Drillnado Drill Press Dust Collection with one problem
Review by DW833 posted 04-29-2015 02:43 PM 9440 views 0 times favorited 17 comments Add to Favorites Watch
Drillnado Drill Press Dust Collection with one problem Drillnado Drill Press Dust Collection with one problem Drillnado Drill Press Dust Collection with one problem Click the pictures to enlarge them
I purchased this product at the Tampa woodworking show. The inventor was at the show and demoed the dust collection. I thought that the dust collection setup had a small footprint. I’ve tried other methods that just got in the way at the DP.
The cost was $39. Included the quill for attaching to the DP, two housings and additional fittings to secure the quill. At the show, a second housing was provided with the purchase. I’m not sure if that is the case with every purchase.
The two housings are handy. One can be trimmed for larger bits, and the other for smaller bits.
Installation of the quill was straight forward. Just connect to DP and tighten four screws. Don’t make it too tight.
The housing then snaps into the quill. I had difficulty getting that just right. But after I did, it was easy to install and remove the housing. If you find that the housing isn’t snapping into the quill, loosen the quill until the housing easily snaps.
The dust collection works great. I’ve used it several times and using a HF DC with 2 1/2 inch hose adapted to 4” hose. I estimate dust collection is 95% or better at the DP. That is with small or large bits. If you are not using the DC, it is out of the way and doesn’t interfere with DP use.
There is one problem with the dust collection. On my Ryobi DP 102L bench top drill press, the housing blocks the laser from reaching table. Tried adjusting the laser, but didn’t help. The only solution is to remove housing, align laser and re-install housing. Although it is easy to install housing, it is a pain when many holes have to be drilled to remove it, align laser to desired point on wood and then re-install housing. If your DP doesn’t have a laser, it won’t matter.
I would recommend this product because it has excellent DC and small footprint. I thought the price was OK. Although there are only a few pieces, they are well engineered. Also, wanted to encourage the woodworking start-ups to create new products. If you depend on a DP laser, just beware of how it has to be used. If the laser would continue to work without removing the housing, would be 5 starts instead of 4.
View DW833's profile
DW833
220 posts in 2121 days
17 comments so far
View CharlesA's profile
CharlesA
3359 posts in 2036 days
#1 posted 04-29-2015 05:02 PM
Thanks for the review. How convenient is it to change bits frequently?
DW833
#2 posted 04-29-2015 06:00 PM
The housing has to be removed so the chuck can be used and the bit removed. However, it only takes a second and isn’t a problem. I haven’t used it when I had to change bits a lot. But I would think it still wouldn’t matter. Snapping the housing off and on is quick and easy.
CharlesA
#3 posted 04-29-2015 06:03 PM
thanks.
View gtbuzz's profile
gtbuzz
427 posts in 2680 days
#4 posted 04-30-2015 02:24 PM
Thanks for the review. I’ve been curious about this myself since seeing it at one of the WWS. Since you’re using a 4” dust hose that you’re necking down to 2.5”, you’re losing a lot of airflow, but presumably it’s a lot more directed with that accordion thing. How would you say chip / dust collection is on a smaller bit with the Drillnado vs just holding a 4” hose next to it?
DW833
#5 posted 04-30-2015 02:56 PM
I always had trouble securing 4” hose to the DP and did not use it much.
So I don’t have a good comparison between the two. I can say that the Drillnado
collects almost all of dust and isn’t in the way when using DP.
View Rayne's profile
Rayne
1124 posts in 1778 days
#6 posted 04-30-2015 05:28 PM
How’s the customer service? The Woodworking Show actually asked them my question but they never got back to me or them, so I’m curious if they’re as committed to it as I would hope. This looks to be a great idea and am considering it especially after your review.
DW833
#7 posted 05-01-2015 01:00 AM
Rayne,
I talked with the inventor at the show. He was very helpful and answered all questions before I purchased.
Also, I emailed him when I had questions about the DP laser issue. He emailed me back with possible solutions.
