| Review by BTKS | posted 314 days ago | 2440 views | 2 times favorited | 37 comments | ![]() |
Hello Lumberjocks,
Just received and set up my new Steel City 10 inch cabinet saw with riving knives.
A couple other Steel City saws have been reviewed recently, I’ll try to limit myself to what I observed and try not to repeat too much of what the other guys had to say.
BOTTOM LINE UP FRONT: I love this saw. It was a major investment. I spent many months spread over several years researching cabinet saws. I’ve waited until I believe I won’t have to move this saw for the foreseeable future. A last minute read of riving knives in FineWoodworking lead me to checkout Steel City. This discovery slowed things down another couple of months. I’M GLAD I WAITED. I feel like I got top quality for several hundred dollars less. Not the cheapest out there, but I think they have everything the other brands have at a substantially lower price. It is not a bargain if it’s not worth having, these products are worth having. I also purchased the 14in Granite top bandsaw at the same time. More on this at the end of the review. The tablesaw works wonderfully and so smooth. It passed the nickel test with flying colors. See pics.
Packaging and Assembly:
Came intact with a steel cage around contents. Slick system, two bolts and the top comes off and the entire assembly is on a steel base. My saw had a small scratch on the motor cover door. Called the distributor asking for the color code. He contacted Steel City and they sent a small jar of touch up paint. I’ll make a plug for my distributor later in the review.
My suggestions for a smooth assembly: Preread the entire owner’s manual before anything else. The manual has clear directions with applicable pictures. Layout and inventory the parts then get started.
Use a four or perferably six foot level to set the wings. A dead-blow hammer is a big help but not an absolute necessity. The provided adjustment screws are a lifesaver. The screws will fine tune the wings before final tightening of the attachment bolts. The cosmoline on the parts is lightwieght and easy to remove. The riving knife factory adjustment is dead-on with my saw.
Saw comes with a good guard / splitter assembly with kickback pawls. Also includes two low profile riving knives. Both set below the top of the blade for non-through cuts, one for standard kerf and one for thin kerf.
Service:
I have not used the direct contact available with Steel City yet. I purchased my table saw and 14 inch bandsaw through American Grinding and Sales in Kansas City, Missouri. Rusty (the owner) has handled everything. They have been more than helpful. I don’t want this to be an advertisement for them but I really can’t say enough good at this point.
I called the Tech Dept for Steel City prior to my final decision to purchase this model. They were open to all my questions and answered with their experience and opinions. All other companies I spoke with would not make a statement or give a personal opinion about an option or detail of their machine. These guys believe in their product. I opted for the cast iron over granite simply because I can still use magnetic jigs and fences. I was concerned about the dog ears of the T-track chipping out. I like the steel top, I think the granite would be a lot easier to care for but the steel has been industry standard for about one or two hundred years. I’ll stay with tried and true for the work horse of the shop.
Fit and Finish:
Other reviews have covered the wrench hooks being too low, this is the case. One new screw hole and that’s fixed. I would prefer the hook be on the front and I’ll probably move it there later. Right now, on some magnets up front where they are easy to reach.
The top and wings are polished almost to a smooth finish. They have a texture to them that appears to be shallow marks parrallel to the miter grove. The fence, miter guage and material all move over the top extremely smooth. I don’t see this as a drawback. I’ve also treated everything with three coats of buffed out wax.
Both tops had a shallow dish. They were both dished out a couple of thousanths in the middle and dead even on both ends. You can feel the difference with a finger nail but it looks like a dark line when looking at the top.
The trunion moves so smooth. Spin the heavy adjustment wheels and they will keep spinning for a short while. If any play ever develops the dovetail ways for the trunion are adjustable for wear. Looking at the castings, this should be many many thousand trips up and down before any play develops. They were set perfectly upon arrival.
The factory 90 and 45 degree stops were dead on. Check the pictures. The stops were checked with a Wixey digital guage and came out to the tenth of a degree. I was impressed.
