| Review by SPalm | posted 441 days ago | 3308 views | 1 time favorited | 26 comments | ![]() |
I bought a Steel City 35670 tablesaw a couple of weeks ago and have been able to play with it some. Here are a few of my thoughts.
Packaging
I picked up the saw at Woodcraft in a small pickup truck. They loaded with a forklift as it is over 400 pounds. There were also a couple of other boxes that contained the fence. When I got it home, four people where able to slide it back and lower it to the ground. I then took off the cardboard and the found a square channel welded steel frame inside for protection. This unbolted from the bottom and lifted off. I had to hacksaw this frame to get it in the trash, but it was worth it. I then strapped it to a two wheeler and got it down the basement.
Assembly
The only things to assemble were the wings, the hand wheels, and the fence rail. I removed all of the shipping goo and cleaned it up. The paint job is excellent and the fit and finish is first rate. First thing was to bolt on the wings and adjust for them for level. There is a very nice feature here with leveling set screws under each bolt. By using an Allen wrench to adjust and a socket wrench to tighten, this usually frustrating job was actually fun (no shimming). There are solid cast wings for each side and a wooden table board with laminate for the far right wing. This wing will get a router plate soon. Then I bolted on the fence runners. This also was quite easy and adjustable. One caution here is to get the fence runners absolutely level with the top. I used a Wixey digital angle indicator that made this a breeze. Then added the fence rail and measuring tape. The fence itself came preassembled.
Adjustment
All in all, it arrived very well adjusted. The ‘blade parallel to the miter slot’ adjustment was dead on. This is an easy adjustment if needed because the trunion is mounted inside the cabinet, so just loosen four bolts and swivel the table. Again, I did not have to do this. Backlash was undetectable. The blade tilt stops for 90 and 45 degrees are really, really nice. There is a hole for each in the top of the saw that accepts an Allen wrench. The fence was also easily adjustable with Allen screws for perpendicular, parallel to the miter slots, and height off of the table.
Splitter, Anti Kick Back Pawls, and Blade Guard
I am old school so these are new to me, but I promise to try to use them. It is all one assembly. It snaps into a slot behind the blade and then is tightened in place with a lock knob from behind the saw. It is very adjustable and also very easy to remove and install. So far I have been using it. I am used to Board Buddies and really like them but have not installed them on this fence yet.
Two Things I Don’t Like
But they are very minor. The clear plastic lens with the red line on the fence is way too high off of the ruler. Moving your head from left to right will yield different readings. I’ll add a spacer to this soon. Also the fence rides on the rear rail with a plastic foot. I guess this can also be a nice feature, as it slides quite easily. But it also holds the fence off of the table, and would make adding an out-feed table a bit more of a chore. It can easily be removed if I end up not liking it.
Thoughts
Nice saw. Highly recommend. 5 year warranty. It is really nice to have an actual cabinet saw. I bought the 1.75 horse, 30 inch model as it fits the best in my shop and I can run it off of 110 volts for the time being. They put some thought into adjustments and I like that. Dust collection is very good. The combo blade that comes with it seems to be as nice as any I have bought before. The Off switch is easy to find, but I always had it on the right hand side, so there is just a learning curve here. The T-slot miter gauge is as good as expected for standard issue. The fence is very nice, adjustable and solid. There are hooks on the cabinet for fence storage when it is not needed. The saw has plenty of power for me. I have cut some 2 inch beech and maple and it never resisted. It is quickly becoming one of my new best friends.
Steve
26 comments so far
EEngineer
home | projects | blog
275 posts in 508 days
posted 441 days ago
Nice review. It definitely does look like a nice saw! I have been hearing good things about Steel City for a while now.
The Off switch is easy to find, but I always had it on the right hand side, so there is just a learning curve here. I just recently rewired my saw and, after much deliberation, ended up with the power switch mounted very similarly. My reasoning was that I usually support and feed stock with my right hand and the left hand is free to turn on the saw. Also, if something panicky happens, my right hand is usually holding or supporting the stock so the left hand would be free to shut things down. After a coupla weeks like this, I won’t ever go back!
jm82435
508 posts in 637 days
posted 441 days ago
Congratulations on the new addition. Sounds like a very nice replacement for your old Craftsman. Getting 400lbs of saw downstairs safely sounds like an impressive feat in itself. We will be looking forward to seeing your finished stained glass tray now…
-- A thing of beauty is a joy forever...
