BowlSaw
Review by DougTx posted 299 days ago 897 views 0 times favorited 10 comments Add to Favorites Watch
BowlSaw BowlSaw No-picture-s Click the pictures to enlarge them
I had a very good experience with the 6” BowlSaw. The pictures show a black walnut blank that I now have a bowl and another piece that can be turned into a smaller bowl and/or a box. I followed the instructions included with the tool and did not have any problems. I started at 120 rpms and finished at 400 rpms. Will probably get the 8” tool and thus can core larger blanks and possibly make 3 bowl out of one blank.
DougTx
View DougTx's profile
DougTx
4 posts in 299 days
10 comments so far
View lew's profile
lew
4496 posts in 652 days
posted 299 days ago
I have to Ditto what Doug said!
Lew
View cabinetmaster's profile
cabinetmaster
8637 posts in 455 days
posted 299 days ago
I’m waiting for some warm weather so I can get in the shop and try mine.
View motthunter's profile
motthunter
2079 posts in 696 days
posted 299 days ago
now i see what the tool does.. thanks.. pretty cool
-- making sawdust....
View ShawnAllen's profile
ShawnAllen
30 posts in 350 days
posted 297 days ago
Have you thought about creating bowls on your tablesaw..?
Was going to provide a reference, but I seem to have returned that particular saw book to the library, sorry.
DougTx
4 posts in 299 days
posted 297 days ago
ShawnAllen
I have not made bowls on a tablesaw. If you find the article, please forward to me.
Thanks
View WoodWrangler's profile
WoodWrangler
34 posts in 687 days
posted 293 days ago
What does it do? Cut the bowl from the lathe? I must be missing something.
-- Jeremy, Charlotte, North Carolina
DougTx
4 posts in 299 days
posted 293 days ago
The BowlSaw cuts a core out of the bowl blank. This is wood that would normally be turned in to shavings or dust. The core could be used to turn a smaller bowl/platter/etc.
WoodWrangler
posted 293 days ago
I can see that now … thanks for the clarification.
I would be fearful that the large teeth on it would catch. Also, wouldn’t be require a rather “square” (not box, but sidewall-to-base) bowl in order to slip in in for the cut—or is the cutter angle adjustable?
DougTx
4 posts in 299 days
posted 293 days ago
The tool that I received was square but I have seen a picture somewhere that the blade looked to be at an angle. My thoughts about an “angled” tool is it would be harder to control. The cut-out core and the sidewall of the original would be “square” however the sidewall could then be turned to whatever shape is wanted assuming that there is enough wood left in the sidewall.
View Bob Collins's profile
Bob Collins
210 posts in 581 days
posted 264 days ago
Simple solution. Start with larger blanks and leave the side walls a greater thickness and any shape can be created with 1,2 or 3 bowls. Bigger has always been better so they say.
-- Bob C, Australia. There are two theories to arguing with a woman and neither of them work.