He mentioned at the show he had committed to some number of units manufactured. Don’t recall the exact number, but remember thinking it was more than I would have expected.
No problems with what I’ve experienced.
View Mikesawdust's profile
Mikesawdust
327 posts in 3277 days
#8 posted 05-06-2015 10:25 AM
I would suggest purchasing a laser pointer and clamping it where it could hit the wood. Once you clamp the first piece, you can adjust the pointer to match the factory laser then reinstall the shroud. As long as you are doing the same thickness of material for all drilling in the batch it will identify the center.
-- You never cut a piece to short, you are just prepping that piece for a future project
View pottz's profile
pottz
3826 posts in 1223 days
#9 posted 09-15-2015 08:10 PM
warning so you dont waste 40 bucks like i did this will probably not do what you want it too first it clogs up very easy with larger bits the kind you really need dust collection on second the plastic shroud distorts and looses its shape very quickly making it hard to reattach.also each time you drill a hole you have to pull the shroud back down to get maximum suction.not made from the right type of plastic mine is worthless after putting on and off a dozen times.the unit does mount on the press very easy i have a delta.all in all i give this product a 1 star rating if you do get one buy lots of extra shrouds you will need them.
DW833
#10 posted 09-16-2015 01:28 AM
Pottz, I’m with you on the drillnado. Wanted to take this time to update the initial review. After using the drillnado for several months, I’m no longer using it. The main problem for me is the housing was always in the way. It was more of a pain than a gain for me. So I ended up removing it. I did get the housing where it could be removed and then reinstalled. It took many attempts at adjusting the quill used to attach it, but even then it would loose shape occassionally. When I could use it, the dust collection worked great.
Maybe the inventor will improve on it. Mine is going on ebay.
pottz
#11 posted 09-16-2015 01:29 PM
yeah i loved the whole idea but it just doesnt do what you want and the plastic shroud is crap you may see me on ebay too.
View clieb91's profile
clieb91
3545 posts in 4173 days
#12 posted 01-09-2016 03:16 PM
Thanks for the review and updates to this. I am heading to a show in February and this is something that is on my interest list. I drill a lot of holes for my games ad looking for a good solution to dust control.
CtL
-- Chris L. "Don't Dream it, Be it."- PortablePastimes.com (Purveyors of Portable Fun and Fidgets)
View SawTooth1953's profile
SawTooth1953
336 posts in 3544 days
#13 posted 08-30-2016 02:42 PM
I don’t have a product review since I just mounted mine and haven’t used it yet…and then I saw this thread on LJ.
I wanted to update that the Drillnado is now available in 2 sizes…the new one is for larger drills with larger quills. AND the one you guys bought is now $49 and the larger one is $59 (based on my recollections). I got the larger one…it came with 2 shrouds and shims to fit it to various sizes, including smaller quills. Turns out my larger drill has the depth stop mounted on the quill. Drillnado instructions tell how to dismount that and attach the depth stop to the Drillnado housing so that the Drillnado can be installed on the quill. I didn’t do that (yet). Instead I attached it to my smaller drill press, using the shims that came with it. No problems at all for that installation…took just a few minutes.
After I’ve used it a while, I’ll come back and let you know how it’s working for me. (I don’t have a laser on my drill press.) I bought it because dust control at the drill press has always been difficult for me to achieve and this product appeared at the show to be just what I needed.
-- Spence in Skokie, IL
pottz
#14 posted 08-30-2016 06:06 PM
looking forward to your update,maybe the reason they give you 2 shrouds is because they dont last long,mine went into the trash a long time ago.good luck.
View DeansWoodworking's profile
DeansWoodworking
2 posts in 1063 days
#15 posted 09-09-2016 05:17 PM
I have been using one for about 6 months. The only problem I have had is when I installed it too high and blocked the suction port partially which caused it to clog. Once I figured that out I would not do without it.
Do a project and nothing to clean up, Awesome.
