Works well thus far
Review by Will Mego posted 272 days ago 296 views 0 times favorited 4 comments Add to Favorites Watch
Works well thus far No-picture-s No-picture-s Click the pictures to enlarge them
With the intention of using it to spray glue down pieces of sandpaper for the Scary Sharp sharpening method, I bought this at my local Ace Hardware, large can was about $12 or so. I’ve only used it a couple of times, but thus far it works well, giving me paper glued onto 1/2” plate glass strongly enough to work chisels on it, but it pops off easily when I want to remove the paper. I just spray a tiny amount on the back of the paper, and stick it down, let it set for a few seconds. I can imagine this being pretty darn good at gluing all sorts of things down though.
-- "That which has in itself the greatest use, possesses the greatest beauty." - Unknown Shaker
View Will Mego's profile
Will Mego
204 posts in 608 days
4 comments so far
View David_Bethune's profile
David_Bethune
243 posts in 289 days
posted 271 days ago
Hmmm SOunds like KRYLON Easy Tack. I use it all the time. It’s called repositionable glue.
View dsb1829's profile
dsb1829
369 posts in 523 days
posted 271 days ago
Super77 will dry eventually. Even within an hour it will become much harder to remove the whole sheet. If you leave a sheet glued for a week be prepared to wet it and use a razor or scraper to pry it off.
I have used this for all kinds of stuff. I redid the upholstery in my 66 nova with that as the primary adhesive for cloth to the hardboard, mdf, and foam bases for door panels, arm rests, dashboard, rear deck. After several years I noticed no delamination or signs of it weakening. About the only complaint I have is to watch where it goes, because it sticks to everything :)
-- Doug, woodworking in Alabama
View 8iowa's profile
8iowa
592 posts in 657 days
posted 271 days ago
I use 3M77 to adhere sandpaper to glass plated for sharpening.dry it works very well. Water however will loosen it, and it’s not too difficult to replace a worn sheet.
3M90 is much more permanent. If you use this adhesive you will have difficulty removing the paper from the glass
View Matt's profile
Matt
178 posts in 268 days
posted 265 days ago
Super 77 rocks. On the directions, for removing things later, I think you are suppose to spray the surface, let it dry for a while then apply the other surface. I have never tested that theory. I’ve used it on my CNC to ‘boost’ the holding power of carpet tape but still allow me to ‘pop’ the piece off my router’s table.
Good stuff.
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
