| Review by Mike Lingenfelter | posted 305 days ago | 333 views | 0 times favorited | 4 comments | ![]() |
- Lie-Nielsen Skew Block Plane
- Brand: Lie-Nielsen | Category: Hand Planes
This Skewed Block Plane can be used for many operations. It can be used to work on end-grain, like a standard block plane. It has a fence and nicker so that you can work on tenons and rabbets. The nicker can be moved so that it is engaged or not. I’ve used it to clean up some tenons and it work beautiful. The skew blade really helps to reduce tear-out when going across the grain. I haven’t added an auxiliary fence to mine yet, but it’s coming soon.
It come in Iron or Bronze and as a left or right skew. They call them left and right handed, but it’s really just which way the blade is skewed. Ideally you would have both, depending on which direction you need to go. So far I only have one of them.
4 comments so far
home | projects | blog
13162 posts in 928 days
posted 305 days ago
Great looking plane Mike. I’ve seen the advertisements.
rikkor
8344 posts in 402 days
posted 305 days ago
I think if it is from Lie-Nielsen it is a winner out of the box. They are like male jewelry.
-- Maplewood, MN
MinnesotaMick
15 posts in 287 days
posted 286 days ago
Any trouble sharpening the skewed iron??
Mike Lingenfelter
403 posts in 641 days
posted 286 days ago
No real problems. I use honing guides to help with my sharpening. With the skewed iron you have to use a jig that lets you skew it. For my skewed blades and chisels I use my VERITAS MK. II Honing Guide.
-- http://theinquisitivewoodworker.com/
