Bosch Trim Router
Review by roman posted 263 days ago 1511 views 0 times favorited 32 comments Add to Favorites Watch
Bosch Trim Router No-picture-s No-picture-s Click the pictures to enlarge them
I bought this little router at HD as my 25 year old, never failed me, Black and Decker trim router was sounding like it was about to puke. I didnt look at prices as I am somewhat a believer in “buy once” ...then “cry once” then never cry again so it wasnt the least expensive one there.
I use my trim router a lot, mostly for routing in butt hinges then clean it up with a chisel, same for inlaid bowties and “trimming” veneer and plastics etc., On first, second and …..............it worked great, no complaints but then I noticed that the router bit was slipping when actually it wasnt. It was the outer case sliding down the motor so I tightened the nut on the cam that clamps it down
End result is that the outer case that tightens down on the motor houseing is made from inexpensive white metal and was actually bending to the point where it cannot be tightened any more and the router is somewhat useless so I wonder as I have not read it the manual if I am required to put a shim inbetween the casing and the housing.
I’m not impressed.
View roman's profile (online now)
roman
1114 posts in 787 days
32 comments so far
View John Stegall's profile
John Stegall
210 posts in 410 days
posted 263 days ago
I would return it to HD. I understand that any company can have a problem, but they should stand behind it. Good luck if you decide to keep it.
-- jstegall
roman
posted 263 days ago
I’m going to return it as in its present state its somewhat useless.
Going to buy the Festool MFK 700 EQ at 5 times the price, mind you…...buy twice, cry twice…...and hopefully never cry again
20629 posts in 716 days
posted 263 days ago
Roman, thanks for the review. I have been considering adding one of these to my routers and have always been impressed by Bosch’s quality for tools. But this review causes me to reevaluate the purchase. I am sure that a review of the Festool is going to come up. There is no question about the quality of this router.
View Matt's profile
Matt
178 posts in 266 days
posted 263 days ago
Sorry to hear that. I know lots of guys are putting them in CNC routers but they are removing the motor from the base and putting them in custom mounts. Supposedly the spindle is really good on not having any runout and with the 1 hp motor, it is awesome for the benchtop CNC machines. Sounds like a bad implementation of a good motor. I have a PC893 in my router but I’ve thought about getting the colt for when I don’t need the size, power, or noise of the PC.
I have a DeWalt laminate trimmer that has never let me down. Love that little thing.
Thanks for the review.
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
View MrWoody's profile
MrWoody
285 posts in 668 days
posted 263 days ago
Thank you for posting this review. I was looking at that same router; I won’t be now.
-- If we learn from our mistakes, I'm getting a fantastic education.
View Kindlingmaker's profile
Kindlingmaker
1470 posts in 420 days
posted 263 days ago
I have the Bosch Colt and it is a fantastic router! For such a little guy it works like a big one.
View 3fingerpat's profile
3fingerpat
907 posts in 561 days
posted 263 days ago
Roman, what model is this? Looks like the Bosch Colt but I can’t tell from the pictures?
I also have the Colt and haven’t had any problems, so I would be interested to know what model yours is?
Thanks.
3037 posts in 915 days
posted 263 days ago
Thanks for the heads up Roman.
You just saved me over a hundred bucks and the frustration.
I had one in my hand last week at HD.
I’ll have to go back and look at the Rigid.
I wanted something that takes guides (1-3/16’)
View RedShirt013's profile
RedShirt013
116 posts in 555 days
posted 263 days ago
Roman, I have the VS version of the Colt and haven’t have that problem. One thing to note is that the router is designed that the motor could sliding up/down the case/base easily (for rough adjustment), but you have to rotate the motor clockwise to engage the fine adjustment threads (for fine adjustment). Not sure if you had done that but the fine adjustment threads are what mainly maintains the set height. I still think my Colt is very good in quality, except for the fact that I much prefer double wrench over the spindle lock it has.
-- Ed
View Woodguru's profile
Woodguru
7 posts in 265 days
posted 263 days ago
Not good news, I too would consider returning it or having it repaired if under warranty. I have two of these routers and used them very often for tandem jobs. I personally love them very much and would not give them up. I also have the PC and Dewalt trim router but always go for the Colt. Good luck.
View John Gray's profile
John Gray
1753 posts in 779 days
posted 263 days ago
Love my Colt, no problems here.
View mmax's profile
mmax
52 posts in 349 days
posted 263 days ago
I also have the Colt and have used it for the past year with no problems. Fantastic router.
