Very happy but with a bit of drama of course
Review by PeteMoss posted 328 days ago 2270 views 1 time favorited 23 comments Add to Favorites Watch
Very happy but with a bit of drama of course Very happy but with a bit of drama of course Very happy but with a bit of drama of course Click the pictures to enlarge them
Saw Overview:
Well, I decided it was time to purchase a new tablesaw. After quite a bit of research, budgeting, and window shopping I decided to go with the Steel City granite top saw. Since I only have 120 VAC power, I went with the 1.75 HP version. I have called Steel City several time and received excellent customer service as you will see as this review continues. Anyway, I asked Steel City if there were any structural differences between the 1.75 and 3 HP models and was told that they are identical and that if I ever got a shop with 220V power that I could convert it to a 3 HP model if I wanted to by swapping the motor and pulleys. I also decided to go with the 30-inch fence due to space limitations. In fact, even the 30-inch model was much bigger in my garage than I thought it would be.
Ordering and Delivery:
I ordered this saw from my local Woodcraft store. The item is shipped to the store for free and then you pick it up there. I also ordered a Steel City brand mobile base for it. They also had a special deal going on where if you buy any of their riving knife models in December you get a free Forrest Woodworkder II blade and “tiny” bottle of Empire Bladesaver with it. It took about 10 days for the saw to come in. My intention was to get it home and uncrate the saw in the bed of my truck. Then I, along with some help could set it on the mobile base, roll it in the garage, and assemble it. Well, my mobile base didn’t come in with the saw. It would take another week and a half for it to come in. Of course I couldn’t stand to wait that long and took the saw home, uncrated it in the bed of the truck. Had help lowering it to the ground and moving it to the garage. I then assembled it the next day. Unfortunatly, I had to get help over again to get it up on the mobile base once it finally came in.
Assembly:
This saw was pretty heavy in its crate, around 420 lbs. I think. Speaking of the crate, this was by far the best job of packaging I have ever seen. Each item was wrapped in plastic with cardboard padding where needed. All of those items were wrapped together. The saw was bolded down to a metal “pallet” and a metal cage bolted down to it. So in essense the entire thing was surrounded by a metal cage. Needless to say, it arrived without damage.
The instruction manual was pretty good. It pretty well matched what you actually needed to do to assemble the saw. There were a few pieces that it said to assemble that were already assembled. There were also a few adjustments that it said were set at the factory but I had to adjust on mine. On one adjustment in particular, the arbor gib adjustment, the manual tells you how to perfom it, but not what it does or why you would want to adjust it. I assume mine doesn’t need adjustment. Another thing that the manual doesn’t explain is that the saw comes with 2 short riving knives and the full height one with the see-through plastic guard on it, but it doen’t mention it. You have to sort of figure out there different usages and that one riving knife is for a regular blade and the other is apparently for a thin-kerf blade.
Anyway, I installed the handwheels and motor belt with no problem. Checking the alignment of the motor pully to the arbor pulley was very difficult. In the third picture you can see the motor pulley has a metal piece which extends past the pulley part. There is no such extension on the arbor pulley, so, you have to put your straight edge on the back of the pulleys to check the alignment, but of course you can see the backs. I finally gave up and hoped for the best. Installing the granite extension wing was a pain. They do give you two bars that hold the wing up and which have four set screws so you can pre-level it to the main tabletop. The problem is that when you actually bold it in place the height changes every flippin time. This took well over an hour to get it dead level even though it was adjusted level with the set screws in the bars. Luckily they were there though, I can’t imagine having to lift this thing in place and bolt it level without them. The throat plate installed easily and levels with four set screws. The riving knife goes on and off very easly with about a half turn of metal knob. However, one of the factory adjustments that you shouldn’t have to change is the riving knife to blade alignment. Mine was off and was a total pain to get lined up correctly. You have to take the blade off to loosen the screws to move the riving knife. Then put it back on to try and line it up. Take it back off to tighten the screws. Put it back on to see if it is still lined up, etc. EVERY other adjustment was dead on: miter slot to blade alignment, all 90 and 45 degree stops on the blade and on the miter guage.
The Fence:
This saw come with what they call an Industrial II fence, which seems to be just like the Industrial fence except that the two pads and screws on the front that keep the fence from racking when you slide it are set further out to the left and right, I assume to give it more leverage to miimize the afforementioned racking.
The fence was assembled and adjusted exactly like the manual said with no issues whatsoever.
