New worksharp for old chisels
Review by Craftsman on the lake posted 327 days ago 1069 views 1 time favorited 17 comments Add to Favorites Watch
New worksharp for old chisels No-picture-s No-picture-s Click the pictures to enlarge them
In reviving my shop after many years I got a workshart 3000. I used to sharpen my chisels by hand on sandpaper and stones and got marginal results because you really have to work at it to get them the way you want. This worksharp really makes it easy. I mean really easy. Old dull chipped chisels took maybe 15 minutes each and I’ll be able to touch them up in a few seconds anytime I want to now.
The unit is not cheap but not as expensive as some units. I got mine from Sears for $189 but you can find it lots of places for $199. I think it retails for $249. It’s well built and easy to use. The only small quirk I can think of is that some levels of the sharpening paper that comes with it get dull quickly. Then again maybe I’m complaining too soon. I brought a dozen chisels up to speed and some of them really needed some work badly. From now on it won’t take too much wear on the consumables I’d think. Tools like this make woodworking someone like me do and look a lot better than i am in the shop.
Here’s a link to the manufacturer’s promo.
http://www.youtube.com/watch?v=_N9UTcXX61Q
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
818 posts in 334 days
17 comments so far
View matt garcia's profile
matt garcia
723 posts in 568 days
posted 327 days ago
I too have a Worksharp 3000. I think it is a phenomenal sharpening machine. No oil or waterstones to check the flatness on. No slurry to clean up, and it always gives me excellent results. I had to adjust the squareness of it when I first used it, but that was just a screwdriver, and lever adjustment! I recently honed a plane iron with it. The manufacturers suggested bevel angle was 25 degrees. The Worksharp 3000 had a preset for that angle, so no measuring! I think this is an awesome tool that every woodworker should try, at least once. One use, and you’ll be hooked!
-- Matt, Houston Texas
teenagewoodworker
2482 posts in 665 days
posted 326 days ago
yep i have this too and it works great! use it for all my flat blades. they even have an attachment allowing larger blades to be sharpened on top now
View Brad_Nailor's profile
Brad_Nailor
1222 posts in 854 days
posted 326 days ago
Thanks for the review..I have been using guides and sandpaper with only decent results and allot of work. I have been considering getting one of these.
View douglbe's profile
douglbe
191 posts in 857 days
posted 326 days ago
I got two of them for Christmas, but, we won’t go into how that happened. I also sharpened a couple of chisels that really needed it. iron planes, and also sharpened my used lathe tools that I aquired. Being able to see what you are doing while sharpening from the underside is great. It was quite easy to get a razor sharp edge on my tools; what a delight to work with sharp tools. Thanks Daniel for your post, it’s fun to talk about our new toys.
-- Doug, Cass City, Michigan
View Tony Z's profile
Tony Z
173 posts in 687 days
posted 326 days ago
I’ll take your second one douglbe.
-- Tony, Ohio
View bfd's profile
bfd
419 posts in 704 days
posted 325 days ago
have it love it couldn’t be easier to use.
-- Brian, Folsom, CA http://www.brianfullerdesigns.com
View Sac's profile
Sac
236 posts in 530 days
posted 325 days ago
I’ve been looking at getting a sharpener that I can get a true edge on other than a grinding wheel. This looks very economicle. Thanks for the info.
-- Jerry, Set in the foothills of the Smokey's
View northlander's profile
northlander
9 posts in 533 days
posted 325 days ago
I recently picked up the WS3000, I second all the comments on the ease of getting sharp tools. The only gripe I have is the grit of the lapping paper for the back of the blade when sharpening, I may change to a different grit when it get worn out. I’ve done chisels and plane irons and it’s been a dream compared to the hand sharpening on waterstones.
View Built2Last's profile
Built2Last
103 posts in 374 days
posted 310 days ago
I use mine to sharpen my pockets knives, first time I’ve ever been able to sharpen them so they will shave. Can also make my chisels shave. This thing is great!!!!
-- BUILT TO LAST WOODWORKS, West Blocton, Alabama
View NeoDon's profile
NeoDon
48 posts in 303 days
posted 276 days ago
I also have it and it Rocks. Really comes in handy when your in the middle of
turning a pen and your turning lathe chisel dulls. It.s fast and good. I am going
to add the leather honing wheel to see if I can get to that scary sharpness that
it gets close to now.
View Loogie's profile
Loogie
67 posts in 676 days
posted 270 days ago
Anyone find a source for generic PSA disc’s with the hole in them for the Worksharp? I can get 6” dics on a roll for a lot cheaper than the OEM Worksharp one’s, but I have to cut the hole myself.
-- Mark
View buffalosean's profile
buffalosean
61 posts in 284 days
posted 243 days ago
great system, easy to use. worth the money if you ask me
-- Sean Buffalo, New York
View pommy's profile
pommy
962 posts in 588 days
posted 243 days ago
just looked at the price in the uk for this system and is it really worth £189.95
so if anyone wants to buy me one feel free LOL
andy
-- cut it saw it scrap it
View SCOTSMAN's profile
SCOTSMAN
2244 posts in 482 days
posted 243 days ago
I have a slow speed 3 phase sixteen inch horizontal wheel run in an oil bath supplied by a pump the oil really cools the sharpening process down and works great chisels and planer knives hand only come up rezor sharp.Alistair
View WayneC's profile
WayneC
6034 posts in 994 days
posted 243 days ago
That sounds like a beast of a sharpener Alistair. I would think the price is dollars if your were to buy one in the US is closer to 120 pounds. I imagine there would also be a power conversion issue.
Relative to paper use, there is a corse pack they sell that has some lower grit paper in it. It works great if you have to remove a lot of material. I would also like to find a second source of paper.
View USCJeff's profile (online now)
USCJeff
901 posts in 965 days
posted 195 days ago
Just got this unit. Decided to finally tackle turning and had to break down and get a sharpener I’d use. I put sharpening in the same boat as sanding. Try to avoid doing much of either.
The initial impression was much like the original post. Takes a while to fix a damaged tool, but resharpening is a matter of seconds after the initial work. The paper does seem to glaze over quickly regardless of using a crepe block. The consumables could really make it expensive to upkeep.
-- Jeff, South Carolina
16928 posts in 474 days
posted 194 days ago
Hey Daniel Thanks for your review.
I have had work sharp 3000 for almost 2 years it works great and I just use standard 6” psa and cut the center out it’s not a big deal and it saves on cost. It’s cost is a little deceiving in that if you buy a fair amount of sandpaper and extra glass wheels(4) you can double the price. But even with the extra cost I still think its a good system.
