| Review by GaryK | posted 1948 days ago | 4523 views | 0 times favorited | 6 comments | ![]() |
- Delta 17-965 16-1/2-Inch Floor Drill Press
- Brand: Delta | Category: Drill Presses
This heavy-duty 16-1/2-inch drill press from Delta will do the job.
The 3/4-horsepower motor that can be wired for either 115 or 230 volts.
It gives you an deep plunge length of 4-7/8 inches.
Chuck holds up to a 5/8-inch-diameter bit.
Solid cast-iron construction and a 3-1/8-inch column
The table rotates, 45 degrees each way for drilling angles.
On of my favorite features is the depth stop. Instead of screwing it up and down the shaft it has
a quick release button to dis-engage it from the threads to quickly move it.
Belt charts under the top, Delta uses a wide, clearly legible chart to explain how to configure
the belts for each of 16 speeds (215 to 2,720 rpm).
All in all it’s a great drill press. I got mine used but like new.
6 comments so far
RobS
home | projects | blog
1331 posts in 2478 days
#1 posted 1948 days ago
Thanks, I always keep my eyes open for a good used drill press.. I’ll add this to the list of possibilities.
-- Rob (A) Waxahachie,TX
Dick, & Barb Cain
8681 posts in 2471 days
#2 posted 1948 days ago
Thanks Gary,
Once you purchase a good drill press it should last you a lifetime.
Dorje
1761 posts in 2168 days
#3 posted 1948 days ago
Your shop is so clean!
17849 posts in 2023 days
#4 posted 1948 days ago
Thats a nice piece of equipment Gary. The quick release would be great for me to have. The cranking up & down can be tedious.
6501 posts in 2151 days
#5 posted 1948 days ago
Good review Gary,
I second the recommendation on this Delta product.
Taigert
593 posts in 2012 days
#6 posted 908 days ago
Gary
I have the same DP and I have had nothing but problems with it, mine must have been the first one made on a Monday or the last one on a Friday afternoon before a long weekend. I’m glad to see your happy with it
-- Taigert - Milan, IN