The rip fence is tough, solid and easy to adjust, if done in order with the directions. Pre-read the directions. I started into the set-up having used several fences. Needless to say, I backed up, read the directions and had no more difficulties.
The provided extension table provided with the 50 inch rip fence is thick and solid. A big plus, it is laminated on both sides to reduce humidty warping. I will probobaly replace it with a thicker board designed to be a router table. The nice heavy fence can do double duty for a second router table.
I got the mobile base with the saw because I’m still building the interior of my shop and have not set my final wiring diagram. I would not recommend it. I don’t have experience with mobile bases, but I would only use it if mobility is a must. I recommend setting the saw and leaving it in place. I’m going to shim mine so the saw does not shake everytime you touch it. The saw sets on corner braces inside the perimeter of the base but the base flexes allowing it to shake.
I got the tenon jig from steel city at the same time. This is the first time I’ve had a factory made tenon jig. I like it. It is similar to others I looked at but it has a quick, gross adustment and it is predrilled for left or right tilt saws. Looks like Steel City puts in the small details up front, no need for upgrades or special orders.
Oh yea, promised a note on the bandsaw. The saw comes with all the bells and whistles. Bearing guides, quick release tension etc. The saw is two speed, 1500 and 3000. Not going to get into a seperate review here. This ties the quality with service I’ve tried to convey in the above review. A packaging SNAFU resulted in receiving a 50100 (cast top) instead of the 50100G (granite top). My dealer (Rusty) American Grinding and Sales is trading out the top and fence on my next visit to the city. Apparently the cast version does not come with the fence, the granite does. He’s trading me even up and following up on any questions I have. I feel like I’ll be doing business with them for some time to come.
Hope this helps with anyone else out there trying to decide on a saw or a company for equipment.
BTKS.
37 comments so far
home | projects | blog
20740 posts in 719 days
posted 314 days ago
Nice review. I am planning on upgrading my saw sometime in the near future and have been considering the Steel City line. This review has been informative.
Woodchuck1957
950 posts in 661 days
posted 314 days ago
Nice saw, but it’s NOT a Cabinet saw, it’s a Hybrid.
hokieman
50 posts in 651 days
posted 314 days ago
If it is a 3 hp then it’s a cabinet saw. SC’s hybrids have smaller motors. I have an earlier 3 hp version of this saw without the riving knife with 50 rails and it is a cabinet saw. I hope that SC will offer a retrofit riving knife in the future, but I doubt it. Steel City makes some really nice stuff. I liive in Tennessee and I drove to Murfreesboro to their “showroom/warehouse” two years ago to see their stuff. They had one that was scratched and let me have it for a significant reduction in price. It was too good of a deal to turn down. Mine never passed the nickel test. I think that is due to the fact I put it on a mobile base. I really don’t care about the nickel test anyway. I am working wood, not nickels! I will be buying more of their stuff in the future. Thanks for the review on the bandsaw.
Beginningwoodworker
4207 posts in 570 days
posted 314 days ago
Thats a nice saw.
-- CJIII Future cabinetmaker
Woodchuck1957
posted 314 days ago
Hokie, hp doesn’t dictate weather it’s a cabinet saw or not, the trunions do. That saw has the lighter built cabinet mounted trunions, just like the 1.75 hp saw, which Steel City also calls a cabinet saw, which is bogus and misleading. It’s just like the Craftsman Hybrid. If you want a true cabinet saw from Steel City you have to buy one of their Deluxe cabinet saws, they have the beefy trunions that are found on real cabinet saws.
hokieman
posted 313 days ago
Sorrry but you are wrong woodchuck
Woodchuck1957
posted 313 days ago
Nope, Hokie, by your definition, if you put a 3 hp motor on a Contractor’s saw, it would then become a cabinet saw, I don’t think so. And yes, the trunions are cabinet mounted, but they are lighter duty than in a cabinet saw. Please stop missleading people into thinking that it’s something that it is not. It’s a Hybrid, wannabe cabinet saw, PERIOD. Which model number is yours ?
boyneskibum
58 posts in 367 days
posted 313 days ago
Hokieman, I just bought a similar saw last saturday. I’ve started to assemble it, but the -20 temperatures have kept me out of the shop most of the week. As far as I am in my assemblage, I agree with your assessment that this is a well built cabinet saw.
