Pennstate Midi Lathe
Review by interpim posted 281 days ago 1525 views 0 times favorited 10 comments Add to Favorites Watch
Pennstate Midi Lathe No-picture-s No-picture-s Click the pictures to enlarge them
I ordered this lathe as part of a pen turner starter set, and have been pleased with the results so far.
I have turned only small pieces on it so far, such as pens and a couple of chess pieces, but it has done well.
The lathe speeds are manually adjusted, which is the only annoyance I can find about it so far. Out of the box the center and headstock were dead on, point to point.
The lathe comes with a small plate, drive center, and live center.
I have enjoyed it, and plan on purchasing the extension bed once I have some extra funds to spare.
I would recommend this lathe to any wood turner on a budget. You are not sacrificing quality at all. If you want variable speed, you can pick up that model for just a bit more. If the quality of this lathe is anything like that one, you will not be disappointed.
-- San Diego, CA US Navy
View interpim's profile
interpim
446 posts in 352 days
10 comments so far
View pitchnsplinters's profile
pitchnsplinters
252 posts in 332 days
posted 281 days ago
Thanks for the review. Do you have it bolted to your bench? With the extension do you plan to keep it on your bench?
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
View NeoDon's profile
NeoDon
48 posts in 300 days
posted 281 days ago
I have the variable speed version and am pleased as well.
Try not to over tighten the Mandrel as I did, It tends to
bend it out of true and makes for a wobbley turned pen.
I will try a bowl I think, any Idea what the limit would be on this thing?
For a bowl in inches, width wise I mean.
interpim
posted 281 days ago
As for the capacity, the manual says 10” diameter. I haven’t turned a bowl yet, but a small one would work i’m sure.
View Jim's profile
Jim
67 posts in 892 days
posted 280 days ago
I have this lathe and will say for a starter lathe it works great. I paid $188 for mine with free shipping from amazon. I have done small turnings- spindles, bowls and made a bunch of saw dust and chips. the only real problems I have had are when setting it up I bolted the extension bed on and it did not line up the best. A little filling and sanding is all it took. Also this weekend I noticed my dead center was slipping in the head stock some. I have spent alot more on accessories for it than I spent on the lathe itself. mine is bolted to the stand I made for it.
-- Jim in Cushing Oklahoma
View brewtang's profile
brewtang
15 posts in 408 days
posted 280 days ago
One thing to keep in mind with lathe bowl capacities, is that it is a measurement from the center of the spindle to the top of the bed…not to the top of the tool rest banjo. Sometimes you can position the banjo at an angle and get more space, but sometimes you can’t get it out of the way totally. Another thing to keep in mind is that the closer to the max capacity you get, the lighter the cuts you have to take. More aggressive cuts will cause a 1/2 hp motor to bog down.
-- Billy, Jacksonville
View jSchrock's profile
jSchrock
48 posts in 330 days
posted 280 days ago
25792 posts in 1295 days
posted 280 days ago
I bought the same lathe, but I got the variable speed and I also got the entension table. Great lathe for what I’ve used it for. A little unhappy with the joint/fit of the entension bed. You can read my review here
View Chris Wright's profile
Chris Wright
360 posts in 375 days
posted 278 days ago
I’ve been looking at this lathe and it’s variable speed brother. I’ve used several different mini/midi lathes (the Jet Mini and the General 25-100) Didn’t have to much trouble with a small bowl, just had it stal the motor out so I had to go slow. Also, and this seems like a no brainer but, keeping your tools sharp will help keep from bogging the motor down. Good luck, have fun and play safe.
Here’s my review of the General 25-100 (http://lumberjocks.com/reviews/491)
-- "At its best, life is completely unpredictable." - Christopher Walken
View itsme_timd's profile
itsme_timd
676 posts in 725 days
posted 276 days ago
I got this lathe in the pen turning starter set as well. After using it for a while I’d say it is a decent, inexpensive lathe.
PSI also offers the VS motor by itself, if you want to add it later, took me less than an hour to upgrade mine and well worth it!
-- Tim D. - Woodstock, GA
View GaryCN's profile
GaryCN
180 posts in 829 days
posted 275 days ago
It looks almost identical to the Steel City one that I have with one exception the location of the
power switch. Under $200 I have not used mine yet except for a few test scraps. Steel City Mini
-- Quando Omni Flunkus Moritati