-- Always remember you're unique, just like everyone else
View PurpLev's profile
PurpLev
2745 posts in 542 days
posted 263 days ago
sounds like 1 bad apple. as Bosch’s routers and the colt as one of them are top notch machines… sad to see so many people here change their minds about this one because of 1 review. there may be more than meets the eye here – either Roman didnt engage the fine-adjusting thread, or maybe this particular one is truly defective. I’d check more into it personally.
View Gary Fixler's profile
Gary Fixler
646 posts in 275 days
posted 263 days ago
Sorry to hear it, roman. I had that one in my hand 2 or 3 weeks back at HD, too, but opted for the RIDGID, partly because it cost less, but also because it had a round base. I figured at some point I was going to want to follow a pattern with an inward curve, and the circle wouldn’t have a problem. The square base would. Silly, but I liked it, and it was lighter. I’ve loved it so far. I cut a few stairstep shapes in plywood with it and my All-In-One clamp guides from Rockler. No slipping, light and easy to use. I’ve actually been planning to write a little review of that one at some point. It’s really right between a Dremel and small router. I did a lot of the work with 3 fingers of one hand on the base, casually moving it around. It’s so light and easy to use.
I noticed this Bosch laminate trimmer was the Rockler Deal of the Day this past week – refurb’d, and almost bought it as a backup, and because it can be put in a CNC machine that I dream of one day building, but I let the deal pass. Now I think I might be glad I did.
-- Gary, Los Angeles, video game animator
View cabinetmaster's profile
cabinetmaster
8534 posts in 452 days
posted 263 days ago
Never used the Bosch. I have 2 of the PC and we bought a new Freud at work. I still prefer my PC. I’ve had mine abiut 10 years now and no problem with either one.
View JayDee's profile
JayDee
22 posts in 266 days
posted 263 days ago
I have the Colt and love it. With mine, you turn and lock the casing to the motor before clamping. I’ve never had a problem with it slipping.
-- JayDee from Woodstock, GA
View mrsawdust's profile
mrsawdust
47 posts in 461 days
posted 263 days ago
Roman, sorry to hear about your bad experience. you should return it, immediately. i too, have the Bosch Colt 1hp variable speed and wouldn’t trade it – fine tool.i’m curious about the “white” metal, because mine is machined aluminum. excellent quality throughout. good luck.
mike
-- mrsawdust, pittsburgh,pa.
View Emeralds's profile
Emeralds
155 posts in 456 days
posted 263 days ago
Roman:
Call Bosch and I can virtually guarantee they will make it right. I’m a HUGE Bosch groupie simply because of their impeccable CS. Manufacturing aside (there will always be problem units and bad designs, it’s inevitable and unavoidable) I own half a dozen Bosch machines and have yet to have had an issue that was not dealt with to my satisfaction. I’m not saying that everything they make is as well made as it could be. What I am saying is that they will stand behind everything they sell for as long as you own it. This has been my ongoing experience with them and it’s worth its weight in gold.
Bosch 1-877-267-2499
-- JMP
View PirateOfCatan's profile
PirateOfCatan
53 posts in 293 days
posted 263 days ago
I am also in the camp of Colt groupie. A co-workers has one that they put some gauges in. They are in the main body and make the adjustment of the base more difficult. I have had no problems with mine and love it.
Hey Redshirt013- My model has the spindle lock and a wrench slot. It came with both wrenches as well. Take a look yours might also have it. Mine is about to have its first birthday. Gift ideas include a new patter bit and a handmade 1/4 Plexiglas sled.
-- P.O.C.
View Brad_Nailor's profile
Brad_Nailor
1214 posts in 851 days
posted 263 days ago
Hate to break up this Bosch love fest but I have read several reviews of this router and the locking mechanism seems to be an issue. I love Bosch tools I own quite a few and I was planning on buying this router. Its good to hear all the rest of you guys saying that you don’t have a problem…so maybe it is an isolated manufacturing defect, or something that was a problem on the older models..etc. There is nothing like a router this size to have kicking around to do small round overs and knock edges off table tops.
View UVA's profile
UVA
18 posts in 303 days
posted 263 days ago
I have the Bosch Colt and it is terrific, no problems at all. I use it all the time with a 1/8” roundover bit to soften edges and a 1/16” straight bit to mortise hinges freehand. I wouldn’t be without it.
View DonFaulk0517's profile
DonFaulk0517
50 posts in 380 days
posted 263 days ago
I have the same router and when rotated to the “lock” position mine stays in place with no vertical movement. I use it more than my other routers and love it! I would take yours back or contact Bosch for a warranty repair.
