Review of ClearVue 1800LH
Review by Padre posted 304 days ago 1745 views 4 times favorited 38 comments Add to Favorites Watch
Review of ClearVue 1800LH Review of ClearVue 1800LH Review of ClearVue 1800LH Click the pictures to enlarge them
I purchased a ClearVue cyclone 1800LH for my shop about two months ago. Had torn muscles in my shoulder, so put it up a month ago, had shoulder surgery, and finally got it wired and turned on for the first time today.
First Impressions: The unit came complete, packaged extremely well. Everything labeled, wrapped, boxed, re-wrapped. I unpacked everything and nothing was dented, broken, scratched or otherwise in any condition but brand new. The system also came with a remote control and 6- 6” blast gates.
Put the unit together. This is more than a 1 person, 1 day project. The motor is REALLY heavy (5hp). The impeller is REALLY heavy. It took me two full days of assembly with the on and off help of two others. The directions are very good with only one minor glitch.
NOTE: Ed, the owner of ClearVue, is a fantastic guy. He actually answers the phone when you call, helps you at any time and answers even the most minor question.
After installing the ClearVue it was time to run the pipe. I chose 6” S&D PVC (green) with S&D elbows (white). I ran the 6” pipe as close as possible to each piece of equipment. I then reduced down to 4” and ran 4” flex hose to each piece of equipment. The longest piece of flex hose I used is 4’. For my drill press I had to reduce down to 2 1/2”.
After reading many articles I decided NOT to ground the piping. If I find that static becomes a problem, I will run copper wire to all my screw joints.
I have absolutely no 90 degree bends, but I do have some back to back 45 degree elbows. 90 degree elbows absolutely kill the airflow.
I put in seven machine drops and one floor sweep drop. The plumbing took another week to complete. Finally found a 30 gallon galvanized garbage can to complete the system, put on the filters and then had to wait to wire it up.
Wired it up today and turned it on for the first time. I did not expect and was shocked to see the power of this unit. It actually lifts up the 30 gallon garbage about 4” off the stand, and then sucks the sides in on the can about 3” I shut it down and called Ed and was assured that this is normal.
All I can say is HOLY COW. This is one powerful, quiet, well-put-together American Made system. I highly recommend this unit.
-- Chip -- Manchester, Connecticut "When the power of love overcomes the love of power, the world will know peace."
View Padre's profile
Padre
259 posts in 382 days
38 comments so far
View bentlyj's profile (online now)
bentlyj
783 posts in 363 days
posted 304 days ago
Man, that thing really “sucks”
Looks like quite the setup. Should keep the dust where it belongs for sure. Nice unit.
View pickles's profile
pickles
49 posts in 306 days
posted 304 days ago
Yeah I built a sheet metal version of Bill Pentz’s design (the basis for Clear-vue) and shocking is the best description of what happens when that thing roars to life! Be sure to keep a gate cracked as I’ve heard the suction with all gates closed can crush the cyclone (atleast a sheet metal one) Awesome system!
View John Gray's profile
John Gray
1752 posts in 778 days
posted 303 days ago
Thanks for the information it will help me plumbing my new DC.
View tooldad's profile
tooldad
454 posts in 607 days
posted 303 days ago
I’ve gotten away with using standard HVAC 6” round snap together metal piping. I would be afraid to use that with this system.
View PurpLev's profile
PurpLev
2733 posts in 541 days
posted 303 days ago
nice, thanx for the review, this will def. be a future project for me after I find a more permanent location.
the only thing that kinda struck me as odd though was the fact that you chose to plumb the entire run with 6” pipes which is excellent, but then you reduced it to 4” at each drop, and to 2 1/2” on the drill press… I fail to see this logic unless this is a temporary solution:
1. reducing the 6” pipe to a 4” opening kills your airflow just like a 90 degree elbow will (same concept) by creating a bottle neck for the air. I would just go 6” all the way – including the flex hoses… you obviously invested ALOT of money into the cyclone, and the plumbing – the extra expense to have the flex hoses also 6” would be minimal.
2. 2 1/2” for the drill press? since this is all a fabrication (no dust ports on drill presses – so its all up to you to set it up) why not keep it at 6” as well? ....same logic as my previous note about reducing to 4” only this time it’s more worse…
not trying to be negative here – just made me very curious!
View Built2Last's profile
Built2Last
102 posts in 370 days
posted 303 days ago
Very nice looking system. What’s the red light hooked to?
