Rarely needed yet useful
Review by JuniorJoiner posted 1562 days ago 4153 views 1 time favorited 6 comments Add to Favorites Watch
Rarely needed yet useful No-picture-s No-picture-s Click the pictures to enlarge them
I have had a set of the Lie-Nielsen Joinery floats for a few months now, and unbelievably i have even found uses for them.
When i first saw these tools advertised on their site, I actually called my wife over , and showed her. Not from amazement or anything like that, but to tell her to never get them for me.
Apparently she pays as much attention as i would to her new shoes, because just short weeks later they arrived.
Smiling and being thankful, I put them all in the tool roll, and tossed them in the bottom drawer of my bench.
But, against my prejudice, i have used them and found them useful.
What these Joinery floats are, is basically a coarse single cut file , that cuts either on the push or pull stroke.
they are sized precisely in Sae, and have a fine fit and finish that you would expect for the lie nielsen price.
what they are intended for is precise fitting of mortises. Which is why i thought they were a strange choice of tool. usually doing mortise and tenon, you make the mortise first, then fit the tenon to the mortise. voila, no need to ever fit a mortise. and if you did, why not use the chisel you made the mortise with in the first place. or even a file or ironing rasp if you wanted to get fancy.
well, their use, as i have discovered, is to get good results without getting fancy, or spending alot of time on marking and setup.
Normally when i would make a through tenon, i would precisely mark the mortise location on both sides of the mortise piece, and carefully inscribe the back side of the mortise piece before i started pounding with the mallet for fear of blowing out a chunk of wood i wanted to stay there.
then , spend more time trying to trim everything precisely with my chisel against a guide block.
anyway, the problem with those actions is that you are trying to work end grain, or edge grain. neither of which is very forgiving. These tools are built just for that purpose, and work well. sized for many different mortises, you can use them to trim the mortise sides, and since they only have one cutting face, you can work them without fear of damaging the surrounding hole.
I have found that in use, i can have mortises looking alot better with alot less work, and usually without the need to do tons of paring with a guideblock.
So, in conclusion , Lie Nielsen built a really good, useful tool. that most woodworkers would never buy or reach for. they have made my work better or at least more efficient.
Now if they would just make the tool I reach for the most, A panel saw.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View JuniorJoiner's profile
JuniorJoiner
441 posts in 1607 days
6 comments so far
TopamaxSurvivor
13192 posts in 1843 days
#1 posted 1562 days ago
Good review.
View ShannonRogers's profile
ShannonRogers
534 posts in 1955 days
#2 posted 1562 days ago
Great review. I just got 2 of these face floats for Christmas. I am excited to try them out. BTW, I have heard rumors of a LN panel saw in the works. Let’s keep our fingers crossed.
-- The Hand Tool School is Open for Business! Check out my blog and podcast "The Renaissance Woodworker" at www.renaissancewoodworker.com
View johnjoiner's profile
johnjoiner
160 posts in 2060 days
#3 posted 1561 days ago
Nice review.
Is there one or two floats you’d recommend to those of us not lucky enough to have a spouse who will buy us the whole set? :-)
-- johnjoiner
JuniorJoiner
#4 posted 1561 days ago
If i had to recommend two , it would be the 1/2 inch mortise float, and the offset face float(pull)
the reason for this is, the mortise float is really handy when making mortises larger than you have mortise chisels for. My largest mortise chisel is 1/2 inch, making bigger mortises requires more trimming which these floats do well. Besides, smaller mortises are more easily worked with chisel alone.
the offset face float(pull) would be my second choice because it is the most versatile. the pull motion allows you to work the back of the mortise towards yourself (edgegrain). this allows you to widen a mortise without blowing out the back side. The offset I find handy for keeping the mortise true.
hope this helps
View tenontim's profile
tenontim
2129 posts in 1911 days
#5 posted 1561 days ago
I’ve been looking at these, but the question I have: did you use any kind of files before you got these? I’ve been using flat, bastard cut files for working mortises for many years. They work fairly well, not to coarse, so the sides of the mortise stay very smooth. At a third of the price, I’m having trouble selling myself on buying the floats. If it works better than the files, then it’s something I would use constantly. If not, like you said, it would be one of those tools that rarely comes out of the tool box. Thanks for your input.
-- Tim-- http://www.tmuli.com
JuniorJoiner
#6 posted 1561 days ago
I have about a dozen files and rasps i keep on my bench, and more special purpose ones i keep elsewhere.
these floats cut faster than most of them, and all fit mortises better.
their real benefit is the speed of cut, and the safeness over a file.
worth the price? thats debatable. if you commonly cut a mortise sized to one of these floats. then i would.
for my work they are a rare use item.
