DAILY DEALS Rockler 3-Pc. Roundover/Beading Bit Set at Rockler  |  DeWalt Gauge Narrow Crown Stapler at Tool King
LUBRICANT
Review by SP8 posted 353 days ago 436 views 0 times favorited 9 comments Add to Favorites Watch
LUBRICANT No-picture-s No-picture-s Click the pictures to enlarge them
My S.I.L. works at a chemical plant in Yazoo City Mississippi. They use a lubricant there caller kroil. The only place that I know of that it can be bought is direct from the factory which is KANO labs located in TN. I ordered some and believe it is twice as good as WD40. Check out the web site http://www.kanolabs.com. I believe that if you try it you too will be h
-- R K SP8 "The 10 Commandments are NOT multiple choices"
View SP8's profile
SP8
16 posts in 438 days
9 comments so far
View rickylee's profile
rickylee
1 post in 578 days
posted 353 days ago
Great stuff, I have used it for the past 25 years up in Wis.
View CessnaPilotBarry's profile
CessnaPilotBarry
1224 posts in 581 days
posted 353 days ago
Lots of things are better than WD-40… For instance, PB Blaster for freeing stuck bolts.
I’ve heard GREAT things about Kroil, but have never been able to buy some here in CT. How much was it where you buy it?
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View knothead's profile
knothead
47 posts in 826 days
posted 353 days ago
If you work on cars or trucks you will find this indispensable – I am an aircraft mechanic for a large airline and have had access to this stuff for nearly 20 years. A couple of years ago I was changing a head gasket on my daughters car and was unable to break the exhaust manifold bolts and the manifold to pipe connection. tried for days, then sprayed kroil on them twice a day for two days and then removed the nuts and bolts with a standard ratchet and socket. GOOD STUFF!!!
-- So Much Wood - So Little Time! --
View Steve2's profile
Steve2
48 posts in 449 days
posted 353 days ago
Your comment says twice as good as WD-40…. as Barry says, lots of things (understatement) are – for some reason WD is a name everywhere but try Ti-Flo added to the list of better than…
-- Regards, Steve2
View SP8's profile
SP8
posted 353 days ago
Check the above web site. If you buy a can, they will give you a free can of your choice. Even though it is a little pricey the free can makes up for it.
View Paul 's profile
Paul
117 posts in 468 days
posted 352 days ago
Anyone want to split a 55 gallon drum with me?
-- Paul, La Center, Washington
View jlsmitty's profile
jlsmitty
11 posts in 489 days
posted 352 days ago
I , in another life, serviced office machines (when they were still machines). I agree with Steve2 that Triflo is the best oil there is. For most things, not all, WD 40 is the worst. A friend of mine said that WD worked well on adding machines, which it did for a short time and it would set up like varnish, I had a terrible tiime.
Smitty
View Phil53's profile (online now)
Phil53
9 posts in 501 days
posted 255 days ago
WD-40 is not a lubricant it was made to dissipate water, and it is good for that.
CessnaPilotBarry
posted 255 days ago
“WD-40 is not a lubricant it was made to dissipate water, and it is good for that.”
I agree, but did you ever read the can?