-- BUILT TO LAST WOODWORKS, West Blocton, Alabama
View spaids's profile
spaids
458 posts in 586 days
posted 303 days ago
I have a little one for my shop vac. I have no room for a dedicated dust system in my garage shop. Even the little shop vac system they sell is great. The finer the dust the better it works. Its like magic. The shop vac stays empty and the important thing, the shop vac filter, stays clean and the suction stays high.
I did break mine once and I got on the clear vue forum to ask about recommended material for the repair. The answer to my question was “I have your address on file. Let me know if your address has changed or not and I’ll get you a new unit out right way” It was followed by answering my question on repair in case I wanted to fix it and have a second unit. I told the guy it was probably my fault. He didn’t care that it was my fault. Crazy awesome service! Very impressive product! Coming from some down to earth guys in South Carolina. There is nothing about it that isn’t great buy.
-- Wipe the blood stains from your blade before coming in.
View Charles Mullins's profile
Charles Mullins
94 posts in 604 days
posted 303 days ago
Chip,
I had read about some people having trouble with too high a suction. One fix I heard of was to use a dampner at the end of the main line with it spring loaded for suction adjustability. This also allows the main line to have the volume of air it needs to help keep it clear.
For what it’s worth.
Charlie Mullins (Mine isn’t finished yet, I’m jealous) Hee hee
-- God makes the wood beautiful--I simply rearrange it to make it more useful, hopefully.
pickles
posted 303 days ago
Purplev – check out Bill Pentz's website it explains all about dust collection and he definately says to use bigger pipe whenever possible. Plus if Padre wants to change to 6” later the infrastructure is already there. I changed most of my tools over to 6” but a few light dust makers I left 4”.
PurpLev
posted 303 days ago
pickles... I am aware of Bill’s website, which basically say what I referred to in my previous comment. if it’s a temporary solution just to get by thats great… but since this was all been put at the same time – I dont see the reason for a need for a ‘temporary’ solution for most of the drops… which made me curious.
Padre
posted 303 days ago
The red light is an old traffic light a friend gave me. It wasn’t working, so I took it apart (not much to them), found an inexpensive controller on line and hooked it up. It now cycles every 35 seconds, red, green, yellow. :)
Padre
posted 303 days ago
Purplelev,
I dropped down to 4” because my equipment (the bandsaw, joiinter/planer, table saw, etc.) all came with 4” dust chutes already attached. I didn’t want to ‘re-invent the wheel’ and since I put blast gates on each drop ans will be opening them one at a time, for now the 4” will be ok. I will re-configure to 6” in the future when my shoulder and $$$$ allow. Right now the Mrs. has pretty much shut down the shop budget! :)
Padre
posted 303 days ago
Purplelev,
Just to check, I googled and cannot find 6” dust chute/port for woodworking equipment. Do you know where these might be available?
PurpLev
posted 303 days ago
Padre – fair enough!
glad to see you’re back in action :) hope your shoulder heals quickly.
20575 posts in 715 days
posted 303 days ago
Thanks for the review. I am in the market for a dc system and will have to take a look at one like this.
View CessnaPilotBarry's profile
CessnaPilotBarry
1263 posts in 595 days
posted 303 days ago
Don’t get too close to any open vents!
I used 6” “flange” adaptors, from any sheet metal duct source, to connect to 6” metal pipe. I’m sure it could be adapted to PVC. I bought mine @ Portland Winnelson (which is not in Portland <g>...), but I’ve seen them in Lowes and HD.
BTW… Nice traffic light.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View Brad_Nailor's profile
Brad_Nailor
1214 posts in 850 days
posted 303 days ago
wow that looks like a nice DC setup. I like the PVC pipe instead of the usual metal. Nice work!
View ND2ELK's profile
ND2ELK
6155 posts in 667 days
posted 303 days ago
Your dust collection looks great. I just finished putting mine in. Now I need to start buying my equipment. Check it out and see what you think. Thanks for posting.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View pitchnsplinters's profile
pitchnsplinters
252 posts in 330 days
posted 303 days ago
Awesome setup.
Here’s a pretty cool dust collection barrel, the Parks & Parks Dust Bagger. It might save a bit of wear and tear on your shoulders.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
View woodbutcher's profile
woodbutcher
431 posts in 1058 days
posted 302 days ago
Padre,
Looks like you’ve got one more system there.I’ve been thinking about a system like that-now that you’ve got the plumbing down and the shoulder is on the mend-wanna come put mine together?-LOL Seriously though, I’m glad you had something delivered that wasn’t damaged in transit finally! How about some high speed photos with maybe some purple heart-blood wood-yellow heart-all going through that clear vue cyclone! Hope the shoulder heals quickly, you can enjoy the dust collector and we can see some new projects. Take care!
