My review of the Ridgid EB4424 Oscillating Spindle Sander
83K views 49 replies 26 participants last post by  marcbousquet
#1 · (Edited by Moderator)
Ridgid - EB4424 Oscillating Edge Belt / Spindle Sander (Rating: 3)
Hi, after much deliberation, and reading and rereading the FWW review, I bought the EB4424, Ridgid Oscillating Spindle Sander.
8/4/15 Update:
I returned #2. I then took a combo square off the display and applied it to the display unit sander. Much flatter table, and much more coplaner tables (tiltable table relative to fixed), and near perfect perpendicular table to spindle. All I can suggest is the older models were machined with much tighter tolerances. In my opinion the latest FWW article is mistaken. The older review may have been true, but either FWW got an older model sander this time around, or Ridgid swapped out production shortly after the review. I can see where those of you with the higher quality machine could rate it a 5. But my 3 is generous for what's currently on the shelves.
7/24/15 Update:
I returned the unit, and bought a 2nd one. It is more or less the same; certainly no better. All the same issues below apply. I have not powered it on yet, but the tilt-able table is not flat-with the same sort of crown near the spindle. If the tilt-able table is set perpendicular to the spindle, than it is not co-planer with the fixed table. Running a straightedge across the tiltable table, it extends above the fixed table with a gap of about 1/16". That constitutes significant wobble for a piece one would sand where you transfered the center of gravity from the tiltable table to the fixed table (e.g. sanding the inside of a bandsaw box).
While I was at the store, I looked at the "display model". It's a different beast. First, the rollers on the belt sander assembly are METAL vs plastic on the one in the box. The belt assembly is all metal, whereas the boxed one has plastic in various places including the tab that positions the small roller into the cutout in the table. Second, the table has a more polished finish than the rough painted one in the box. The display model - clearly older - generally has a better fit and finish look and feel about it. I just about grabbed an associate and asked if I could buy the display (though clearly lacking various parts). This is one of those times I kick myself for not buying this until when FWW reviewed it the first time a few years ago.
It reminds me when I bought a Ridgid 6" random orbit sander 10 years or so back when it was made by the German company, Metabo. It was a $110 sander. I bought two in fact once I learned it was likely to be later manufactured in China. I believe that did happen a few years later.
I think #2 is going back to the store. I may try again in a few months. Maybe enough returns come in that they get the message. If you have an older one, I think you have much better quality unit.
Here are my observations:
1) The tilt-able table is not flat, and not coplaner with the fixed portion of the table (where the spindle protrudes). Mine has a hump in the 3" flat area (the area nearest the spindle on the tilt-able table). The very edges of that area are flat, but as you come inwards toward the center, the hump is very pronounced. You can feel it with your hand and if you put a 3" long straightedge (engineers square) on the table, there's a hump that allows stock to rock toward and away from the spindle at least 1/32". If your stock is 5 or 6 inches it may not matter, but for 3-inch or smaller stock it is going to be impossible to sand perpendicular to the stock. If you align the adjustable table to be perpendicular to the spindle, then the adjustable table is not coplaner with the fixed table. If you keep most of the stock on the tiltable table, then that may not be a problem, but if you move the stock and reference off the fixed table (e.g. inside sanding) , the spindle will no longer be perpendicular to the stock. Also for sanding thin stock, 1/8" up to maybe 1/2" this may not be a big issue, but as you sand over 1" thick, edges will start to get out of perpendicular by a noticeable amount. I was sanding a 3" high bandsaw box, and had to flip the box over periodically to minimize uneven sanding. This was not a precision operation, but it clearly indicated that if it needed to be, I would have been in trouble.
1a) I initially setup the tilt-able table to be nearly co-planer with the fixed table. That turned out to be a problem, as the tilt-able table was then way off from perpendicular to the spindle. I decided it was more important to be perpendicular to the spindle, so re-adjusted the tilt-able table. For the best accuracy you may want to just remove the little indexing part from under the tilt lock knob. Just get out an engineers square or digital protractor to set your angles. Most of the time I would think having the stock perpendicular to the spindle would be more desirable. Again, from (1) above, that hump in the tilt-able table will cause major issues on stock under 5" wide or when referencing from the fixed table.
2) The onboard storage of "everything" is awesome. A big plus especially with the inserts, washers, etc. (but there might be a better way.. see #4)
3) The belt sander assembly is lightweight. The rollers are plastic, and in fact, the 3" roller on mine has a small nub from the mfg process. It would be easy to sand off, except it oscillates! A little hand filing should resolve. I doubt the platen is all that flat. Again, the belt sanding accessory is handy, but only light duty. My jointer and crosscut sled will not get any less use.
