Grizzly 6" cast iron hand wheel
Review by ajthomas5009 posted 06-06-2015 04:27 AM 4001 views 4 times favorited 10 comments Add to Favorites Watch
Grizzly 6" cast iron hand wheel No-picture-s No-picture-s Click the pictures to enlarge them
I ended up picking up a cpl of these to replace the garbage plastic OEM ones on my Cman 113 saw. I was a little lerious whether they would work because I ran across a few unhappy reviews because of difficulties modifying the fit.
Well they arrived today and I couldn’t be happier! The are nice stuffy and turn real smoothly. Installation was a breeze and I don’t see why some would complain. As long as you have a drill press just bore the center hole to 1/2” then pop a 1/4” 20tpi tap in your drill press and use it to tap the side for a set screw and that’s all. I don’t have much experience with milling and the process should be easy enough for most LJs. So if your in search of some replacement handwheels these are by far the best bang for your buck.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
View ajthomas5009's profile
ajthomas5009
296 posts in 1523 days
10 comments so far
View Jerry's profile
Jerry
2552 posts in 1554 days
#1 posted 06-06-2015 06:24 PM
Thanks for this review, I’ve had my eye on these to replace the crappy wooden hand wheels I fabricated for my Moxon vise.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View Grumpymike's profile
Grumpymike
2215 posts in 2221 days
#2 posted 06-06-2015 08:20 PM
I have an old C-man tilt head band saw with of course the plastic hand wheel. During the move to Ariz. the hand wheel got broken.
No longer available from Sears I tried the Grizz.
Like you I drilled for the shaft and set screw and wholla! we’re back in business stronger than ever.
+1 on Jerry’s by line.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
ajthomas5009
#3 posted 06-07-2015 12:29 AM
It amazes me that these handwheels don’t come standard on all contractors grade tools and up. They were like 16$ a piece and I’d rather pay the extra 30 up front then replace plastic down the road.
View bobasaurus's profile
bobasaurus
3377 posts in 3090 days
#4 posted 06-07-2015 02:57 PM
I need a pair of these for my old crapsman table saw as well, those plastic wheels have been driving me nuts. Did you also buy the handle attachment, and if so does it pivot while turning smoothly?
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View longgone's profile
longgone
5688 posts in 3214 days
#5 posted 06-08-2015 12:35 AM
I’ve been wanting a better knob for the adjustable angle sculpting table I have because the small 2” plastic knob I currently use is difficult to tighten. It has a 7mm” bolt that the knob tightens on and this large hand wheel seems like it would be perfect since it needs to be drilled out and tapped. Just ordered one online…thanks for the idea…!
ajthomas5009
#6 posted 06-08-2015 12:53 AM
Yes BoB I ordered 2×6” handwheels and 2×4” handles. A 10” craftsman could handle the 8” wheels if you felt so inclined but I think it would look out of balance. Plus the 6” are already like 10x better than the OEM’s. The handles do pivot and all you need for installation is drill press, 1/2” drill bit plus 1/2” reamer, 3/16” bit and a 1/4-20 tap bit. If you don’t want to mess with the reamer go with a 17/32” drill bit because drill bits are usually a little undersized.
I paid right around 42$ with delivery for all 4 parts.
Grumpymike
#7 posted 06-08-2015 04:00 PM
Hey Greg,
After you install these guys you will wonder why didn’t I do this a year ago … I did.
View Festus56's profile
Festus56
2510 posts in 1134 days
#8 posted 06-08-2015 11:10 PM
I have both the 6” and the 4” version with the chrome handles on my old Craftsman TS. As said they are great and easy to machine to fit your application. The 4” one does not come drilled for a handle but that also was easy to drill and tap the hole for it. This pic was before I got the chrome handle for the 6” wheel.
Mark
-- Mark -- Really we're not crazy, just "Limited Editions" -- http://www.jmh-limited-editions.com/home.html --
View Mainiac Matt 's profile
Mainiac Matt
7663 posts in 2234 days
#9 posted 06-10-2015 02:42 AM
I have the 8” one on my Grizzly wish list (just in case Santa is looking for any ideas) for use on a leg vise I hope to build from ACME threaded rod.
-- Pine is fine, but Oak's no joke!
Grumpymike
#10 posted 06-10-2015 11:15 PM
Mainiac Matt
Have you found a supplier for your Acme Thread?? Every where I look it’s pretty expensive stuff, putting my leg vise back a bit.
