Ridgid JP0610 Jointer/Planer
Review by ferstler posted 410 days ago 5479 views 2 times favorited 21 comments Add to Favorites Watch
Ridgid JP0610 Jointer/Planer Ridgid JP0610 Jointer/Planer No-picture-s Click the pictures to enlarge them
OK, before I purchased the JP0610 I owned a 30-inch Delta JT160 tabletop jointer/planer. (Shown to the right in the wider-angle photo.) I still have the thing and now store it on a shelf where it can be quickly hauled out onto my shop’s workdeck for rough-and-tumble work that does not involve longer boards.
The 45-inch-bed Ridgid JP unit has replaced it as a precision tool (some have complained of table alignment problems, but mine seems perfect in that respect), and of course the new unit has a built-in stand. It is a pretty basic jointer/planer, with outfeed table star wheel and lock screws for that end of the cast-iron table assembly and a hand crank to allow for quick adjustment of the infeed table. The table tops are very well finished and I found no misalignment issues once I had the unit assembled. Assembly itself was rather simple, and the fence was also perfectly aligned (leveled) and went into place with no hangups. The assembled machine weighs a tad more than 200 pounds.
The manual is pretty good about dealing out instructions, but I do recommend making sure that the two pullies are not only set up properly in terms of vertical tension but are also parallel to each other and in front-to-rear alignment. The manual mentions the vertical alignment requirement but does not mention the parallelism issue. Adjustments for in/out alignment can be made by moving either the motor or the table assembly, but adjustments for parallelism can only be made by moving the motor before tightening the motor-mount screws. Only basic hand tools are needed to assemble the tool. The tool also came with a comprehensive parts breakdown list, typical with Ridgid tools.
The manual suggests mounting the motor with the assembly flipped upside down, but it also mentions that tensioning the belt can also be done with the assembly rightside up – using gravity to do the tensioning. I followed the latter suggestion, but one must remember that the motor is heavy enough to put too much tension on the belt. Care must be applied to get the belt deflection to the 1-inch point the manual suggests.
I modify nearly all of my tools, and this one was no exception. The amount of “editing” was more than what I did with the Ridgid sliding compound miter saw I will review elsewhere and considerably less than what I did with the company’s band saw, also slated to be reviewed by me.
First, I installed it on a mobile wooden platform under the unit’s metal stand. (See photo.) This helped to stiffen up the entire lower assembly. The platform sits on 4-inch wheels, each of which can swivel. Doing this not only allows me to move the unit out onto my shop’s outdoor workdeck but also gets the cast-iron table surface 6 inches further off of the floor. I like my worksurfaces to be rather high up. To stablize the base when using the tool I built two large wooden “chocks” that I can push under one end of the platform to keep the unit solidly against the floor at four contact points and from moving about as I slide workpieces along the table. Note that for maximum tipping resistance the base had to be large enough for the wheel contact points to be outboard of the stand contact points.
Second, the motor mounts to oval-shape cutouts in the bottom of the dust chute. The motor chassis does not cover the holes completely, which will allow woodchips to drop into the motor area. To combat this I put pieces of clear packing tape over the cutouts inside of the dust chute after mounting the motor. This reduces the amount of dust dropping onto the motor itself.
Third, I initially replaced the stock belt with one that I picked up at an auto parts store. I did the same thing with my 14-inch Ridgid band saw (also reviewed on this review site), but in the case of the jointer/planer the belt that came with the product was not as weird as the one that came with the saw. Indeed, the stock belt seemed reasonably well made, but it still seemed a tad too stiff for my taste and for a while at least that much more flexible (and American made) segmented belt remained installed. However, I later on went back to the stock belt, because that flexible and segmented automotive grade belt I tended to oscillate too much, generating its own weird vibrations to the chassis.
