopefully we will see you post occasionally.
View kokako's profile
kokako
8 posts in 2525 days
#9 posted 02-27-2011 09:51 AM
Thanks for posting this review Chris.
How capable would you say that the Griptites are of guiding heavy timbers? 2×6’s etc.?
Chris
#10 posted 02-27-2011 11:10 AM
I have no idea if it will hold something that heavy. I guess it would depend on how much force is going against them,
View noodles1's profile
noodles1
1 post in 2403 days
#11 posted 06-19-2011 07:49 AM
I would like to know if the grip-tite 2000 will work with my Bosch 4100 jobsite saw?
Chris
#12 posted 06-20-2011 06:30 PM
If the fence on the Bosch is no wider than a standard Beismeyer style than I would guess that it should…
