Fantastic substitute for remote control dust collection
Review by Rayne posted 07-17-2015 02:53 AM 35514 views 1 time favorited 10 comments Add to Favorites Watch
Fantastic substitute for remote control dust collection Fantastic substitute for remote control dust collection Fantastic substitute for remote control dust collection Click the pictures to enlarge them
This is my first review so hopefully this is decent. I have been looking for ways to remotely turn on my Dust Collector for a while now. After being snubbed a bit by PSI for their remote I went on a hunt for a new solution that wouldn’t cost me a ton of money and was less likely to fail. After hunting for a while, I ran across this little gem. It’s a wireless receptacle that can be turned on or off with a remote (only the bottom receptacle; top is always on). Since you’re cutting power off from the receptacle itself, I would think this was less likely to fail and for $40, it was worth the risk in trying. It is a 20A 120V duplex receptacle. It installs like any other receptacle except that it has a little button on the front. The neat thing about this is that it can be manually turned on or off by that button if you so like. Maybe the remote is further away than you being at the plug; just push the button and it turns off. Now, I should mention the remote had to be bought separately, but luckily, you can get the generic GE brand for about $12. The remote is a little finicky, but it works. Considering the alternatives, I have no qualms with it and since it’s not a Z-wave brand item, I can’t knock a star down on the receptacle. With no extra bulky box, easy install, and 20A coverage, this was one of the better investments I’ve made and am glad it exists. If anyone has any questions, I’ll be glad to answer them.
Pros: – $40 – Easy to install – True 20A – No extra bulky box – Works as hoped
Cons: – Remote is finicky, but that’s a different brand; Z-wave version probably works better, but costs a lot more. – Only the bottom is wireless, although that could be a Pro to some by having at least one receptacle “on” all the time.
View Rayne's profile
Rayne
913 posts in 1567 days
10 comments so far
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1204 days
#1 posted 07-17-2015 03:08 AM
Thanks for the review. Please update us as time passes.
View GFactor's profile
GFactor
80 posts in 1627 days
#2 posted 07-17-2015 08:52 AM
Just an FYI:
Z-Wave is a standard protocol / platform as opposed to a manufacturer. Kind of like CAT5 or CAT6 in a sense, kind of, as these are standards that have set.
All products with the official Z-Wave logo on them, are 100% compatible with each other. Most newer security systems, like 2GIG for instance, are Z-Wave enabled and can control an outlet like this, either with your phone, tablet, PC, key fob, or right from the actual panel itself.
Z-Wave operates at 900mhz so older cordless phones could cause some interference issues, but for the most part, you should not have any issues.
Depending on the remote (and controller), the first time you press the remote, it may only be checking the status of the outlet. Also, turning it on and off several times in a row, could cause delay issues.
Lastly, Rule #1 when programming Z-Wave devices, ALWAYS remove / delete the new device before trying to learn it. Even though you have a brand new part, 9 times out of 10, it must be deleted (even though it was never added to your network).
Probably way more info than most people care about, but I promise you my Rule #1 will save countless hours of frustration if and when you decide to use ANY Z-Wave products. Or if you have a technician at your house adding it for you, you can save the day when his head is ready to expload LOL.
Cheer!!!
-- To Steal Ideas From One Person is Plagiarism; to Steal From Many is Research…
View Planeman40's profile
Planeman40
1179 posts in 2788 days
#3 posted 07-17-2015 02:14 PM
If your aim was to obtain a remote inexpensively, I would have recommended what I have been using for 2 years now that costs only $10!
http://www.amazon.com/Woods-32555-Outdoor-Control-Converter/dp/B001Q9EFUK/ref=sr_1_4?ie=UTF8&qid=1437141912&sr=8-4&keywords=electrical+remote+control
It is robustly made and does the job well for my large Delta 110 V vacuum system. I super-glued the remote to a powerful magnet (http://www.harborfreight.com/66mm-round-magnet-96650.html) and placed it next to the on/off button on my table saw.
I’m sold on this thing!!!
View bigJohninvegas's profile
bigJohninvegas
456 posts in 1489 days
#4 posted 07-17-2015 02:58 PM
I to am using the $10 remote. Although I do like the idea being reviewed here. It’s crazy what the cost is on dedicated dust collector remotes.
I got my remote at the big box store at Christmas time. Intended for outdoor Christmas lights.
had to shop around. 1st one I saw was only 13 amp. Found the 20 amp at another store. I have been using it for about 1 1/2 years, and it works great. It has a key Chain type loop on it and I keep it hooked to my apron.
-- John
bigJohninvegas
#5 posted 07-17-2015 03:49 PM
-- John
View CyberDyneSystems's profile
CyberDyneSystems
283 posts in 2216 days
#6 posted 07-17-2015 05:02 PM
Very cool idea for a lot of potential uses.
The little $10.00 simple one at Amazon looks good too!
-- Without the wood, it's just working
Rayne
#7 posted 07-17-2015 05:47 PM
I tried hunting down the 20 amp version of the dongle you guys are mentioning, but nothing would show up and nothing locally came close. That outlet was the only thing that qualified for my DC. What store did you get the $10 one at 20 amps?
View philba's profile
philba
96 posts in 1400 days
#8 posted 07-17-2015 06:02 PM
The only issue I have with the remote control approach is, well, the remote control. Just another thing to lose. For me, a better approach is to have sensing outlets that will turn on the dust collector when there is a load. I have an iVac one for dust extractor cart and love the flexibility (don’t love the iVac but that’s a different story).
There are plans to build sensing outlets for a few $$$.
View brtech's profile
brtech
1029 posts in 2950 days
#9 posted 07-20-2015 08:57 AM
You can’t use the iVac approach for a bigger DC, because it needs a dedicated circuit (the 20A part) and the tool often needs one too. Also, some tools are 240, where the DC could be either. A shop vac or portable dust extractor can be powered from the same circuit as most portable tools, so it works there.
There are ways to get the same effect, but it is pretty expensive. Basically, you need to have a wire or radio connection from the load sensor to a contactor or relay on the DC. Another way is to use a sensor on the blast gate.
Also expensive, but that works really well.
View b2rtch's profile
b2rtch
4861 posts in 3076 days
#10 posted 07-20-2015 04:53 PM
I used to use the $10.00 version but I went through two remotes in one year.The contacts on the remote burn out.
I now use a similar remote but different brand.
I use my remote to control not the DC itself but a relay for my Clear Vue 5 HP cyclone dust collector.
The new remote has been working for over one year now.
I never yet lost my remote, I always leave the same place.
-- Bert