Fourth, the unit has a four-inch dust port on the left side of the stand. (The port assembly can be removed so that gravity can pull chips down the square chute to the floor if one cares to do things that way.) All of my other tools have ports that are 2.5 inches or smaller, so my dust-collector device (which is simple, uses no bag, and simply blasts dust out into my “natural” yard area) has a 4-inch to 2.5-inch adaptor solidly attached to the end of the 4-inch hose. To facilitate the use of this adaptor I installed a similar adaptor to the 4-inch port on the jointer. The reduced air flow from the neck-down configuration has not resulted in dust piling up inside of the tool’s dust chute.
Finally, the unit has two vertical cutouts on one end of the metal stand (the end opposite the dust-port) where one can store the two push blocks that came with it. When in place they tend to rattle and so I store them on a shelf next to where the device is parked when it is inside of my small shop. To make use of the two cutouts I installed a very solid wooden handle that lets me more easily manhandle the unit out onto the deck. I can do this by grasping the table assembly, of course, but I prefer to not use that part of the jointer as a handle. The added handle works fine and there is more than enough clearance between it and the outfeed table crank.
I like this jointer/planer. It runs smooth and cuts true. It is easy to adjust and after running through dozens of feet of wood the blades still seem dangerously sharp. I ordered spare blades from Ridgid ($10 bucks apiece for three, a not-bad price) and will use them when honing the blades that came with the unit no longer is viable.
Certainly a jointer/planer with a longer bed would work better with longer boards than the 45-inch Ridgid, but it would probably be so heavy that I could not wrestle it out onto my workdeck. It would also cost more. The Ridgid unit was listed at $399 at Home Depot but I talked to a clerk about that price (up from the $349 it had been a few months before), and he knocked it back down to $349. I think they are selling the thing for $450 these days.
Howard Ferstler
View ferstler's profile
ferstler
138 posts in 417 days
21 comments so far
View bbqking's profile
bbqking
332 posts in 620 days
posted 410 days ago
Congratulations. I own the same planer and totally agree with the 5 star rating. It is a shop workhorse and I have never had any trouble with it since straight from the box. I own other Ridgid equipment and this seems to always to be the case. They always work great. Note- I had mine moved over 1000 miles by a relocation firm, carted all over the east coast on its way to Georgia, carried around the house and into the basement shop. When I had it where I wanted it, I plugged it in and ran a board through. No adjustment necessary. Amazing. bbqKing.
-- bbqKing, Lawrenceville
View bayouman's profile
bayouman
86 posts in 562 days
posted 408 days ago
I agree with the bbqking. Mine is an excellent machine and it gets a sizable amount of work. I buy almost all of my material in the rough and mill it to what I need. I couldn’t do that without my Ridgid joiner. It has already saved me enough money to pay for itself.
View Emeralds's profile
Emeralds
155 posts in 459 days
posted 408 days ago
I too own the same the jointer and it’s been a great asset to my shop. I would also rate it as 5 star unit.
-- JMP
View CessnaPilotBarry's profile
CessnaPilotBarry
1285 posts in 599 days
posted 407 days ago
I had the same tool and would rate it highly. Mine provided stellar service.
I replaced mine when I stumbled upon a “clearance” non-X5 Delta DJ-20 for $1000, brand new.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View laflaone's profile
laflaone
57 posts in 577 days
posted 406 days ago
I may sound like a broken record, but I have the same jointer, and I love it. My base is similar: A piece of MDF to match the jointer base, then two 2×4’s which extend out 3” or so on each side, then rollers. It raises the jointer up to a decent height, and eliminates the problem of it being tippy. Only one complaint. The blade guard will allow something slightly under 3/4” to slide under it. Now, I would be uncomfortable jointing something 1/2” on less, but there still is a lot of dimensioned lumber that could stand a bit of jointing and planing. I have solved the problem, but I am afraid OSHA would come after me if I revealed how.
-- "non illegitimis carborundum"
View mot's profile
mot
4903 posts in 933 days
posted 406 days ago
Nice review. I have the same jointer and have had good use from it.
