| Review by Karson | posted 368 days ago | 1305 views | 0 times favorited | 11 comments | ![]() |
I bought this lathe to make a cane for my Mother-in-Law. I had a small Ryobi lathe that I used for making pens but it only had around 16” length. Not enough room for a cane.
I bought the variable speed version from Penn State Industries because I felt that it would be easier to use. It comes with a belt drive and a 3 step pulley. You can change the belt drive to change the speeds. The variable speed gives you a range within each of the pulley ranges. The motor is Motor: 1/2HP (650-3800 RPM). I also bought the extension table.
The lathe set up OK, but, the castings were a tight fit for the tail stock when you wanted to span across the two sections of the bed. I had to take the tail stock off and file and sand the edges to get it to cross the barrier of the two sections. it is still not an easy slide so I’ll probably do it again. As I was using the lathe I noticed that the tool rest also had the same problem. I could force it but It will require modification to give me an easy slide from one end to the other.
I wish the tool rest was longer, but it was designed for the mini lathe and is OK for it. But a lot of movement for a 30” piece of wood.
The belt was quiet when I ran it at start up. After I moved the belt I was unable to get it to run quietly I swapped to the additional belt that they provided and it’s quiet. They said they’d send a new one but it hasn’t shown up yet.
A pretty good lathe for $300 bucks. I could have driven to get it but the gas and sales tax was more than the shipping.
I think I’ll made a ball bearing steady rest for it also.
11 comments so far
home | projects | blog
14915 posts in 743 days
posted 368 days ago
Sounds good value for the price Karson as long as you can put up with a few minor design faults.
lew
4475 posts in 648 days
posted 368 days ago
Don’t you just love it when you have to buy a new tool to complete a project!
I imagine after the kitchen project, the Mrs. didn’t complain too much about the purchase.
Lew
Dusty56
3458 posts in 580 days
posted 368 days ago
Newbie here …Karson , what is a ball bearing steady rest please ?
Richard Williams
142 posts in 685 days
posted 368 days ago
I saw one at Sears and it is about that price range and looks to be pretty nice. Try going to this web site and let me know what you think. I would not be making any canes for myself. :) Take care buddy. http://www.sears.com/shc/s/p_10153_12605_00990247000P?mv=rr
-- Rich, Nevada,
25795 posts in 1293 days
posted 368 days ago
Richard. The Jet lathe has a 24 point indexing pin. The design looks similiar. It does not have the extension, nor does it have variable speed. That version at Penn state is around $200.00. I believe that I have the hollow headstock so you could drill through the headstock to put a hole in the end of the wood. The jet states that it has a hollow tailstock. I don’t know if I have that.
posted 368 days ago
Dusty: It is a rest that holds long pieces of wood from flexing in the middle when using lathe tools. It’s purpose is to stabalize the wood so that it is turned truely round.
3034 posts in 914 days
posted 368 days ago
Nice chioce Karson.
I have always had a good feeling about Penn State stuff.
I’m sure you will put it to the test soon.
Good luck with the steady rest . You need one for thos long slender pieces.
itsme_timd
676 posts in 723 days
posted 368 days ago
Nice review Karson, I have this lathe as well and I noticed a few ‘quirks’ about it. I don’t have experience with others so I chalked it up to operator fault! Glad to see your opinion on this one, too.
-- Tim D. - Woodstock, GA
bake
38 posts in 570 days
posted 86 days ago
Karson, after nearly a year would you buy this one again?
Bake
-- The only thing wrong with instant gratification is that it's not fast enough.
Russel
2057 posts in 831 days
posted 86 days ago
I don’t know about Karson, but I bought my lathe from Penn State about the same time and I have nothing negative to say about it or Penn State. From my perspective, they’re products are good and they are a great company to do business with.
posted 86 days ago
The lathe has been great. No problems other thatn what i identified is the review.
