BOSCH Glide Saw, Up For Review
Review by woodshopmike posted 06-18-2015 07:13 PM 8566 views 0 times favorited 15 comments Add to Favorites Watch
BOSCH Glide Saw, Up For Review No-picture-s No-picture-s Click the pictures to enlarge them
The BOSCH GCM12SD dual bevel glide saw is a remarkable tool that takes accuracy and ease of use to a new level. Now that I’ve completely let the cat out of the bag that I like this tool, lets see why.
The most obvious features are the upfront controls and the super smooooooth axial glide that BOSCH has engineered and patented. These upfront controls not only allow for rotating the table, but also make it possible to tilt the blade left to right. Yes, that means you no longer have to reach to the back of the saw for anything! Now…these controls seem totally weird at first. When I saw this for the first time, I was scratching my head and really didn’t know what to do, but it now makes so much sense! The bevel lock lever on the left, along with a selector knob allows for the blade to be tilted. The controls out in front allow for the table to rotate and either stop at common angles or for you to override those common angle detents.
Read the full review on my blog: http://woodshopmike.com/bosch-glide-saw-up-for-review
-- www.woodshopmike.com, www.woodshopmikestudio.etsy.com
View woodshopmike's profile
woodshopmike
226 posts in 1688 days
15 comments so far
View doubleDD's profile
doubleDD
7437 posts in 2068 days
#1 posted 06-19-2015 03:17 AM
I used this saw briefly while helping a friend build a deck. I agree it being a top notch piece of equipment.
View ellen35's profile
ellen35
2738 posts in 3457 days
#2 posted 06-19-2015 11:28 AM
I reviewed this several years ago… still love mine.
View RPhillips's profile
RPhillips
1182 posts in 1861 days
#3 posted 06-20-2015 12:17 AM
Lol, I just recommended this saw on another LJ thread just prior to your posting…
Heard nothing but great things about it….especially the accuracy. The movement is very fluid too. I have used one in Rockler… very nice saw. Congrats.
-- Rob - Indianapolis IN - Learning... one mistake at a time...
woodshopmike
#4 posted 06-22-2015 02:17 PM
This really is an awesome saw, I couldn’t be more happy with it. Glad to hear y’all echoing the high praise!
View Drew's profile
Drew
350 posts in 3125 days
#5 posted 06-22-2015 09:39 PM
I do not understand why people like this saw so much.
IMO this is one of the least accurate saws made! All the weight of that huge head and motor assembly hanging way out there causes that thing to flex all over the place. Most sliders suffer, 12”ers are bad…. this one is the worst!
I hear so many great things about this saw and I just scratch my head.
If you need huge crosscut capacity without the need for a quality cut, than this is a good saw. If you need staright, flat bevels, I would stay away!
-- TruCraftFurniture.com
View dawsonbob's profile
dawsonbob
2884 posts in 1780 days
#6 posted 06-22-2015 09:57 PM
How odd that you think this saw is of poor quality, when people who actually use this saw think it’s absolutely top notch. Could it be that you tried one that wasn’t put together properly, or could it be something else?
-- Mistakes are what pave the road to perfection
View Drew's profile
Drew
#7 posted 06-22-2015 10:11 PM
People that actually use the saw???? Have you used one?
I have made thousands of cuts with that saw. I guarantee I have used one to brake down material for over a thousand table tops over the last 3-4 years. Hundreds of Starbucks across this country have had their table tops built by me. Almost all of which I broke down with this saw.
When I need to make accurate cross cuts I turn to my Milwaukee 12” non-slider or the cross cut sled. If I have to try to make a decent cut on a slider I use my Makita 1013.
BTW, I never said anything about the quality of the saw.
dawsonbob
#8 posted 06-22-2015 11:56 PM
Yes, I have used the saw, but only briefly. It worked fine for me, but it sounds like you have a lot more experience than I do, and in any event your opinion is your own.
Calling the saw inaccurate pretty much speaks to the quality of the saw, doesn’t it? If it doesn’t do what it is supposed to do — make accurate cuts — then it cannot be considered a high quality tool, no matter how well it’s constructed.
woodshopmike
#9 posted 06-23-2015 01:27 PM
It’s really interesting that you’ve seen poor accuracy out of this saw. I’m not arguing or doubting that, just surprised that’s all. I don’t mean to insult either, but did you setup the saw once you received it?
