Starrett Bimetal Band saw blades
Review by robscastle posted 05-18-2015 11:41 PM 5835 views 1 time favorited 8 comments Add to Favorites Watch
Starrett Bimetal Band saw blades No-picture-s No-picture-s Click the pictures to enlarge them
I saw a bi metal blade working at Degoose’s workshop, Larry demomstrated cutting a couple of rips from some timber and the results were very impressive. He cut two runs from a length of timber and produced very accurate results from his band saw fitted with a new Kreg fence.
With this in mind I decided to try it for myself on my bandsaw, which BTW is notorious for cutting where ever it wants to, generally not where the operator wants it to go.
So I purchased two Blades:-
1×2240mm x 1/2” x 4 TPI and the other 2240mm x1/2” 12 TPI.
The 4 TPI Blade is branded Starrett Intenss PRO-DIE 1/2” (13mm) x .035” ( 0.90mm) x 3/P then is smaller numbers showing 360295-07.
The 12TPI has no markings on it at all. So I assume its a generic bulk saw blade cut to length to suit the customer.
Physical Appearances:
As you can see in the previous image both the blades exibit a greyish finish as opposed to the black/Blue appearance of a conventional blade, and they are noticably thicker. So regonition of the bi metal is apparent
Fitup:
Due to the difference in thickness a complete re- adjustment of the saws alignment bearings and rubbing strips has to be done along with a readjustment of the tension to suit the width of the blade.
I have only fitted the 4TPI blade to the band saw at this stage.
Pre run up:
With the new blade fitted a freehand rotate was done to check for binding, all was good so it it was go at throttle up, at power on the saw ran normally and exibited no difference in its nornal free running operation.
I had a piece of timber which had a twist in it which to remove would waste most of the timber so I chose to use it as a resaw test.
Preparation before sawing:
The timber had been thicknessed and jointed on the edge, hence how I discovered the twist.
I marked the timber out at 22mm intervals allowing for final thicknessing and commenced the first cut, I used the original fence and a Mag switch featherboard
Resawing in action:
I cut each piece, jointed the stock and completed another cut again repeating the process eventually finishing with five pieces, four at the required width and one a remaining off cut.
I then took the off cut jointed the sawn side and resawed it to remove the outer rough edge
Although I aded the additional process of jointing the timber in between cuts the blade performed on par to what I saw at Larrys shop.
Post sawing Measurements:
I placed three pieces on the jointer to check for physical accuracy.
This is what I saw:
One end view
Then the other end
There is evidence of twist but the results are good enough for a cutting board glue up or the likes.
I then gauged up each stick at three positions, start, middle and at the finish of the cut, these are the results.
Note: Pictures deliberately turned sideways for convienence, I havent had an earthquake !!
Start:
Middle:
End:
Conclusion:
Financials:
A standard Bandsaw blade is about $14 -$16 each, the Bi meatal blades were $48 each, so investment wise its a substantial rise in capital outlay cost.
Performance:
The blades performance was certainly improved out of sight, in both accuracy and ease of cutting on the saw.
Value for money:
Well its cost is certainly up there so an accurate assessment is to be determined as the blade is used and its life cycle can be assessed. But if its anything like HSS is to tungsten its a worthwhile investment.
enjoy.
-- Regards Robert
View robscastle's profile
robscastle
4962 posts in 2198 days
8 comments so far
View gfadvm's profile
gfadvm
14940 posts in 2684 days
#1 posted 05-19-2015 01:14 AM
I too purchased a bi-metal resaw blade (Timberwolf) and will never go back to regular carbon blades. I use the 2/3 variable tooth configuration on very hard woods (Jatoba and Hedge) with good results. So far it seems to be staying sharp/straight longer than my carbon blades. My 131 1/2” was $70 so it needs to last longer!
View degoose's profile
degoose
7231 posts in 3348 days
#2 posted 05-19-2015 03:35 AM
Glad to see you are getting better results…
View Joe Lyddon's profile
Joe Lyddon
10091 posts in 4046 days
#3 posted 05-19-2015 05:19 AM
Very interesting…
View Roger's profile
Roger
20928 posts in 2798 days
#4 posted 05-19-2015 12:51 PM
Thnx for your review and thoughts.
View MrRon's profile
MrRon
4758 posts in 3237 days
#5 posted 05-19-2015 03:36 PM
I discovered Starrett blades a long time ago and that is all I use. I have not used the bi-metal ones, although I do have one on my metal cutting bandsaw. On my wood cutting BS, I have the Starrett “Woodpecker” 3T skip. The most notable thing about them is the weld; or the lack of. It is so perfectly welded, that you can’t see where it is welded. That makes for perfect running through the guides. I have mentioned them many times before, but no one seems to want to believe me. I’m glad you have discovered them.
View b2rtch's profile
b2rtch
4861 posts in 3042 days
#6 posted 05-19-2015 05:13 PM
My local guy made me bi-metal band saw blades from reels of Leenox material.
They work great.
I think that I paid quite but lees that you paid for yours.
-- Bert
View stefang's profile
stefang
15881 posts in 3328 days
#7 posted 05-19-2015 05:45 PM
Those bi-metal blades should last a long time Rob.
View tnwood's profile
tnwood
258 posts in 3080 days
#8 posted 05-26-2015 12:44 PM
I have a Starrett also and find it performs extremely well. I have used the Woodslicer blades previously and while they work well, they don’t stay sharp very long. I’m hoping the Starrett will have a longer life expectancy.
