| Review by GaryK | posted 326 days ago | 473 views | 0 times favorited | 17 comments | ![]() |
- Wixey Digital Angle Gauge
- Brand: Wixey | Category: Measuring Tools
Here’s a great little tool for setting the angle on most everything.
Bandsaw, Tablesaw, Mitersaw, Radial Arm Saw…
The best part is the precision and speed in which you can do it.
There are magnets on the bottom which allows you to stick it to anything steel.
I will use a table saw for example here, but you can apply the same to all tools.
If what you are trying to set is aluminum or something other than steel then you will need to
hold it place.
Here are the magnets:
For setting the blade angle on your table saw stick it to your table next to your blade..
Then press the ‘zero’ button.
Then stick it to your blade and more to the desired dergee. If your table is not level it won’t matter
since you zeroed to your table. (I’m using a Radial Arm Saw picture because I don’t have one showing
the table saw)
It makes changing the angle of my table saw blade a no sweat operation and I find myself
changing it without hesitation. I used to hate changing it since it involved getting a square or protractor.
With the magnets you can also store it close. Just stick it somewhere convient on your table saw.
The best part is that’s only $39.95. I have even seen it on sale at Rockler for $29.95.
Either way is a great deal!
17 comments so far
DAN
home | projects | blog
3505 posts in 523 days
posted 326 days ago
I have one and like it too
-- ..... art for lifes sake ... danwalters@lumberjocks.com
rikkor
8645 posts in 415 days
posted 326 days ago
I have looked at these with lust in my eye…
-- Maplewood, MN
mrtrim
1548 posts in 420 days
posted 326 days ago
yes very handy tool ,ive had one a year or so and love it .
Max
6627 posts in 813 days
posted 326 days ago
Got one of these for Christmas, I will be giving it a try here shortly…..
2101 posts in 562 days
posted 326 days ago
Gary, wise descision.
I have never been as confident with my angles as I can now be using the Wixey guage.
All the mechanical devices leave you wondering about that last 1° +_.
Wixey lets you trim to dead on.
I know another decimal place would be kool but it’s not too practical with woodworking.
At least mine.
mot
4863 posts in 577 days
posted 326 days ago
Yeah, it’s a handy item. I use the Beal Tilt Box, but it’s the same thing with an extra decimal place. They are really handy to have around for sure. Thanks for the writeup, Gary.
6735 posts in 391 days
posted 326 days ago
Thanks for the info Gary.
brunob
1391 posts in 709 days
posted 326 days ago
Got one. Love it. I use it on my drill press as well.
-- Bruce from Central New York
Nils
121 posts in 404 days
posted 326 days ago
I have the “Dixie” – which is Peachtree’s version of this – and it’s incredibly handy. The Dixie has an additional feature, which is a “Hold” button. It will hold the last measurement so you can pick up the gauge and see the angle. Handy if you’re not flexible enough to always be able to see the gauge when it’s attached to the tool, or when the lighting of the tool isn’t right for use of the gauge. Or, as was the case when I was using it to point my DirecTV satellite dish, when my ladder wasn’t long enough to let me see the gauge when it was on the post – I just stuck it on the post above my head, let it measure, then hit the Hold button and brought the gauge back down to where I could see it.
I might as well add a review, I guess!
-- Nils Davis, Menlo Park, CA
Mike Lingenfelter
405 posts in 654 days
posted 326 days ago
I have the Wixey and love it. I also highly recommend it.
Bruce, on the Drill Press why didn’t I think of that! I was just trying to square up the bit to the base, and was having a hell of time. I’ll have to check it the next time I’m in the shop to see how close I got.
-- http://theinquisitivewoodworker.com/
14328 posts in 941 days
posted 326 days ago
Thanks for the review. I have one and it’s very handy. But hadn’t used it on the drill press.
-- Karson Southern Delaware karson_morrison@bigfoot.com †
2898 posts in 520 days
posted 326 days ago
Hi Gary;
Great information. I wasn’t familiar with these devices.
Thanks;
cajunpen
5345 posts in 606 days
posted 326 days ago
Gary you are correct – it is a very valuable addition to anyone’s shop. I also have the Wixey Digital Planer Readout as well as the Wixey Height Gauge – I have not used the Height Gauge yet, but the Planer Gauge is dead on – if you want to plane a board to .750 – it will indicated exactly when you get to that thickness. I will review the Height Gauge once I play with it some.
Blake
2248 posts in 414 days
posted 326 days ago
I’ve got one and I LOVE it!
-- Check out my new website! http://www.theeasellife.com
GaryK
8567 posts in 528 days
posted 326 days ago
Bill – I have the planer readout also. I was going to post a review but they just upgraded the design.
It’s great also.
gizmodyne
1486 posts in 630 days
posted 326 days ago
Cool. Great explanation.
Chris
1261 posts in 531 days
posted 272 days ago
I use mine every time I step up to my Drill Press, Band Saw, Table Saw & RAS.
-- Chris