-- Let's make some firewood!
Woodchuck1957
posted 313 days ago
LOL, Boyne, you can’t say I didn’t warn ya. I explained all this to you in a different post, but you go ahead and do it anyway. Go figure. Aparently you didn’t check out the difference in the saws at the store like I suggested.
boyneskibum
posted 313 days ago
Woodchuck, his is model #35915 (At least that’s what he has posted in the title). Here are the vitals on that saw http://www.toolking.com/steelcity_35915.aspx
boyneskibum
posted 313 days ago
Let’s not hijack this thread, great review BTKS, I look forward to seeing your projects!
Woodchuck1957
posted 313 days ago
Yeah, whatever, goodluck with your new Hybrid, or wannabe cabinet saw, which ever you prefer.
BTKS
490 posts in 362 days
posted 313 days ago
Thank you to all that replied.
Oh yea, something I didn’t mention in the review. I cuts great even with the factory blade. Have not received the Forest II that was supposed to come with it for the sales promotion. I can’t imagine pushing enough wood through it to slow it down without running a huge risk on a massive kickback. A scenario I hope not to deal with.
I enjoyed the set up and hoped it gave someone out there a little help forming their opinion of the saws on the market.
Hokieman, you are so right, we are working wood not nickels. This saw is on a mobile base, but only for as long as it takes me to finalize my wiring and shop layout. You commented on retrofit riving knife. In the last of my research I saw some talk of someone retrofitting saws for riving knives. I’m not sure it can be done if a trunion pivots on a single point. All the saws I researched had sliding trunions for riving knives. Hopefully a safe affordable bracket can be mounted. The riving knife is a feature I really like and hope it saves a lot of fingers and pain for woodworkers everywhere.
Woodchuck1957, thanks for the input. Cabinet / Hybrid I don’t care. It’s heavy, solid and powerful. I like it.
Again, thaks for reading the review. Thought it was a good chance to throw my two cents in after reading so many everyone else has taken the time to post.
BTKS
SCOTSMAN
2244 posts in 482 days
posted 313 days ago
Is it just me or does it take it’s looks from a delta which a guy I know has.?Alistair
bentlyj
790 posts in 367 days
posted 313 days ago
It’s not you Scotsman. They look like delta because….
Founded in 2005, STEEL CITY is headquartered in Murfreesboro, TN, with satellite offices in Vancouver, BC; Mississaugua, ON; and Taichung, ROC.
Though we are a new company, our investment group, led by Scott Box and Mark Strahler have had long, distinguished careers in the machinery industry. Strahler was VP of sales and marketing for Delta before leaving to found Orion, a successful startup that manufactures machinery for Sears and other retailers. Box served as director of product development for Delta before leaving to head up the Powermatic division of the WMH Tool Group, owner of the Jet, Powermatic and Wilton brands.
CessnaPilotBarry
1286 posts in 600 days
posted 313 days ago
Nice review and nice saw!
I love the shot of the nickel…
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
brewtang
15 posts in 411 days
posted 313 days ago
I hate to point this out, but Woodchuck you proved yourself wrong in your second post. Cabinet saws have cabinet mounted trunions. Hybrid and contractor saws have table mounted trunions. Steel City saws may might be as heavy-duty as you seem to feel is necessary, but it is a cabinet saw. BTKS – congrats on the new saws…they make great machines…and speaking as a dealer, their customer service is top notch. Enjoy them both.
