16" Variable Speed Scroll Saw
Review by jwarner75 posted 368 days ago 872 views 0 times favorited 2 comments Add to Favorites Watch
16" Variable Speed Scroll Saw 16" Variable Speed Scroll Saw No-picture-s Click the pictures to enlarge them
This is a New addition to Craftsman Scroll Saw Series.
The first one that I had, I’ve only used it twice, and if it wasn’t for the Replacement Warranty that I purchased just in case, I wouldn’t have this replacement now.
So far, this Version of their Scroll Saw has Held up very well. There are only a few complaints with it thou.
1. The table is a Little Small
2. The Table Tilt only tilts up to 45 Degree to the left Only, Not both left and right
3. It does not have a Lamp to help with visual for your Work piece
4. It does not have Quick release Capability, it uses a Hex Wrench to tighten and untighten the blade
5. The Blade Tension Adjustment is at the rear of the Machine.
6. No 0 Clearance inserts.
Other then these 6 complaints, it’s good for a beginner Scroller that’s just getting into the craft, it can be annoying thou at times, when you have to get your hex wrench out just to take the blade loose while you do Fretwork.
A quick fix that I came up with for that. Go to your Hardware Store and Purchase the same Thread count for a Thumb Screw or Wing nut Bolt, and replace the hex screw with a Thumb Screw, you converted it quickly to a Quick release.
This machine was only $130.00, which wasn’t a bad purchase, it has a Cast Iron Table also, the only other thing I don’t care much about the table, is there is about 1 1/2” by 1/2 Gap for the blade, Makes it hard to work on Fretwork with the Consistent Vibrations and all, So a quick fix with a Piece of Cardboard and some Packing Tape. Which also helps Make the Table Slicker for ease of piece movement along the table top.
This concludes my Review on this Piece of Fine Machinery, I hope this helps everyone that is looking to buy a Scroll Saw, especially the 16” Craftsman from Sears.
Handi
-- Jimmy "Handi" Warner, http://jwarner75.etsy.com, http://handisworkshop.blogspot.com
View jwarner75's profile
jwarner75
251 posts in 371 days
2 comments so far
View mtnwild's profile
mtnwild
2021 posts in 424 days
posted 367 days ago
Thanks for that. I do not have a scroll saw, but when I go to look I’ll keep what you said in mind. Those were good points and as a beginner I probably would never have thought to look for those things.
View Greg's profile
Greg
131 posts in 355 days
posted 187 days ago
I used a piece of 1/8” baltic birch on my Hitachi scroll saw to make a zero clearance insert. Card stock will also work, depending on the depth of the hole for the insert, also mine is round which made it easier, I’m not familiar with the craftsmans saws so the plywood may not work for you. Check out my website there are links to several good scroll saw forums on there.
Greg
www.joesawdust.com
-- Greg S.E. Ga. www.joesawdust.com