View kansas's profile
kansas
79 posts in 598 days
posted 404 days ago
I bought mine from a outlet store selling reconditioned tools. I got it for $270 but it needed a belt, the nut for the big bolt that tightens the fence was gone and the key for the switch was also missing. I’m a cheapskate so I made do. It seems to have a bit of a table concern if you set the fence close to the guard. I’ve fiddled with it a lot and can’t seem to make it any better. Someday I hope to replace it with a better machine but the price was right and it’s did a lot of work.
View MikeGCNY's profile
MikeGCNY
3 posts in 391 days
posted 391 days ago
I was at HD last night and noticed this jointer is on sale for $301.00. I had a 10% off coupon and picked it up for $270.00 plus tax.
Setup was a breeze, and it seems to be fairly well aligned out of the box. I did have one issue lining up the bolt holes of the motor support and the base.
Just bring someone with you to pick it up. I was alone when I noticed it on sale and had to wrestle it onto a cart and lift it into my car.
View Thos. Angle's profile
Thos. Angle
4013 posts in 859 days
posted 376 days ago
Me too. I just wish it was 12 inches wide and had a 9 foot table.
-- Thos. Angle
View glassyeyes's profile
glassyeyes
31 posts in 226 days
posted 187 days ago
I have to give it five thumbs up, too! (My wife tells me I’m all thumbs, but she exaggerates.) I don’t have a first-class straightedge, but the infeed and outfeed tables seemed quite flat, and parallel. The only adjustment I had to make was to raise the outfeed table a few thousandths to match the blades. It does seem to spew a bit of dust, but a better dust collector (next on my list) may improve that. I had the Delta benchtop, but the fence simply flexed too much, the aluminum makes it hard to use magnetic-based gauges, and setting the knives was fairly finicky work.
-- Now, where did I put those bandaids?
View Chris Lawrence's profile
Chris Lawrence
4 posts in 130 days
posted 127 days ago
I just bought this same jointer last night. I’m wondering if you could provide more pix and details of your mobile base.
Thanks,
Chris
-- - you mean I have to set up each and every new tool I buy?
ferstler
posted 127 days ago
Hi, Chris,
The photo I posted shows pretty much all of the details count. Note that in the picture the wood-colored items on the wooden stand and under the planer base are movable “chocks” that I use to wedge/stabilize the base when the unit is in use. I store them in that area.
First, I built a rectangular frame out of 2×4 sections and then screwed and glued a piece of 3/4 inch plywood to the top of that frame. The resulting frame/plywood base is maybe 3-4 inches wider and longer than the outer footprint of the planer base. I painted the thing with a grey, fast-drying primer, and (after the paint dried) I then screwed 4-inch, 125-pound rated, soft-tire wheels underneath to the four corners. I previously had used 3-inch, hard-tire wheels, but they were just too awkward handling and bounced the unit too much on my wooden deck outside. The 4-inchers allow for much easier rolling than those 3 inchers and glide smoothly. Then, I just screwed the metal planer base to the top of the wood stand using thick wood screws driven down through the same holes on the bottom tips that normally would use the adjustable feet that came with the unit, and through the plywood and into the 2×4s. I had a buddy of mine help me hoist the assembled planer onto the stand before doing the screw work.
Job done.
PS: it is important to have the vertical wheel axes be at the same point or a bit outside of the ends of the stand legs where they hit the stand. Otherwise, the assembly will have a tendency to tip too easily. If I had it to do over again I would have built the wooden bass a couple of inches wider and longer to get better stability. What I have now is fine, however.
Howard Ferstler
Chris Lawrence
4 posts in 130 days
posted 127 days ago
Hello Howard,
Thank you so much for your help with this. That’s a pretty through description and I am looking forward to taking your advice on building this base.
-Chris
View KTMM's profile
KTMM
13 posts in 90 days
posted 90 days ago
I got this jointer yesterday at the North Jackson (MS) store for 214.00 I have a store near me, but they were sold out two days ago after marking the unit down to 321.00 I don’t know if they’ve lowered the price that much or if they’re closing it out. Just thought I’d post so you guys might can make your local store price match…...