One Quick “Weird” Problem:
I installed my Forrest Woodworker II blade that came free with the saw and to my dissapointment found that the blade would not slide all the way up agains the arbor flange but stopped about the thickness of a business card away. If I tighened the arbor nut, it appeared to push it up over a slight flairing in the shaft right at the flange. But it didn’t it actually bowed the entire surface of the blade slightly as checked with a straight edge. So, I tried it with the Steel City brand blade. It fit just fine. You could tell the FWW II blade fit the arbor more tightly and was apparently just tight enough not to be able to get over that little flairing at the arbor flange. So, I called Steel City and explained the situation. They got a tech on the phone for me and he said that the arbor and flage are on machined piece and that they leave the little flairing on there for strength and that the FWW II blade’s arbor hole was to tighter tolerences he guesses and wouldn’t snug up over it. So, what he said to do and what I did and what worked in fact was this, even though it totally freaked me out. He had me remove the blade and arbor nut and washer. Rasise it all the way up and turn the machine on. Then take a bastard file and use it as though it were a scraper on a lathe to remove that slightly flaird area on the arbor shaft. Now both blades and my dado set fit just fine.
Usage and Impressions:
First off let me say that I have zero experience with a cabinet saw or even a good contractor saw, so please take my two cents with a grain of salt. The saw seems to be quite sturdy. The cabinet is thick and heavy. The granite is stupid heavy, solid, and flat. Fit and finish are quite decent, not exactly polished, but pretty good. I don’t know squat about trunions to know good from bad. I do know that they are cabinet mounted and that they have to be differnt to work with a riving knife so that the blade goes straight up and down, but that is the best I can do. Picture two above shows the saw insides befor the blade or motor belt was installed. There is no belt tensioner on the belt relying only on the weight of the motor, but the TEFC motor is heavy. It seems to weigh about the same as my entire benchtop tablesaw. The fence slide easily and locks solidly. There is a tiny bit of deflection in the far end if you push hard on it but I don’t think it would ever be an issue in any kind of regular use.
In using the saw it seems to be plenty powerful and I have yet to cut anything that seemed to tax it in anyway. All cuts have been acurate. The motor is smoot and purrs along nicely. I don’t have a dust collector, I just let it fall inside and sweep it out the back, so I can’t comment on dust collection efficency.
A couple of usage complains are that the hook where you hang the blade wrenches is too close to the brackets where you store the fence. So you can’t put the fence into it’s storage place with out the wrenches getting in the way. Also there is no where to store the mitre guage. The power switch is not magnetic. It seems to me that this would be even more important on a 120 V machine where the user is more likely to plug it into a non-dedicated circuit and kick the breaker.
That’s all I can think of at the moment, but I’m sure I have forgotten things. Please let me know if you have any questions.
-- "Never measure......cut as needed." - PeteMoss
View PeteMoss's profile
PeteMoss
63 posts in 370 days
23 comments so far
View Woodchuck1957's profile
Woodchuck1957
950 posts in 663 days
posted 328 days ago
I would recommend you put it on a dedicated circuit, whatever your motor spec plate shows, not just because of the non magnetic switch, but because the motor needs the dedicated power.
View boyneskibum's profile
boyneskibum
58 posts in 369 days
posted 328 days ago
Great review! Thank you!
-- Let's make some firewood!
Beginningwoodworker
4233 posts in 572 days
posted 328 days ago
Congrats man on your new tool!
-- CJIII Future cabinetmaker
20807 posts in 721 days
posted 327 days ago
Pete, this is a nice review and congratulations on getting such a quality tool.
View Rob Drown's profile
Rob Drown
324 posts in 732 days
posted 327 days ago
Well written and clear.
CONGRATULATIONS AND MERRY CHRISTMAS !!!!
-- Sharp tools and thin whispy shavings make woodworking a joy.
PeteMoss
posted 327 days ago
Thanks everyone. I’ve enjoyed it so far. I’ve been working on a simple outfeed table for it. I hope to have that finished soon so I can start working on something to make my wife happy. I sure hope it looks better than this outfeed table. :)
View RichClark's profile
RichClark
73 posts in 330 days
posted 327 days ago
Pete, Nice review, I set my SC 35913 – 10” a few weeks ago with a very similar experience to yours.
I have the 3HP 240 version. The only issue I had was the Miter Gauge handle’s shaft to lock it to the gauge was bent
from the factory and I called their customer service and had one the next day.
I have a SC 64200 DC 1.5 HP 120V. And it works well with the saw.
Enjoy it
Rich
-- Duct Tape is the Force! It has a light side and a dark side and it Binds the Universe together!
View Neodogg's profile
Neodogg
89 posts in 327 days
posted 327 days ago
very nice review, I was curious about the granite tops
-- If you can't fix it with a hammer, you've got an electrical problem!