I had to adjust the stops for 0 & 90 in the head & place a .005” shim behind one of the fences to bring everything to true. In my opinion those setup items are pretty standard with tools and to be expected. Once everything was dialed in, the saw has performed quite well. I know the “glide bearings” can be adjusted on this saw, yours could be too loose and decreasing the accuracy of cut.
Every now and then a lemon is going to make it through QC so perhaps you got one if your saw is as bad as it sounds.
I’d be interested if you went through those setup steps that I went through. Also, what kind of inaccuracies are you seeing? Is the head leading off in a cut, is the blade square to the fence when the head is locked to the far back and down position, if you put a dial indicator on the blade and rotate by hand is there run out in the arbor? This may all be more than you care to go into which is fine but here again, just curious to know what kind of issues exactly you have since there are multiple reasons for inaccuracy.
Obviously you know what you’re needing in an accurate cut if you’re using multiple methods to attain it.
View Drew's profile
Drew
#10 posted 06-23-2015 08:33 PM
You remind me of my wife
Calling the saw inaccurate pretty much speaks to the quality of the saw, doesn t it? If it doesn t do what it is supposed to do — make accurate cuts — then it cannot be considered a high quality tool, no matter how well it s constructed.
- dawsonbob
View Drew's profile
Drew
#11 posted 06-23-2015 08:46 PM
It s really interesting that you ve seen poor accuracy out of this saw. I m not arguing or doubting that, just surprised that s all. I don t mean to insult either, but did you setup the saw once you received it?
... Also, what kind of inaccuracies are you seeing? ....This may all be more than you care to go into which is fine but here again, just curious to know what kind of issues exactly you have since there are multiple reasons for inaccuracy.
Obviously you know what you re needing in an accurate cut if you re using multiple methods to attain it.
- woodshopmike
This saw, as with every 12” slider I have used (which is most), has a lot of deflection in the head. This saw worse than any I have used.
There is just to much weight, to far out, for it to stay solid.
I challenge any owner of this saw to pull the slider all the way forward and put slight pressure left and right on it. It will move 1/16”+ very easily! Even more so with greater pressure. You might not think that this comes into play in real world usage but it certainly does.
Now bevel it to 45 degrees, slide it forward again and see how much it moves now. It moves all over the place! Absolutely unusable with any degree of accuracy.
I scratch my head when I hear people talk about how great this saw is
ellen35
#12 posted 07-23-2015 07:03 PM
ellen35
#13 posted 07-23-2015 07:05 PM
Just a note… this saw was reviewed and chosen as Best Tool of the Year in the Fine Woodworking 2012 Tool Guide. While I don’t drink the Kool Aid, I do think they put the tools they select through a thorough battery of tests and hard use before selecting them. Fine Woodworking is no Dick and Jane Cut Wood publication.
Additionally, I pulled my saw to it’s maximum 12 inches and it was dead on. I cut some wider stock and the stock was absolutely square using my Starrett combination square.
I think anyone can find fault with any tool but I use this almost daily and have never had a problem with it. As someone upthread said, maybe a lemon or two get through QC.
I refer anyone to my previous review and all the good things that were said about this saw in response to that review.
View 14999's profile
14999
3 posts in 151 days
#14 posted 01-21-2018 04:21 AM
- Drew
I totally agree with you. This saw cannot make a flawless crosscut no matter how hard I try keeping my arm steady with even pressure on the vertical. I own both the Bosch cm10gd and the Dewalt Dws780. There is a noticeable difference in cut quality in Dewalts favor.
14999
3 posts in 151 days
#15 posted 01-21-2018 04:32 AM
- Drew
The Bosch cm10gd cannot make a straight crosscut no matter how hard I try. I own both the Bosch cm10gd and the Dewalt Dws780. There is a noticeable difference in cut quality in Dewalts favor.
- dawsonbob
I have the privilege of comparing both the Bosch 10” glide (cm10gd) and the Dewalt dws780 side by side and the Dewalt dws780 hands down blows the Bosch glide out of the water in cut quality.