-- DonFaulk0517@gmail.com
View USCJeff's profile
USCJeff
899 posts in 962 days
posted 263 days ago
Gotta say, I think you simply got a defect. I’ve had mine a year and haven’t experienced what you describe in the least. I’d repurchase if it vanished today. I will say I think the variable speed on the model I have is a little unwarranted. It’s really not meant for bits that would require slowing the rotation.
That said, I do have one complaint – the bit visibility is not great. For a router that wlil be used in a lot of shops for intricate detailed work, I would have liked to have had a stock clear base and a better line of sight to the action.
-- Jeff, South Carolina
dennis mitchell
3789 posts in 1208 days
posted 263 days ago
Built on a friday…about one out of five tools of any brand seem to be defective.
roman
posted 262 days ago
Its possible that I got the defective one but having a little experience with that “white metal”.........it bends and wears under constant use.
I might add that I use my trim router a lot and there are days when it runs all day, day after day…...not just turn it on, run it for ten minutes and then back on the shelf for months.
I have a Bosch belt sander…...love it, same for their jig saw.
I am not really a fan of returnming things as I always judge how long it takes to drive there, walk across their gigantic parking lots, fill in paper work, then stand in long lines, and then have to debate whether I am right or I am wrong to some one who has little clue. Take all that time and compare it to what money I could have made if I just stayed home and worked. Often its just not worth it.
Buy once, cry once….............Festool, here I come at 5 times the price
View rickf16's profile
rickf16
221 posts in 475 days
posted 262 days ago
Have the colt also, Use it a lot when I can. Great router! Ditto what Jeff said though, can’t figure why it has V/S.
-- Rick
View jcees's profile
jcees
552 posts in 693 days
posted 262 days ago
Yepper, take that puppy back to where you found it. I have one of these and I would buy another in a heartbeat. So I think you just got a lemon. Return it for another and you’ll be glad you did.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View Todd Thomas 's profile
Todd Thomas
4827 posts in 342 days
posted 262 days ago
Man…I have had this router for awhile with no problems….we use it allot…love the tilted base option, great tool…if it broke I would buy the same one….
-- Todd, Oak Ridge, TN, Hello my name is Todd and I'm a Toolholic, I bought my last tool 10 days, no 4 days, oh heck I bought a tool on the way here! †
View Schummie's profile
Schummie
121 posts in 659 days
posted 262 days ago
I have also this router and I love him, it a great router for me.
The only downside for me is, that mine has no speed control, because I have also light
problem with my hands it hurts when I use him.
I’m searching now for a lose speed control who also is usable on a router with soft start.
Schummie.
-- Greetings from the Netherlands.
RedShirt013
posted 261 days ago
Hey P.O.C. thanks for the head’s up, my Colt came with one wrench only and I just checked and did found two flat spots ground into the spindle for a wrench. However neither the wrench that came with Bosch nor any of my forged wrenches is thin enough to fit it the narrow flat spot. Never thought in my life I would purposely look for a stamped one.
-- Ed
View Dusty56's profile
Dusty56
3460 posts in 582 days
posted 260 days ago
I guess I lucked out with my COLT , as I haven’t had any problems with it at all to date. I usually have the opposite kind of luck with tool purchases . Seems as though if there are any out there that are defective , I end up buying one of them . : ( However , I have two BOSCH units that are perfect . Both are VS and I use that feature to help avoid possible “burning” of profiles on woods such as Cherry or Maple when I have to slow down the feed rate at the end of a cut or corner , etc.. The VS control isn’t there just for bit sizes : )
I also have several PC routers and I use after-market speed controls on all of them as well as my PC random orbit sanders . You don’t always have to listen to screaming motors or need full power to get the job done !
Try it sometime , you’ll like it !
View jake's profile
jake
36 posts in 597 days
posted 256 days ago
I too own a colt and have had a year of heavy use with it and no problems. I have read some threads on other sites that have talked about spotty quality. I think this is true of all of the manufactures now, as most items are coming out of China and while Bosch is usually better in quality control than most, they too must have some problems. I seriously considered the new Craftsman, that has gotten great reviews and their entire new router line, overall is very well received by most reviewers. It has many features for a good price when you use the Craftsman Club flyers. I have purchased mostly Bosch tools in the past and love them but it seems like all of the companies are competing for price, HD and Lowes keep lowering prices on DB models, you wonder at what expense of quality are they able to do that- as tools have traditionally have had low markup and few deals. Sorry to hear of your problem but I think it was more of a fluke than representative of the line.
