More Than Worth the Money
Review by Tomcat1066 posted 332 days ago 1251 views 0 times favorited 10 comments Add to Favorites Watch
More Than Worth the Money More Than Worth the Money No-picture-s Click the pictures to enlarge them
While wandering through Lowe’s, I saw this bad boy just sitting there with a $30 price tag. Since I found myself in no position to own a table saw for the foreseeable future, it looked like it would solve one of my biggest problems: how to rip boards down.
The Accu-Rip attaches to your circular saw with two small screws located at the front of the guide. It takes a bit of time to get it set right, because it’s edge must line up with the blade just so, but once it does, it works like a dream. On the other side (and clearly visible in the closer picture above) is the edge guide part. You simply line this up with the desired rip you want, lock it down, and go to town.
I could go on a long diatribe and try to make this look more impressive, but the fact of the matter was the thing works. I was able to rip down each board with no problem. In addition, this puppy makes it possible to rip thin strips that you wouldn’t want to try to do free hand.
In addition, it makes the same cut over and over again, something that is hard to do without a jig of some kind. It’s 24” capacity allows it to handle 4’x8’ pieces of plywood or MDF without a problem.
The kicker is that the guide doesn’t impede crosscuts in the least, unless you use a guide of some type. In that case, simply remove it and let it run.
I have to admit, I was very surprised at how well this thing worked!
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
View Tomcat1066's profile
Tomcat1066
776 posts in 694 days
10 comments so far
View DaveH's profile
DaveH
372 posts in 676 days
posted 332 days ago
Looks like a cool idea.
Link to the craftsman accu-rip
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
Tomcat1066
posted 332 days ago
Thanks Dave! I didn’t even think about linking to the product. Thanks for doing that for me :D
Beginningwoodworker
4214 posts in 571 days
posted 332 days ago
Neat idea!
-- CJIII Future cabinetmaker
View CessnaPilotBarry's profile
CessnaPilotBarry
1287 posts in 600 days
posted 332 days ago
Lowes?
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
Tomcat1066
posted 332 days ago
Yep, Lowes. ;)
View Doug S.'s profile
Doug S.
306 posts in 606 days
posted 331 days ago
I’ll give it 4 stars. It works in a pinch and pretty well, but I think using a clamp on straight edge guide is a bit better.
-- Use the fence Luke
Tomcat1066
posted 331 days ago
Doug,
Perhaps. But for me, I like the idea of just taking it from one board to another without having to line up anything and make the exact same cut. With a clamp on guide, you have to line up the guide rails and get them just so before cutting. With this, you just go to the next board and go to work.
Of course, this is also one of those things where there is no “wrong” answer, just different ones ;)
View Woodshopfreak's profile
Woodshopfreak
390 posts in 640 days
posted 330 days ago
Cool, I need one of those.
-- Tyler, Illinois
Doug S.
posted 329 days ago
Tomcat
which one I prefer to use depends on whether I’m after a finished edge or not. The staright edge clamp gives me a straighter cut. The little hook on the Cman guide will follow any local dings or wallows in the edge, so the cut line will end up the same. If the edge you’re following is rough, that hook can hang up a bit as well, and try to make the whole thing act like a trammel arm and start angling your cut until you snug it to the edge again. Just for busting up sheet stuff for final cutting on a table saw, it’s super quick and easy.
Tomcat1066
posted 329 days ago
Doug,
Fair enough. I haven’t used rough lumber yet, and frankly I haven’t found a local source for it yet, so this is ideal for my situation. Everything is already milled straight, so that’s not an issue for me and in my situation.
