| Review by motthunter | posted 317 days ago | 907 views | 1 time favorited | 20 comments | ![]() |
- McFeeley Square Drive Screws
- Brand: McFeeley | Category: Other
No matter how many years I have been driving screws into wood, I still end up stripping the heads every once in a while and or slipping off with my power driver and foolishly marring the wood in a project.
I switched to square drive screws and I have not made a goof like this in ages. I first started using them in pocket hole joinery, but now I use them for everything. There are several sources for these screws but I get mine from McFeeley’s. They have a good selection and prices are good. Just remember to also order the bits to drive them. Usually, the drivers get thrown in when you get a variety pack.
The first time I ordered, I decided to call rather than place a net order so that I could gain confidence in who I was dealing with. The guys who answer their phones are fastener gurus. I was extremely impressed. Nice to see that someone has a call center in the US these days
You can get cheaper screws, but square heads save so much time and prevent screw ups that can ruin a project.
-- making sawdust....
20 comments so far
home | projects | blog
3046 posts in 918 days
posted 317 days ago
The head style you are refering to was originally patented and manufacured by a guy named Robertson here in Canada.
The history of the screw is convoluted with the second world war and some bad judgment on behalf of the US congress when choosing a head for factories during the war. ( hences the proliferation of the god awful philips head)
The best square heads are still made by Roberston and their screws fit the heads so accurately that they can be driven with one hand.
Of the newer additions to the square design I really like the Spax style sold at Lee Valley that conbines both square and philips style togerher with a new design screw body that cuts into the wood much easier.
Why do I know all this trivia? ;-)
As an aside, my cousin made living in the Arizona are peddling Robertsons and screws to electrical contractors 30 years ago.
They had never seen them and went nuts.
motthunter
2079 posts in 695 days
posted 317 days ago
I had hears that they were originally made in Canada.. I wasn’t sure that this was true since I can’t figure out what you use screws for int he production of head cheese and back bacon.. ha ha.
Thanks for the trivia above. It was interesting. I also am no fan of the Phillips head. I guess that I need to thank a Canadian next time I use a screw.
dennis mitchell
3791 posts in 1211 days
posted 317 days ago
The idea of having to use a Phillips head Grabber screw makes me shiver. I’m a big fan of the square head screws.
posted 317 days ago
I used a whole bunch of these last year and they are now on my shortlist.
They drive twice as easy as regular screws and pull the boards down with the larger finer tap on the head end.
ChesapeakeBob
96 posts in 380 days
posted 317 days ago
I had a long career in hardware. I’m so old, I can remember when only slotted screws were sold and people would absolutely refuse Phillips head screws. Phillips really got going in the mid 1970’s.
-- Chesapeake Bob, Southern Maryland
posted 317 days ago
Seems to my recollection that they took off when the steel stud/drywall construction method became so popular for office construction.
Does that ring a bell with you too Bob?
CessnaPilotBarry
1285 posts in 599 days
posted 317 days ago
Square drives are my favorites, too!
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
posted 317 days ago
This one makes me pretty happy for case work with MDF.
matter
209 posts in 666 days
posted 316 days ago
The only place for Philips heads is in drywall. Their inate ability to cam out on high torque lead to the invention of the drywall gun. I tried to swap tips in a drywall gun for robbies to use on decks, but they just won’t cam out before they are set 1/4” below the surface
-- The only easy wood project is a fire
kalynzoo
5 posts in 324 days
posted 316 days ago
I’ve been using square heads for years, never stripped the head.
-- Gary Kalyn, Kalynzoo Productions
Microsuffer
23 posts in 461 days
posted 315 days ago
An interesting education on the subject. Wouldn’t have considered squares without reading this. Thanks.
-- "Those are my principals, if you don't like them....I have others." - Groucho Marx
motthunter
posted 314 days ago
who knew that so many would be interested in such a screwy topic?
firecaster
482 posts in 315 days
posted 314 days ago
A hardware store was my first real job at 16. Worked there until my 30s. I remember when we sold drivers for something called Robertson screws but had never seen a Robertson screw.
We also had a much larger selection of slotted screws than phillips.
-- Father of two sons. Both Eagle Scouts.
Nic
43 posts in 369 days
posted 313 days ago
i am in agreement with the square drive screws. Started using them with Kregs pocket hole and now use them for everything. The Re-usability is another great factor.
25803 posts in 1297 days
posted 313 days ago
I remember growing up in Canada and Dad have a wall rack with Robertson Screw Drivers. But he never had the screws. Go figure.
Built2Last
103 posts in 374 days
posted 310 days ago
I built swings for a living before I retired and still build quite a few. I use square drive most of the time and torx when I find a special on them. I have found that people will blame the screw most of the time when they have problems with the rounding out (square drive) when most of the time it’s the bit that causes the problem. Even so called good bits will do this sometimes, so the first thing I do with a bit is either take a fine file or a diamond sharpner and make sure the bit is the same size from the tip to the main body. This will allow the bit to go futher into the screw head most on the time. I usually use Micro-Brite 500 screws, ( I have been finding them a lot latley on e-bay). By taking a couple of minutes with a file I can usually build 10 or more swings with the same bit and never have a problem.
-- BUILT TO LAST WOODWORKS, West Blocton, Alabama
posted 310 days ago
Good tip .Something I had not considered before.
When old man Robertson owned the factory every bit fit every screw he made.
That quality control dosen’t exist now however.
Matt
178 posts in 269 days
posted 266 days ago
I just started using square head screws recently when I purchased the Kreg pocket hole system. I love these things. I will never use anything else. Since it seems you always have to buy a new tool (or two) to support the new tool, I had to get a new driver. I was using my Hitachi VS drill and did split out some wood because I couldn’t stop the drill in time. I picked up a Hitachi 10.8 Lithium-Ion driver and never looked back. I needed something with clutch so I could dial down the torque. I usually use some scrap wood of the same type I’m building with to help me ‘sneak up’ on the clutch setting. Then I’m usually good. A clutch will save you a world of headaches.
Lots of the larger driver bit sets have torx and square drivers in them now. I picked up a nice set at Lowes that had them.
I’m sold on these things. Like I said, I probably will never use anything else. Kreg, you have shown me the way!
-- Matt - My Websites - http://www.bestinwood.com - Hand Tools :: http://www.workshopgarage.com - Small Shops
Dick, & Barb Cain
7041 posts in 1196 days
posted 266 days ago
I got to love the square head when I got my Kreg pocket rocket.
You can really go through a lot of screws when you use a Kreg.
I found a that Grizzly has the best price for the face frame screws.
toyguy
724 posts in 734 days
posted 266 days ago
If Robertsons are not available to me when I go out to buy screws, I just go somewhere else. I have been using Robertson for as long as I have been playing around with wood.
Here in Canada, most guys are aware of the Robertson story. I never could understand why they never caught on in the states.
