| Review by Maddhatter | posted 353 days ago | 693 views | 0 times favorited | 17 comments | ![]() |
- Simple Green Cleaning Blades and Bits
- Brand: Simple Green | Category: Other
During a work conference, one of the vendors present was for Simple Green. After talking about hobbies for a while, we got on the subject of cleaning pitch and gum from blades and bits. He had offered me a sample of the product to try. It was simply amazing, one spray on a blade and the pitch and gum just dissolved.
I had pulled out the worst blade of the bunch, and with some light brushing; the pitch came off as easy as you please. I am not sure if this is out on the market, I checked with my local woodcraft and they were going to talk to their distributor to see if they can get it in the store.
If you are not satisfied with what you are using now, you may want to give this one a try. The results just might surprise you.
-- Norm (AKA - The Maddhatter), Middletown DE
17 comments so far
dustygirl
home | projects | blog
767 posts in 624 days
posted 353 days ago
Thanks for the tip.I will write this down for future reference when I need to get some.
CessnaPilotBarry
1281 posts in 598 days
posted 353 days ago
I’ve tried Simple Green for blade cleaning, and CMT 2050 destroys it.
I like SG for lots of other stuff, though! <g>
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
Maddhatter
74 posts in 473 days
posted 353 days ago
I would agree Beech Pilot with the first two product releases, however this is a n
ew product developed for Boeing and mets the FED SPECs. From the other Simple Green products that I have used in the past, this one was a pleasant surprise.
CessnaPilotBarry
posted 353 days ago
So, the full name of this product is? If it was developed for Boeing, it isn’t regulat “Simple Green”.
Maddhatter
posted 353 days ago
When I took the picture of the label, did not notice it was curled over. The product is Extreme Simple Green my bottle states it meets Boeing Spec D6-17487P. Hope this helps.
TraumaJacques
382 posts in 396 days
posted 353 days ago
I wonder if it would remove Gorilla glue from my hands :-) thanks for the tip.
-- All bleeding will eventually stop.
Woodshopfreak
390 posts in 638 days
posted 353 days ago
I have heard that that stuff is great for cleaning blades. I have read that some chemicals can damage the bits of carbide on the blades. I read that Pine-Sol works well. I have tried it and it does work really well, but you have to delute it a bit because I left my blade in a bag of it over night and all the lettering on the blade came right off. Luckily it was a piece of junk cheap blade.
-- Tyler, Illinois
socalwood
968 posts in 500 days
posted 352 days ago
we tried SG- and it didn’t work very well . CMT works good – expensive and overspray rusts stuff . We use paint thinner or diesel . Got to dispose of cleaning rags properly!
CessnaPilotBarry
posted 352 days ago
Cool! I’ll check out the Extreme Simple Green. Thanks!
douglbe
191 posts in 857 days
posted 352 days ago
I’ve been using the inexpensive Simple Green for over a year not, let my blades and bits soak for 10 to 15 minutes and the pitch and gum falls off. It works great for me, I have never had a problem.
-- Doug, Cass City, Michigan
Kindlingmaker
1471 posts in 422 days
posted 351 days ago
Put Simple Green in your pressure washer and it will clean any machine or engine you have. It will totally remove synthetic oils from asphalt! I just wish it smelled like scotch.
OttawaP
53 posts in 622 days
posted 351 days ago
Let me return this favour given to me years ago by another woodworker. “Arm and Hammer Super Washing Soda” is by far THE BEST BLADE CLEANER…..period. A spoon or two in some hot water, soak your blades for 15-30 minutes, a gentle cleanse with an old toothbrush and done with perfect results. Best thing is a box will pretty much last a lifetime for less than $10.
I’ve tried 2 or 3 of the store bought blade cleaners and they don’t do anywhere near as good or as fast a job as this stuff.
-- Paul
Maddhatter
posted 351 days ago
I used to use that to, If memory serves ; I read it in a readers tip some time years ago in a Fine Woodworking magazine. Mid 80’s
I think. It was the Arm and Hammer non phosphate cleaner. Worked grate with soaking as you pointed out.
Cheap that works is a good thing.
blackcherry
730 posts in 719 days
posted 349 days ago
GOOD LUCK FINDING IT!!!!Blkcherry
OttawaP
posted 349 days ago
I just picked it up over a year ago at our local grocery store. Is it hard to find generally ??
-- Paul
poppychuck
14 posts in 366 days
posted 349 days ago
I have been using SG for years with great success. Readily available at Home Depot.
-- Chas F
Layton
15 posts in 355 days
posted 347 days ago
How bout oven cleaner from the dolla store
