Solid on the outside, issues with accuracy and precision
Review by Rick_M posted 04-14-2015 03:50 AM 3698 views 0 times favorited 14 comments Add to Favorites Watch
Solid on the outside, issues with accuracy and precision Solid on the outside, issues with accuracy and precision No-picture-s Click the pictures to enlarge them
From the outside in … The packaging was attractive and consistent with other products sold by iGaging (makes no difference but shows the company takes some pride in their products). Inside the retail box was a sturdy white cardboard box that contained the inclinometer, a nice storage pouch, the instructions, a 9V battery, and a tiny screwdriver. I expected the AccuRemote to be made of plastic but it’s actually a cast metal, possibly zinc, quite sturdy and heavier than expected. The battery compartment is accessed by removing four dinky Phillips screws that jump to the magnets as you pull them out, an unintended but welcome feature as they would be super easy to lose and very difficult to find. The dinky screws + battery cover are too 1970’s for me, there are better ways to cover a battery but including the screwdriver was a nice touch.
The inclinometer was easy to use, I didn’t bother with instructions. I spent awhile measuring angles everywhere then going around checking the machines in my shop. I tried testing for accuracy the same way you would test a level, by flipping it 180 degrees, but got inconsistent results. According to this, after setting my table saw blade with an engineer square, I was 0.20 of a degree out. So pretty close but if this thing is accurate then it’s nice to get that extra precision especially when cutting miters or segments for turning. My miter saw was dead on perpendicular, as I believed. My band saw was off .5 degree which I suspected.
It turned out, the case is not square to the bottom on all sides. So if you zero the device then turn it on it’s side, it should read 90 degrees. The left side read 90 degrees, the right side read 89.70 degrees. Since I have a right tilt saw and would be using the bottom and right sides most often, being off by .30 degrees would just be annoying. I was also bothered that rotating the device 180 degrees does not give the same or reciprocal reading. And I had issues with precision (repeatability) when the daytime temperature was under 60 degrees Fahrenheit. So I sent the inclinometer back to Amazon. Based on the many reviews of this and similar products like the Wixey, I believe it is luck of the draw whether you get an instrument that is accurate and precise. The Wixey and other brands under $50 all have similar negative reviews, and many positive reviews. So I wouldn’t say iGaging makes poor instruments, just that digital inclinometers in this price range suffer poor quality control. The summary is I can not recommend for or against the product.
-- http://thewoodknack.blogspot.com/
View Rick_M's profile
Rick_M
11083 posts in 2282 days
14 comments so far
View Rob's profile
Rob
704 posts in 2973 days
#1 posted 04-14-2015 05:09 AM
Thanks for the review! I was looking at the Wixey Type 1 and Type 2 digital angle gauges a month or two ago and decided to pass. Apparently the Type 2 is accelerometer-based and is no more accurate or precise than a smartphone app. The Type 1 is more accurate and more precise, but it is “always reading” even when the display is off, so it depletes its battery every 6 mos. or so regardless of whether you use it.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Tennessee's profile
Tennessee
2738 posts in 2417 days
#2 posted 04-14-2015 12:17 PM
That also seems to be the problem with my HF that I bought. Seems highly accurate, but also seems to be measuring even when the unit is off, and it is a battery hog.
View doubleDD's profile
doubleDD
7101 posts in 1945 days
#3 posted 04-14-2015 12:46 PM
You are right about these. You can check the accuracy 5 times in a row and get a different reading. I wish I had checked this when I first purchased it.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1079 days
#4 posted 04-14-2015 01:06 PM
Thanks for the review. My Wixey has the same problem with the sides not being perpendicular to the base. I get around this simply by always using the base and adjusting the angle by 90 degrees.
As far as the battery, I learned a long time ago to never leave a battery in a digital measuring device. I have been hoping that they had solved the battery drain issue, but it does not sound like it.
View terryR's profile
terryR
7074 posts in 2211 days
#5 posted 04-14-2015 01:32 PM
Thanks for saving me some money, Rick! I’ve wanted one of these tools to help me cut segments for bowls and whatnot. With my aging eyes, I’ll have to rely on digital measuring in the near future, but I’ll avoid iGaging. Maybe a Wixey1?
-- tr ...see one, do one, teach one...
View timbertailor's profile
timbertailor
1594 posts in 1326 days
#6 posted 04-14-2015 02:23 PM
I have the Type 1 and have had no such issues except for battery drain. I just pop it out when I not in use.
Thanks for the heads up Rick and a very honest review.
View ChuckC's profile
ChuckC
827 posts in 2837 days
#7 posted 04-14-2015 04:15 PM
Mine is just as bad as yours.
Rick_M
#8 posted 04-14-2015 07:20 PM
Sounds like my experience is pretty normal.
View Grumpymike's profile
Grumpymike
2214 posts in 2217 days
#9 posted 04-15-2015 09:42 PM
I have had a Wixley for about five years now and I have learned to love it. Mine has magnets on the bottom and one side. When I set the ‘0’ and turn it on the magnetic side it will read 90 or maybe 89.9.
If I turn it on the opposite case side it will give a crazy reading that is not 90.
I find mine to be accurate for the wood shop and more accurate than using the machinist square.
Now, if I were looking for more accuracy, like plotting a trip to the moon, I would expect to pay a bit more for the tool, but for the $39 I paid, I’m really happy with the Wixley.
Battery life is about 6 months, and the battery cost is about $2.75, so that’s expendable.
-- Grumpy old guy, and lookin' good Doin' it. ... Surprise Az.
View CharlesA's profile
CharlesA
3305 posts in 1700 days
#10 posted 04-16-2015 06:18 PM
Mike, I’ve had the same experience with the Wixey. I’ve never tried all four sides, but the two magnetic sides only vary by 1/100” of a degree. It’s the kind of thing that would seem absolutely dead-on if one didn’t have the capability of measuring 1/100 of a degree.
Rick_M
#11 posted 04-16-2015 08:32 PM
Yeah it seems like I’m being nit picky but if I’m going to have a digital protractor that can measure to a hundredth of a degree, then I want it to be somewhat accurate and precise. Otherwise if close is good enough I can just use a regular protractor or the scale on the saw.
Matter of fact there is a company making a plastic protractor just for setting up table saws, the Gauge-It, it looks pretty cool. The only thing holding me back is the price.
View BobAnderton's profile
BobAnderton
245 posts in 2692 days
#12 posted 04-17-2015 10:10 PM
I can vouch that if you leave it stuck on the blade of a Delta compound miter saw and forget about it, when you turn the saw on it’ll hit the ceiling and still work fine afterwards. Just a few scratches on the anodized surface. I was impressed that it could survive my stupidity.
I don’t think Rick fully stress tested his.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View NormG's profile
NormG
5900 posts in 2906 days
#13 posted 04-18-2015 03:23 AM
I have a Wixey and have been very happy with it
-- Norman - I never never make a mistake, I just change the design.
Rick_M
#14 posted 04-18-2015 05:53 AM
I don t think Rick fully stress tested his.
- BobAnderton
Ha! I have to agree. I did not do any stress testing.