-- Billy, Jacksonville
bentlyj
posted 313 days ago
http://www.toolcrib.com/blog/2009/01/02/top-10-hybrid-table-saws-craftsman-vs-grizzly-vs-steel-city-vs-jet-and-more/
http://en.wikipedia.org/wiki/Table_saw#Hybrid_table_saws
Hybrid saws are a relatively new class of table saw introduced by DeWalt with its DW746 in 1999. Because of the vagueness of the term “hybrid,” they are also referred to as light-duty cabinet saws. Basically in between a contractor’s open stand saw and a shop-grade cabinet saw with all but the DeWalt using a fully enclosed cabinet. The hybridization is usually assumed to be the smaller contractor motor paired with a cabinet stand and internal motor mount; but more accurately, the true distinction is based on the trunnion design. Hybrid saws use contractor saw trunnion assemblies, which are built lighter and typically hang mounted from the bottom of the table versus the beefier cabinet saw trunnion assemblies, which are supported by the top of the cabinet itself. It’s true that all of the motors have moved inboard, but the Craftsman and Steel City designs are the only to use cabinet support with a contractor-style trunnion in this new class of saw, making them the only true candidates to be called light-duty cabinet saws. While interpretations of the class may vary between manufacturers, the price points on the machines we tested ran a tight range from $700 to $1,200 with most between $900 and $1,000. This is a 10-inch-blade saw that might be taken to a jobsite and set up for an extended time or used in a smaller woodworking shop.
Woodchuck1957
posted 313 days ago
Your wrong Brewtang, the Craftsman Hybrid ( which is made by the same company ( Orion ) that makes Steel City saws ) has cabinet mounted trunions. So out your theory goes. If you want to buy a Steel City saw that is a industry standard designed cabinet saw you will have to buy one of their DELUXE Cabinet saws. The rest are light duty Hybrids. Perhaps maybe one easy way of telling what you have is counting the number of V-belts, or drive belts your saw has. If it has less than 3 belts, it’s a Hybrid. Another way to tell is that large motor cover.
adam77
24 posts in 374 days
posted 313 days ago
Woodchuck is right, but its a really nice saw. Congrats
Woodchuck1957
posted 313 days ago
Thankyou Adam, it’s about time someone backed me up. It maybe a nice saw for what it is, I never contested that, but what gets to me is Steel City’s deceptive sales pitch. If it’s a Hybrid, call it a Hybrid, don’t call it something that it’s not, thats my point. People are being fooled into thinking that all of their table saws are cabinet saws. I wouldn’t be too happy if I bought one of those saws thinking it was a cabinet saw because the company said it was, then down the road someday find out that I was sold a Hybrid.
MedicKen
473 posts in 359 days
posted 313 days ago
It is just one of the “zip code” saws just like sears.After all built by the same company as earlier stated. I am looking at upgrading my hybrid crapsman in the next year and will be steering clear of the zip codes. As for me, will be powermatic. Nice review and I hope it perfoms well for you.
ericandcandi
84 posts in 415 days
posted 313 days ago
Ok Woodchuck, given this information what can I ” the customer ” do when talking to the sales rep about buying one of these saws?
-- ericandcandi, Louisiana- Home of the "LSU Tigers"
Woodchuck1957
posted 313 days ago
Eric, I guess I don’t understand your question, and which type of saw your looking for.
Brad_Nailor
1223 posts in 855 days
posted 313 days ago
BTKS nice, detailed review of the saw thanks for posting. Good luck with the saw it’s a really nice one.
I knew the minute I started to read this review that it wouldn’t be long before “Captain Trunnion, protector of cabinet saws, and fighter of all deceptive advertising” would chime in and declare it a non cabinet saw. Woodchuck you tap dance around semantics so much I think we are going to talk up a collection and buy you some tap shoes. But I shouldn’t say anything my “Jobsite” saw has already been smacked down. As usual you declare yourself the expert, and your information is right everyone else is wrong, and when anyone dares to disagree with you you dismiss them with a OK, ya whatever good luck with that piece of s* you bought with the Chinese trunnions. BTKS, It’s a good thing you included a picture of the saw, otherwise,,,you know….IT DIDN’T” HAPPEN! Actually, I have to admit that I get a big kick out of how amazed you are everytime nobody takes your advice!
But thats all I’m saying because I don’t want to ruin a good review or hijack his thread.