I would have put the thing together last night, but I was too busy putting my new table saw together.
View GuyK's profile
GuyK
142 posts in 976 days
posted 74 days ago
I just bought this jointer. It is a great addition to my shop. Well made and easy to put together. Only caution I would have for anyone buying it is that in the assembly directions it tells you to get help to lift it. I didn’t and pulled some muscles. So pay attention to the directions. As for the machine it self the tables are aligned and near perfect. The power is great. I was very inpressed with the quality of the fit. I also bought the Ridgid oscilating sander (spelling) another great tool.
I was also thinking of building a mobile base for it, so off I went to HF for some wheels. When in HF I noticed they had “Furniture Dollys ” for $ 16.99, they hold 1000lbs so I bought one of those instead of buying wheels and having to come home and build one. Works perfectly.
-- Guy Kroll
16928 posts in 474 days
posted 74 days ago
Thanks for the review
View NBeener's profile
NBeener
385 posts in 70 days
posted 65 days ago
Howard-
A thousand thank you’s.
As some may know, I’m fairly new to ww. As I embark on buying the essential tools, it became obvious that a jointer-planer is among them.
A minute on my local Craigslist turned up this exact unit, a few months old, and with an asking price of roughly $100 below HD’s current price (probably negotiable, too).
My brother—former Ridgid rep—said it’s a great unit, but … your review is comprehensive, intelligent, information-dense, and answers questions that I’d never have even /thought/ to ask.
Tomorrow night, I head down there to look at it … combination square in hand. If it looks as good as it should, I’ll leave a deposit and—not being as dumb as I look—go back with a friend and a rental van ;-)
I love this site. Thanks for providing just one more good reason why….
Neil
-- -- Neil
NBeener
posted 47 days ago
For the record … I bought one, brand new, at HD instead, and set it up today.
1) Damned thing is heavy!
2) Twice, I wished for an extra joint in my arm to tighten the motor to the assembly, but … no worries
3) Realistically, the setup was a breeze/instructions were perfect. They blister-packed, with cutouts and labels, all the hardware. EVERYTHING was there, and absolutely simple to put hands on;
4) Maybe 45 min from all-unpacked to power up :-)
5) It’s not quite as bad as “I don’t know why I bought this thing,” but it IS fair to say I’ve never used one before. Now that I’ve done a few laps with it … I totally get it. Cool!!
I also picked up about five bucks worth of cull at the Depot, and … 15 minutes ago … turned fifty-one cents worth of cull into about three bucks worth of S4S!!!
This is a pretty slick unit :-)
Tomorrow will be all the true tuning and alignment stuff, but … first glance looked awfully damned good.
I like it. I like it a lot. Gotta’ either get a true DC unit now (eyeballing one of the HF units), or—at the very least—a 2 1/2” > 4” adapter to get down to my ShopVac. This thing can make it snow!
-- -- Neil
ferstler
posted 46 days ago
Note that a jointer can fill up a shop vac with dust and cuttings pretty fast. You might consider getting one of those adapter units that shunt most of the heavy chips to a separate container, with only the finer stuff going to the vac container. Grizzly and Rockler both sell them.
Luckily, I work adjacent to a wooded area and use a cheap dust collector to just blow the cuttings out into the yard area. Nature and termites take care of the rest, although after a while I might have to use a rake to scatter things a bit further.
Howard Ferstler
25803 posts in 1297 days
posted 46 days ago
Great review. Thanks.
NBeener
posted 46 days ago
You’re sure right about that, Howard. Did my first empty today!
May look into the separator/cyclone sort of thing … or … a legit DC system.
For now, though, I ordered a 4” > 2 1/2” adaptor so I can keep throwing the Shop Vac at it. I’m just gonna’ dump all the shavings into the back yard. At some point, it WILL look nice :-)
-- -- Neil
