| Review by tooldad | posted 66 days ago | 945 views | 1 time favorited | 13 comments | ![]() |
- Grizzly G0490X 3HP 8 in jointer w/ mobile base
- Brand: Grizzly | Category: Jointers
It is not too often someone other than a writer from a woodworking magazine gets to buy 2 different models of the same tool and compare them. I looked through the Grizzly catalog and website and did some paper comparision. I chose the G0586 for the school shop. It was $100 cheaper and had handwheel adjustments for both the tables and the fence.
Once I got down to Springfield to pickup the tools, I went shopping for myself (this was planned) My first intention was to get the same jointer that I was getting for the school shop, for myself also. I haven’t been a big fan of the lever table adjustments. Honestly because the one that the shop had before (delta) the kids abused. However some of that is the previous instructor’s attitude, unfortunately. I got to try the levers, and they work great. I like the bigger base cabinet. I only wish they would have incorporated a storage compartment for the wrenches and manual since is mostly dead space inside except for the starter switch box and the dust shoot. I just put the wrenches in a heavy duty ziplock and duct taped them inside. Won’t need them until a blade change.
The fence is taller and longer on the 490. Often time students forget to lock the fence and the handwheel adjustment basically locks itself therefore not needing to worry about that lever getting lost as it did on our delta. The 586 is the one with the smaller handwheel fence.
Both jointers have a control box that is up above and easier to access. I like that feature. The 586 has a 3 system switch, a stop button, power light, and start button. The 490 has just a stop button (with light built in) and a start button (with green light). I like the 586 control box better for one simple reason. When the jointer is locked off, there is no red light on. When the jointer is in what I call neutral, where the stop button has been unlocked, the red light comes on, then you press the green button to start, red button to stop as normal. When you hit the stop button, the red light goes off.
On the 490 when the tool is in the locked off position, the red light is on, as you can see in the pics. When the tool is in “neutral” there are no lights on. When the tool is running, the green light is lit. Not a big deal but my preference is for the switch on the 586.
490 = 3hp motor, 586 = 2 hp motor, bigger motor is usually better, however requires more amperage. The 586 can be wired 110v, where the 490 is 220 only. That may be a consideration for some.
490 has built in mobile base, great in my home shop (24×24). I could have seen all kinds of teenage ingeniuty with a roller base at a high school shop. However it would have been nice for end of year cleaning when we move most of the tools and sweep and vac everywhere.
Fence took a little bit of setup on the 490, fence and table came all as one on the 586, however it was heavier to lift. Either way, you will need a helper or 2 to get the table and fence on top of the base cabinet.
Much easier to work on installing belts, mounting table to cabinet on the 490. The front and back covers came off exposing inside of cabinet. 586 you had to reach inside the dust shoot practically. The electrical box on the 586 is outside the cabinet, where it is inside on the 490. it is outside on the 586 to allow for handwheel room.
The 586 is $100 cheaper in the regular blade model at $695. The 490 is $795. Shipping is same
However with the spiral head, the 586 is 1095, where the 490 is 1075. a wash there.
I would go with the 490 again with the spiral head. I do a lot of face jointing when making cabinet doors. That sprial head is worth the $400. Also changing blades, may take a little longer if you were to do all, but there is no indexing with a knife guide. Already indexed for you.
The 490 is simply a twin to the delta DJ20. That is the older one we have at school. The only upgrades are the top mounted switch pedastal, and the roller base, both nice add ons.
13 comments so far
RDS1
home | projects | blog
26 posts in 152 days
posted 66 days ago
I think that I have the same jointer, i got it with the spiral head which is sweet. I still like the handwheels, guess I’m old school. I do like the higher fence, but I use a power feed & the taller fence can get in the way. Good luck.
-- Bob Schilke
John Gray
886 posts in 426 days
posted 66 days ago
Very nice review. THANKS!!!
BeechPilotBarry
418 posts in 243 days
posted 66 days ago
Nice review!
I’ve owned machines with both styles of adjusters and prefer levers myself.