View TomK 's profile
TomK
504 posts in 774 days
posted 326 days ago
Thanks for the excellent review.
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
View Routerisstillmyname's profile
Routerisstillmyname
116 posts in 408 days
posted 326 days ago
No need to worry about rust and warping anymore.
Ridgids new table saw has granite top and table mounted trunions but they shortened the cut capacity.
Nice review.
-- Router รจ ancora il mio nome.
View BarryW's profile
BarryW
872 posts in 806 days
posted 326 days ago
I’m drooling…which means I better stay away from your saw or it’ll rust…sweeet.
-- /\/\/\ BarryW /\/\/\ Stay so busy you don't have time to die.
View Huckleberry's profile
Huckleberry
140 posts in 752 days
posted 326 days ago
Like the review this is the saw (3hp) that I am planning on buying this month. It’s nice to hear of the problems and such that you had with the blade as that is the same blade that I will be using. Thanks a lot for the time that you put into this.
-- Something that goes unnoticed will never be remembered.
Woodchuck1957
posted 325 days ago
Steel City has a tendancy to call their hybrid saws, cabinet saws, kind of misleading if you ask me.
View davetermite's profile
davetermite
8 posts in 326 days
posted 325 days ago
I bought one of these saws about 2 months ago and am very happy with it. My only problem with the saw when it was delivered was that one of the holes that the rear rail screws into had mangled threads which I had to tap out myself. However, Steel City customer service was extremely helpful. With the 1.75 HP motor it does slow down a little on hard, heavy wood. I just cut some 3” Honduran Rosewood and had to feed it very slowly. Hard to whine too much about that.
View woodworm's profile
woodworm
8309 posts in 490 days
posted 324 days ago
Great reviews.
Beside Steel City Granite Top, I’m a fan of PM 2000 too.
-- masrol, kuala lumpur, MY.
View Big_Bob's profile
Big_Bob
97 posts in 608 days
posted 324 days ago
Pete:
Great review! Just the from experiences I have had and obviously for future reference. If you can run you tools on 220v it is worth the money to add a 220v circuit to your shop. You will never regret it. Your tools run stronger at lower amperage. You have greater options in tools that you can add to your shop and you never need to buy a tool that has less power than you would like because you only have 115v.
Regards
-- Bob Clark, Tool Collector and Sawdust Maker
View OrangeMan's profile
OrangeMan
3 posts in 303 days
posted 303 days ago
” the saw comes with 2 short riving knives and the full height one with the see-through plastic guard on it “
So does it come with a total of 3 riving knives?
Is the full height one for a regular kerf blade?
I’m interested because my Ridgid R4511 is made by Steel City and it seems to be lacking the full height riving knife. I’m wondering if I could order one from Steel City and it would fit.
Thanks,
Ron
-- "It's easy after you know how to do it" Ron - Aurora, CO
PeteMoss
posted 303 days ago
Hey Ron,
Yes, it came with the 2 short riving kives which sit slightly below the height of the blade, one full kerf and one thin kerf. It also came with one full height “splitter” type assembly, which is the full height one with the attached guard and spring loaded pawls. It is full kerf width.
The images below may be too big and require you to click on them to see the whole thing.
Below is the thin kerf knife.
Thin kerf knife
This is the full splitter assembly.
Full height splitter assembly
You can see what the socket on them look like from the photos to see if they look like they will match your saw. Below is a photo of what the clamp looks like in the saw that you attach the knife into.
Knife clamping thingy-do
Good luck! I hope it works out for you.
OrangeMan
3 posts in 303 days
posted 303 days ago
PeteMoss,
Thanks a lot for the information. And the pics are GREAT! Just what I needed.
Ron
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 485 days
posted 302 days ago
A great new saw well done. I like the shorter riving knives and have set mine deliberately a mm or two below the cutting through height to anable me to use the saw for doing grooves with it.Alistair
View RaiD's profile
RaiD
2 posts in 27 days
posted 25 days ago
OrangeMan – did you find out if the Steel City riving knife will fit the Ridgid R4511? Thanks!
—Ryan
17168 posts in 476 days
posted 25 days ago
Good review enjoy your new toy.
OrangeMan
3 posts in 303 days
posted 24 days ago
Ryan,
They didn’t fit perfectly. I had to grind off some of the shoulders on the knife to let it slide down further into the slot. Also the thick one to be a bit too thick. I have to loosen the 4 set screws to get it to fit.
If I had to do it over again I would do something else. But I love the saw!!!
Ron