Sincerely,
Ken McGinnis
-- woodbutcher north carolina
View Quebecnewf's profile
Quebecnewf
88 posts in 770 days
posted 302 days ago
I too am thinking of buying this system. Everyone has nothing but good remarks about it. I don’t believe they have a canadian dist. so I don’t know how big a hit I will take with exchange and duty.
This will be my main project for next summer fall. That is after I get my shop insulated,wired,lighted etc etc.
See my blogs
Quebecnewf
View Doug S.'s profile
Doug S.
306 posts in 601 days
posted 302 days ago
Nice looking setup. I put in a CV 1600 a couple years ago and have been very happy with it. ditto on dealing with Ed. He’s always available for help and i was pleasantly surprised to get same day email replies to questions on Saturdays, sundays, and evenings. I think there’s more assembly involved with their systems vs some other systems but I think it’s worth it in the end. I’ve never read a single negative review from CV owners.
-- Use the fence Luke
View David Freed's profile
David Freed
94 posts in 560 days
posted 302 days ago
I agree with spaids. Ed Morgano is a real great guy to deal with and talk to. I bought a CV1400 before he started making the CV1800. It does a great job too.
I had so much sawdust to deal with that bags or canisters weren’t practical. I hooked a blower to the bottom of the cyclone that would blow the dust into a self-unloading trailer outside. With this system, you can spend your time making things, not handling sawdust.
-- David, Southern Indiana
View cabinetmaster's profile
cabinetmaster
8498 posts in 451 days
posted 302 days ago
My what a system and what a great shop layout. I am envious.
Padre
posted 302 days ago
ND2ELK,
That is one NICE system. I like the look of the metal ducting. Was it significantly more $$ than the PVC?
I like your shop too…...the wainscoting is a touch of class.
Padre
posted 302 days ago
pitchnsplinters,
That does look like a cool system! Have you seen it in action?
View motthunter's profile
motthunter
2079 posts in 692 days
posted 302 days ago
I am cutting pipe and setting mine up over the next few weeks.. thanks for the ideas.
-- making sawdust....
25795 posts in 1293 days
posted 302 days ago
Very nice setup A great looking shop.
pitchnsplinters
posted 302 days ago
Padre,
I have one. I’m not using it at the moment as I am reestablishing my shop in a new space. Nice people to work with too (at Parks & parks that is).
View Sinister's profile
Sinister
18 posts in 363 days
posted 299 days ago
Hi Padre,
I’m looking to add a cyclone to my shop soon. I have low ceilings (~7’) that preclude clearvue as an option. I was considering the smallest Grizzly cyclone. I see you have some Grizzly tools, is there a reason you didn’t choose a Grizzly cyclone?
-- Patrick, Iowa City
Padre
posted 299 days ago
I went with the ClearVue because I liked the idea of it being made here in the US, that Bill Pentz gets a commission and everything I read about Ed and his great service.
I also looked at the Grizzly, but the cost was a lot more for a Grizzly 5hp unit.
View justsawin's profile
justsawin
4 posts in 306 days
posted 298 days ago
Thanks for he review! How is it from a noise perspective? I see the review says it is quiet, but can you compare it to other dust collectors (Oneida et al.?). Would it be comfortable to use for long periods on the lathe or at a downdraft table in the same room, for example?
Padre
posted 298 days ago
I have it inside my 2 1/2 car garage, and it’s loud. I wear ear muffs most of the time.
Quebecnewf
posted 297 days ago
Has any one had this unit shipped into Canada and if so what were the costs duty etc etc
Quebecnewf
CessnaPilotBarry
posted 297 days ago
Sinister…
“I’m looking to add a cyclone to my shop soon. I have low ceilings (~7’) that preclude clearvue as an option.”
I had the same problem and ended up with one of these.
After about 5 months of steady use, I’m extremely happy with the machine.
Quebecnewf
posted 297 days ago
Great looking system. All in one package no put together required. I wonder how this unit compares to the Clearvu dollar wise and performance wise. Any one have any thoughts??
Quebecnewf
Padre
posted 195 days ago
Day 108 Review
Man, I LOVE this cyclone. It will suck the chrome off’n a bumper. :) I have not had one, single problem with this unit. It starts every time, runs great, has great air movement, isn’t that loud, and works as advertised.
I really, really recommend this unit.
CessnaPilotBarry
posted 194 days ago
Glad to hear it still sucks!
