Lathe Duplicator for Mini Lathes
Review by Karson posted 224 days ago 1853 views 0 times favorited 13 comments Add to Favorites Watch
Lathe Duplicator for Mini Lathes No-picture-s No-picture-s Click the pictures to enlarge them
I’ve got this Penn State Lathe Duplicator I have mine mounted on a Ryobi Mini Lathe. I believe that it works for many brands.
It’s not an all inclusive duplicator like the Vega. If you can make a pattern in something about 1/16” thick then you can fit it into the holding mechanism. Here are the Penn State templates
This is a brass pattern of a small spindle that I’m making. The spindles are for a Vintage Sleigh I’m making.
You mount your blank in the lathe.
And turn it down. This is a rough turn that then needs to be sanded smooth.
The cutter is either a High Speed Steel or a carbide cutter. I make mine out of solid Carbide router bits. Cheaper than buying theirs. But then you need to be able to sharpen carbide. I use a cutter in my Dremel style tool to cut them down to size and a green wheel to sharpen the carbide and then a diamond sharpening stone to get it smooth.
Sanded smooth.
Eight spindles taking about 5 minutes each. And all the same design. 4 Cherry and 4 Sapele
A great tool for making pens and other small turnings that need to be the same.
-- Karson Southern Delaware karson_morrison@bigfoot.com †
21155 posts in 1152 days
13 comments so far
Douglas Bordner
3316 posts in 815 days
posted 224 days ago
Is it hard to calibrate/center and square to the ways? Thanks for the pictures.
View Dusty56's profile
Dusty56
2769 posts in 439 days
posted 224 days ago
Another excellent review ! Thank you very much , Karson . I wonder if it will fit my JET mini lathe as well …...Oops , Nevermind , JET has their own special jig …thanks for posting this and have a great weekend : )
http://www.pennstateind.com/store/CML-DUPJ.html
-- You know you're getting old when you know the difference between you're (you are) and your (belongs to you) AND how to use them in a sentence .
View Napaman's profile
Napaman
2820 posts in 828 days
posted 224 days ago
that is amazing…i clicked on the PSI template link…I am not sure I “get” how it duplicates…does it run on an patter and is automatic??? or are you controlling it…
BTW…get ready for lots of bottle stoppers this weekend!!!
-- Matt, Napa, CA...sanity...has arrived...JUNE-JULY-AUGUST...
View doyoulikegumwood's profile (online now)
doyoulikegumwood
199 posts in 743 days
posted 224 days ago
you push in on the back of it and move it back and forth kindof like making a key i think
-- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more
View rikkor's profile
rikkor
11345 posts in 626 days
posted 224 days ago
Thanks for the posting Karson. I may have to get one of these.
View Russel's profile
Russel
1769 posts in 690 days
posted 224 days ago
I looked at these when I bought my Penn State lathe, but wasn’t quite sure. Thanks for the review, it looks like it could be a useful tool.
posted 224 days ago
It’s all hand operated. Your hand pushes it in and slides it along the pattern. You basicly push in as you follow the template. But you don’t want to cut too much because the small pieces of wood bend easily and you won’t have a true copy.
I sharpen up the carbide cutter by honing it against a small Diamond hone that I carry in my pocket in a leather pouch. I sharpen kitchen knives and pocket knives with it usually.
View lew's profile
lew
3701 posts in 507 days
posted 224 days ago
Karson,
Thanks for the information and pictures. It looks like the duplicator does an excellent job and very quickly, too.
Looks like you are taking advantage of the the Mrs. “kitchen good mood” to acquire some new toys! How many more do you think she will let you get? :^)
Lew
posted 224 days ago
Douglas: To calibrate the jig to the center line of the lathe. (The center of the chuck and the center of the live center) It’s quite easy.
You chuck a piece of wood in the lathe, longer the better. Without any templates in the duplicator you turn a spot on each end of the piece of wood. You want to make sure it’s round and not just take off the corners.
You then measure the diam or the two spots. If different then you lightly tap the base of the duplicator to slide in on the spot that is thicker. You want to go in 1/2 the distance of the difference. If you get within a couple of thousands you might stop or you could be anal about it and make it right on.
The stylus that is under the cutter is what follows the template.
It is what follows the template. Some one mentioned like making a key. Very good analogy. The stylus should have the same shape of the cutter. If the stylus is round you could never get sharp corners. But with a “V” shape stylus and a “V” shape cutter you always get a slope at the edge You would need to us your own tools to do a parting or a 90 deg edge.
The stylus is moved in and out to control the size of your piece you are making. If my stylus was further out then the piece being made would be bigger, but have the same profile.
When I’m making pens I adjust the stylus so that the cutter just clears the metal pen adjustment blocks that control the size of the pen. I don’t want my cutter hitting the metal. I’ll sand down to the correct size.
I’ve noticed that the two ends of the template that I made are a little different shape. I could adjust the template by filing, or I can use sandpaper at finishing time to make the two ends of my turning look the same.
If I needed to move the bead shape than I’d have to make a new template.
posted 224 days ago
Lew these were old tools. When I started making pens.
The cane lathe is the new one.
12048 posts in 602 days
posted 222 days ago
Very nifty Karson & all the same, thats the great benefit.
View JonJ's profile
JonJ
99 posts in 591 days
posted 221 days ago
Thanks Karson! I am (still) getting ready to build another mechanically bowed keyboard instrument that will use an endless belt on rollers, and I’m going to have to make at least 60 tiny wooden rollers to guide the belt at each string. For my test prototypes, I’ve been doing 1 at a time, but this style duplicator is perfect for when I have to do them all. The most helpful thing for me though is the idea about the old router bits…I have several broken ones, plus some bent saw blades I can “pull thier teeth”. I love to use broken stuff to build new stuff!
-- Jon
View Jeffrey P.'s profile
Jeffrey P.
12 posts in 147 days
posted 138 days ago
I have had one for years and it works very well I use it on a CarbaTech Lathe have made several hour glasses and it did very well. A handi attachment but then that is what is fun about lathes all the endless gizmos.
Happy Turning
-- Jeffrey P
Bookmark And Share This Page