Woodchuck1957
posted 313 days ago
Brad, please say what you really mean. LMAO. Excuse me for trying to save some people from makeing an uniformed decision. Take a freakin Midol, or two, pleeeeeeeeease.
ericandcandi
posted 313 days ago
Woodchuck, if a salesman is trying to sell us a cabinet saw that is really not a cabinet saw what do you say to him. What do you say to the company that is preaching the false information. Also, what company out there is not practicing this technique?
Woodchuck1957
posted 312 days ago
Eric, I think it’s pretty obvious what I would say to the salesman, but thats just me. I guess if you want to debate something with the salesman you need to educate yourself as to what all is out there and compare it what your looking at to buy. I think I pointed out the major differences between the two saws allready. As far as what do I tell Steel City, allready did it about a week ago, and didn’t get a response back, that kind of suprises me, but then again it doesn’t. What other company is not practicing this technique ? I don’t know, I suspect there may be others, but that doesn’t make it right does it ?
pickles
63 posts in 310 days
posted 310 days ago
Your correct Woodchuck , Steel City does sell a beefed up “hybrid saw” or less stout cabinet saw; it is Model 35675, However, BTKS is reviewing this saw Model 35905 (NOTE 15 instead of 05 at the end of the model number designates the saw’s 50” fence instead of standard 30” fence) Look on steel city’s website it clearly shows two different trunnions on the respective saws. I purchased the model 35915G (granite) last week; I looked at both saws at Woodwerks in Columbus, OH. There is an obvious difference between the two as far as heft of construction. BTKS you indeed have a cabinet saw!
motthunter
2079 posts in 696 days
posted 310 days ago
you will love this saw. I hear that they are really great
-- making sawdust....
Woodchuck1957
posted 310 days ago
Sorry Pickles, your wrong also, they are both Hybrids. The ( 35618, 35630, 35640, 35623, 35621 ) are a more traditional style 10” cabinet saw that Steel City sells. Notice the difference in the motor cover and the massive trunion assembly with a 3 belt pulley compared to the saws you listed. http://www.steelcitytoolworks.com/products_tools.cfm?section=2&category=12&tool=35618
pickles
posted 310 days ago
No i beg to differ that saw’s trunnion is the old style sans riving knife. Per the new UL listing requirements all new saws manufactured have to have a riving knife. This saw has that riving knife attached to a substantial trunnion. The saw weighs ~450 lbs, has a wide ribbed flat belt, trunnion rigidly mounted to the CABINET. What else would better define a cabinet saw? In fact, when inspecting the two saws before buying I noticed that the “hybrid cabinet saw” had a visually smaller 3hp motor with single capacitor than the one that came with the above reviewed saw (the one I own). I also saw the Unisaw on display (not the all-new model) It’s trunnion appeared no larger or heftirer than that on the 35915. I included the Unisaw among my options and found this saw to be a better product and just as capable. Hand wheels operated smoother and fit and finisher was better. I rest
Woodchuck1957
posted 310 days ago
Traditional cabinet saws do not run on a single belt, and a riving knife has nothing to do with what type of saw it is. Sorry, but I’m done debateing this subject with people that will never get it. You don’t know what your talking about.
juniorjock
790 posts in 663 days
posted 310 days ago
Promise?
- JJ
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
Brad_Nailor
posted 310 days ago
”Sorry, but I’m done debateing this subject with people that will never get it”.
Too bad you didn’t come to that conclusion about five posts ago before you hijacked this thread with your childish insistence that you are the only one that knows anything about table saws…and, quite frankly…how is this a debate? A debate is an intelligent exchange of ideas, not somebody insisting he is right and everyone else is wrong..
”You don’t know what your talking about”.
Ya…nobody knows anything but you..
If we all promise to tell you your right, will you just shut the hell up already….
Woodchuck1957
posted 310 days ago
Well thankyou JJ and Brad, you have a wonderful day.
Adventurer
66 posts in 492 days
posted 307 days ago
woodchuck I believe you have a point and you want to make it clear thank you for clearing this issue to me.
