Freud router bit broke into 3 pieces.
Review by Julian posted 06-25-2015 10:06 PM 5159 views 0 times favorited 23 comments Add to Favorites Watch
Freud router bit broke into 3 pieces. No-picture-s No-picture-s Click the pictures to enlarge them
I used this 3/8” up spiral bit for over a year when making mortises for a gate (in redwood).
This bit did not get used very much. Supposedly it is solid carbide.
Recently I was routing slots for a jig in a medium dense wood using my router table.
When I was nearly finished I heard a bang and discovered the bit broke into 3 pieces.
These router bits are not cheap; over $50. I emailed Freud twice on from their website about this
and to find out if they warranty the bits. No response after 3 days. Very poor customer service.
My new spiral bit will be from Whiteside. No more Freud router bits.
The reason I gave 3 stars is because the router bit worked well until it broke.
-- Julian
View Julian's profile
Julian
1434 posts in 2929 days
23 comments so far
View QuangFromCalgary's profile
QuangFromCalgary
35 posts in 3237 days
#1 posted 06-26-2015 02:04 AM
Yes, it happened to me before but not that expensive bit. I have never bought freud bit since then. I think they have problems with quality control.
View rustfever's profile
rustfever
763 posts in 3549 days
#2 posted 06-26-2015 02:22 AM
I have a Freud 1/2” d router bit that warped. Yes, it is our of round. I used it once for less than 60 seconds.
Message to Freud: Good-Bye
-- Rustfever, Central California
View philba's profile
philba
96 posts in 1611 days
#3 posted 06-26-2015 05:55 AM
solid carbide is very fragile. I broke one just by pushing it a little too hard. don’t blame Freud – it’s the nature of solid carbide bits.
runswithscissors
2928 posts in 2264 days
#4 posted 06-26-2015 07:19 AM
Grizzly has a warning over their solid carbide bits that they are brittle, and I believe they don’t guarantee them from breakage.
View robscastle's profile
robscastle
5632 posts in 2443 days
#5 posted 06-26-2015 09:09 AM
Hi there Julian,
Welcome to the club !! a box of Kneenex is in the mail!!
The short reply:-
Go buy another one and get on with it!
The longer reply:- for what is worth,
Router bits regardless of their cost are considered consumable by the supplier and usually only have a warranty against defects only.
Misuse and wear and tear are not covered.
From my experience breakages usually occur from the bit being subject to a shock.
This can be in a forms.
Chattering
When Chattering occurs its usually all over quickly and too late for the bit epecially if its a small one, 3mm or there abouts,
Impact shock.
The bit may have also been dropped before use.
The bit may have hit a FO or knot within the timber. good night the fox!
Carbide is very fragile and does not like being flexed (philba)
Could even be metal fatigue
As you have not posted any of the gory details its hard to determine just exactly what has happened.
Post Mortem ( if you want to waste more time)
Find the three pieces and examine them, use a magnifying device if required it may reveal something, apart from the fact its broken.
However I can tell you to have a 3/8 bit break and break into three pieces something serious must have happened.
otherwise an echo….Go buy another one and get on with it!
To add insult to injury I dont think Freud are in business any more!
-- Regards Rob
View AaronK's profile
AaronK
1507 posts in 3703 days
#6 posted 06-26-2015 10:39 AM
I had an issue with my freud router and customer service was very responsive. My suggestion is to call them on the phone. Email can be touchy and there’s no guarantee that someone even gets the email (maybe a bug in a program somewhere!).
View abie's profile
abie
880 posts in 4010 days
#7 posted 06-26-2015 03:22 PM
Also Check out Unsrud bits (SP)
-- Bruce. a mind is like a book it is only useful when open.
View Manitario's profile
Manitario
2705 posts in 3122 days
#8 posted 06-26-2015 03:59 PM
I’ve broken several of my solid carbide bits. Carbide is extremely hard (so it stay sharp for a long time) but very brittle. Too deep a cut, too fast a feed speed or just wear and tear and the bit will break.
View abie's profile
abie
#9 posted 06-26-2015 04:23 PM
Onsrud router bits spelling incorrect in previous post.
16281 posts in 4457 days
#10 posted 06-27-2015 12:27 AM
Ditto what others have said about carbide bits being brittle and easy to break.
View michelletwo's profile
michelletwo
2773 posts in 3255 days
#11 posted 06-27-2015 12:57 PM
the rule of depth of cut= bit diam does not hold true with carbide..stressing with too deep a cut or trying to cut too fast will break them most times..it is brittle stuff
View timbertailor's profile
timbertailor
1594 posts in 1663 days
#12 posted 06-28-2015 03:48 PM
solid carbide is very fragile. I broke one just by pushing it a little too hard. don t blame Freud – it s the nature of solid carbide bits.
- philba
AMEN. The nature of any solid carbide bit. Be gentle with them. I use the downcut spiral bits on laminates ALL the time. Works great with no tear out or chipping.
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#13 posted 06-29-2015 08:02 AM
Freud took 4-5 working days to get reply to my emails.
View Redoak49's profile
Redoak49
3742 posts in 2227 days
#14 posted 06-29-2015 09:23 PM
Best way to break a router bit up s by taking to big of a cut or too heavy a cut. I have broken some and my fault.
My experience with Freud is pretty high quality stuff.
Take a high quality picture of fracture faces and post them. One can see if there was a defect present or was overload.
View SapDruide's profile
SapDruide
4 posts in 1301 days
#15 posted 06-29-2015 09:56 PM
Hey, I do agree with Redoak49, I also had a great experience with Freud, the quality is truly something they care about.
showing 1 through 15 of 23 comments