4) The little orange plastic insert for use with the spindles is warped like crazy. It is lightweight plastic and warped 1/4". The leveling feet are of no use, as it wobbles no matter what. A 1/4" aluminum or hardwood plate would be much better. Mill a plate for each spindle size and forget the inserts and wobbly plastic plate. You might be able to get away with only 2 plates-one for the 1" and under spindles and one for the 1-1/2" and above spindles. Another idea-just make an entire top overlay, maybe from 1/2" mdf. Again, a couple may be sufficient. That would make the entire top perpendicular, though you'd need to shim it somehow and fasten it, and lose 1/2" of spindle height. Also, the adjusting screws on the plate have little to rest on. There is enough side to side play in mine that the adjusting screws slide off their contact points. This whole insert design needs more thought.
For me-I think I will try to get another one, or at least a replacement tilt-able table and hope to get a much flatter piece of cast aluminum. That would help a lot. With that, then I'd be tempted to shim up a 1/2" mdf overlay top to get a near perpendicular top a full 360 degrees around the spindle. All of this assumes the spindle runout is a few thou, otherwise I'm chasing after pots of gold near those elusive rainbows. As-is,the sander is functional, and at 199 + tax, quite a bargain. But there are some major shortcomings for those who want or need precision.
Thanks for reading. If you have one of these sanders and simple don't see the issues I have, I'd love to hear from you. I have read there are various QC issues, so maybe I just happened to get one.
#2 · (Edited by Moderator)
I have one of these and while it took some fidgeting at the beginning, I didn't have the same problems as you. Mine is about 10 years old, so could have been manufactured to different standards or even another factory or country. If you're not happy with it I would definitely take it back and see if you just got a lemon.
Only issues with mine are dust collection (there are some clever work arounds if you search the site), and the top knob has lost most of it's rubber, but considering the use I think that's acceptable.
#3 · (Edited by Moderator)
I really think you should return your sander if you have not had it long. I also have one (about 4 years old) and I like it allot. I have never had any of the problems you have had. I think your unit should not have left the factory in the first place. I build allot of Band saw boxes and it gets used allot. I do wish the sanding sleeves were longer but if I only have to turn the box over once in awhile,. I can live with that. And the little knob on mine is also starting to loose rubber…I wonder if they have those as replacement parts
#6 · (Edited by Moderator)
I've had mine for about 3 years… motor went out & had to be replaced (no cost to me, but time missing it) after about 1 year . When they replaced the motor they also changed the belt assembly to one that has metal rollers to go with the new motor. My original unit had plastic rollers.
So you may have received a old model before the up grades…?
Either way, I agree you should return it.
I really like mine & would buy another one.
#9 · (Edited by Moderator)
I bought one about 8 weeks ago so we probably have the same manufacturing rev of it. I don't have the same issues with mine so it makes sense to return it for another. I agree that it's not the most heavy weight piece of kit but given that it was 200 clams (with $40 off for signing up for an HD card), I can't complain too much about that. Also, I agree that the DC is most charitably described as "weak". However, it does what it's supposed to do.
#11 · (Edited by Moderator)
Thanks, somewhere another person noted the tilt-table being out of flat. And for me it's right at the spindle. I did measure spindle runout with a dial indicator and rotating by hand. +/- 1 thou-so quite good. I will update my review, but I did just measure the "rock" back and forth on the table. Across that 3" area in front of the spindle I can easily slip in my .024 feeler guage. So it's not 1/16, but 1/32 is fair.
#14 · (Edited by Moderator)
CO_Trout, I had the same problem, only worse. I ended up returning two units back to Home Depot because I could not get the tilting table square to the sanding belt. The issue the two had were that the tilting table was not flat, so there was no way to get it square to the belt. If the table was set flat at the hinge point, then the far side of the table was about 1/8" lower. I am sorry to hear that you also had an issue with this sander. When I returned the sanders to the store I told them that they were defective, and explained what was wrong. It seems like Colorado got a shipment with quality issues. I hope that they can get these built better since I would like to get one before the fall building season.
Mike
#15 · (Edited by Moderator)
I'm in NE Kansas. Got this one at the Topeka Home Depot. The two big issues for me are:
1) tilt-table is not flat. I cannot judge icoplaner with the fixed table w/o a flat table.
2) the plastic insert around the spindle is not even close to flat and the adjusting screws will never sit well on their resting points.
RE: 1-hopefully another will fix this issue. It says to call Ridgid first.