-- - Real men read directions
GaryK
8567 posts in 528 days
posted 66 days ago
Great review!
How good of a job does it do?
Jeff Kochosky
8 posts in 71 days
posted 66 days ago
I’m starting to look at putting together a small workshop at home, and Grizzly is one of the companies that I’m taking a serious look at for their equipment. Thank you for the excellent review!
-- Jeff Kochosky, Professional Novice Woodworker...
DaveH
275 posts in 319 days
posted 66 days ago
I bought the Grizzly G0565 awhile back and have had no problems.
Thanks for the review!
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
Chris
1261 posts in 531 days
posted 65 days ago
I have wondered about the Grizzly jointer’s for a while now as that will be my next power tool purchase. How are they in use? Especially as compared to the DJ20 yo mentioned earlier….
-- Chris
CedarFreakCarl
403 posts in 594 days
posted 65 days ago
That’s a great comparison/review. I just ordered the GX490 w/spiral cutter head last Friday and picked it up today at UPS. I can’t believe how fast it got here. It’s on my trailer outside the shop even as we speak and I’ve got to go round up some Egyptians to help me unload it. I’ll let you know how it goes. Thanks!
-- Carl Rast, Pelion, SC
tooldad
197 posts in 255 days
posted 65 days ago
I am impressed with the bang for the buck that grizzly provides. All in all, I still prefer a powermatic or delta. But on a teacher’s salary, you either can get one powermatic tool, or several grizzly tool.
My previous jointer was the grizzly 6”, not sure of the model number, but I found the recipt and gave it to another teacher when he bought it from me. I paid $350 back in 2002. Never even changed the blades. I face jointed several bd ft of oak for cabinet doors, and just about every project I put together, I used the jointer. I did end up with a knick or two, but could work around them by moving the fence or just planing both sides once I had a flat surface.
My only regret back in 2002 was not getting the 8” model. However I did sell the 6” for $250, not too bad.
I love the sprial head. We ordered 2 planers, one last year 20” and one this year 15” both with sprials. We had the 3ph 20” for 12 years and instead of replacing the head for about a grand, I convinced administration to let me get the newer planer and sold the old on ebay for $500 to help pay for some of it.
My next review will be on the spiral head planers both 15” and 20”.
Huckleberry
73 posts in 393 days
posted 64 days ago
We have the 10” version of this one in our shop and I really like it. Thanks for the review.
-- Something that goes unnoticed will never be remembered.
jaxx
32 posts in 57 days
posted 57 days ago
amazing prices, in spain this would cost 3 times the price.
matt garcia
229 posts in 212 days
posted 57 days ago
I own a Grizzly G0586, and purchased the spiral carbide cutterhead also. I love mine!! What a workhorse it is, and man what a great price!! Sure does make a bunch of chips!!
-- Matt, Houston Texas
James Lango
60 posts in 74 days
posted 53 days ago
I love Grizzly’s woodworking tools. I highly recommend them to anyone who is looking for serious equipment. Something to look at> My cheap little Grizzly 12” planer is made in China, whereas all their better equipment is made in Taiwan (my Tablesaw). IMO China is the “new” Taiwan. Taiwan industrialized in the late 70’s, and since have much improved their machining qualities to a very high standard. Makes you wonder about the whole marketing concept behind it.
Grizzly puts their name on the cheaper/lesser quality tools and has them manufactored in China. When it comes to the larger machines and equipment they make no sacrifices and build in Taiwan. When I or someone I know is thinking about a new machine, I highly recommend Grizzly tools.
Seems not many people know about Grizzly because they spend less on advertising compared to Delta, Jet, Ridgid, and Dewalt. Their woodworking tools are much less expensive and just as good-or better then the “big guys”.
I would also place PowerMatic in the same category(although i own none). Same goes for hand tools such as SnapOn. The better quality tool manufactors spend less on advertising and more on development, compensation, and employee benifits.
Just my 2cents from a happy Grizzly owner.
-- Longovette@alltel.net