RE: 2-maybe another can remedy this, but if I can get a flat table, I may just cut a 1/4" mdf top overlay to fit for a couple spindle sizes.
With a flat table I'd raise this to a 5-star.
#17 · (Edited by Moderator)
I've been wanting to get one based on user reviews, but with all the negative reviews I've read, not only on this tool, but other Chinese made tools by Ridgid and other companies, I have decided not to throw my money out the window on inexpensive, consumer grade tools and buy known quality tools. My expectation of any tool is quality, longevity and trouble-free operation. Oft times, I will buy a cheap tool and rebuild it. $200 is not a cheap (price) tool, so I would not use it as a base for a tool bash. My latest was a HF trim router ($20) that I took apart and used just the motor for a special purpose tool. Worked fine. I know others may not have the time or the expertise to do this, but I am retired and time is not a factor. My advise; return it and wait for something good to come around; maybe a used tool in good condition.
For what it's worth, I read reviews on this tool that were 5+ years old and they were glowing. We can no longer rely on past reviews and expect a current model is equal or better than an older model. I'm still looking.
#18 · (Edited by Moderator)
Ok, ok … I have read your rant three times, and I have waited a couple of days before responding.
First of all, you expect a low end spindle sander to have the specs of a milling machine that cost several thousand dollars.
If you will look at the tables they are cast aluminum, not ground and polished steel … Of course they are not perfectly flat nor perfectly coplanar to the fixed table … (you can tweek these into very useable position).
For the specs that your looking for, they can be found in a higher quality machine, but rest assured, you will pay the price. Look at the Jet and the Grizzly versions of the spindle sander, there you will find perfectly flat tables and a bit more powerful motors.
I bought the Ridgid Spindle sander because of it's modest price, and I understand that at this price, it will have some deviancies, it is a utility grade tool for the home hobbyist and I can live with that; but to expect polished and balanced steel rollers would raise the price of the machine some where around $80 each.
I like my Ridgid spindle sander and use it nearly every day.
My friend you have bought a KIA, and you are expecting M-Benz precision … that just "ain't gonna happen".
#19 · (Edited by Moderator)
No worries, I understand. But the glowing reviews, especially the one in FWW, are distorted. At $200 its a great value, but they did not calll out these facts. I'm going to swap for a new one, and see. Areas of that cast table are flat, but others are not. The adjustable feet of my insert won't stay on their tiny resting points. Like another mentioned, I'm good with taking an OK machine and making some improvements. The Northern Tool chainsaw grinder comes to mind. Some folks got together on a forum and called out the tweaks that take this $100 tool and get it fairly close to a $300 one.
#21 · (Edited by Moderator)
Yes I have had my sander for about 5 years. I remember the same thing happened with the DeWalt 788 Scroll Saw. I had the 2nd addition and ended up owning 5 of them..kept taking it back and getting a new saw thinking one of the would work as it should. Give you an idea of how much I do like the Rigid sander, I sold the Jet sander I was using.
#22 · (Edited by Moderator)
Like everything it seems, quality has gone out the window. My sander is no more than two years old, and I must have
got one of the last good ones.
I own several Ridgid tools, and while the tools have been good for me so far, another issue has been there lifetime warranty. The last Ridgid tool I got was an orbital sander. Registering for the warranty was rejected, and I here many are having this issue. Seems they make it hard enough to register, and most will give up.
A total shame, what has been a good tool company has gone away.
#23 · (Edited by Moderator)
Yeah, the display was a nice looking, solid fit and finish sander. With the all metal rollers and assembly it looks high quality. The one is the box is almost toy-ish. I'd think for $50 they could get back to the same quality, but someone in marketing probably figures they have to hit the 199 price point. I may try a few other locations, and pop open a box in a few months. 199 for the quality one would be a great buy.
#24 · (Edited by Moderator)
As I mentioned in a earlier reply, mine is about 3 years old…
It came with the plastic rollers on the belt assembly.
When the motor crapped out (about a years time frame) & I took it to the "authorized center", they got the replacement motor (a different version) from Ridgid & along with it came a new belt assembly since the original one wouldn't work with the new motor. I was told the old motor had problems.
This belt assembly had the metal rollers.
So now it seems the Newest units have the plastic rollers again?
That's weird.
Even with the issue I had, I really like mine.
#26 · (Edited by Moderator)
This is a very interesting post, because I had the very same issue 2 months ago. The table was so warped I could believe it. Called ridgid and they said I had to return to Home depot to get another one. Luckily I found one on Craig's List being sold by a guitar maker for half the price and the table is dead flat. Guy said he had it for years and works perfectly. So far he was right. Maybe newer ones really are crap?