GMman
1374 posts in 592 days
posted 441 days ago
Looks like a very good investment , looks like a very well build table saw. Craftsman tools I dont even look at them
-- --<<<<<< I will not stop until I get it right. >>>>>>--
DaveH
372 posts in 673 days
posted 441 days ago
Great review! I personally believe that the power switch belongs right where they put it. You should not have to reach over the work piece you are machining to hit the power switch.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
SPalm
948 posts in 777 days
posted 441 days ago
Yes, I agree the switch should be on the left. I am just not used to it there. I hope it to be a short learning curve.
(I was also hoping everyone forgot about that tray. Now I need to finish it.)
Actually from what I have heard, the new top of the line Craftsman was designed by the same guys that designed this saw. (?)
It is a left tilt saw.
SteveV
77 posts in 994 days
posted 441 days ago
I’ve got almost the same saw. I love it. I just don’t see why other saws are so expensive.
25801 posts in 1295 days
posted 441 days ago
Congratulations on the saw and the review.
20667 posts in 716 days
posted 441 days ago
Thanks for the review. I have been looking at the Steel City line since I need to upgrade my saw. I appreciate the info.
PurpLev
2752 posts in 543 days
posted 441 days ago
thanks for the review! that is a nice saw indeed. one of the few hybrids thats the trunion actually is connected to the cabinet which is a really nice thing. now if it had a riving knife – I’d get 2 of these tomorrow :)
3710 posts in 874 days
posted 441 days ago
Hi Steve;
For not being a rocket surgeon, that was a great review!
May you have many great years and projects with your new toy / tool!
I don’t know if you considered this before buying the saw, but you will no longer be able to “blame the saw”.
I guess it’s worth it though.
teenagewoodworker
2481 posts in 663 days
posted 441 days ago
looks nice! i really like Steel City’s product (can’t say the same about them) but i think they have a great product out there and it is definitely one of the best!
SPalm
posted 440 days ago
Hey Purp, you can get this saw with a riving knife for about $200 more. Also you can get it with a granite top. This model costs $1050. The granite top sounded really cool, but I did not want to layout the extra money for it and I was worried that I would spend too much time worrying about scratching something so beautiful. I believe all saws will have to use a riving knife if the future as U.L. certification will require it.
I don’t know whether to call this a hybrid or cabinet saw. Steel City calls it a cabinet saw, FWW calls it a hybrid. I guess the motor size is a consideration, but you can also get it with a 3hp motor. Either way, it fits my needs.
Lee, thanks for the reverse motivation. I already feel the pressure to get time in the shop, but life keeps getting in the way. Maybe winter will bring some opportunity.
PurpLev
posted 440 days ago
Crap SPalm – now I don’t have any excuses left – I gotta have me one of those.
It’s true – it is now a requirement of all new saws to be equipped with a riving knife! not sure why it took them so long, but I’m glad to see that they’ve finally put that on paper!
Enjoy your new toy, This one is definitely on the list as I don’t think I’ll ever need more than 1.75-2HP, and I like the fact that you can use it on ‘regular’ 110v circuits! that being said – do you run it on a 20Amp breaker? or 30amp?
SPalm
posted 440 days ago
I am embarrased to say, but I have it on a 20 amp circuit with an extention cord. No problem. It starts up nice and smooth. I also have my 1.5hp bandsaw and 2hp sander on the same e-cord with good results (not at the same time), so maybe I just got lucky. But I know the circuit will trip because it did a lot when my old saw’s motor died. I am in the basement right near the circuit panel and I guess this can only help. I planning on a new wiring scheme soon. So much to do, so little time.
JimJ
13 posts in 493 days
posted 440 days ago
Hey SPalm,
Glad to read your favorable review—reinforces my decision to buy the SC 35670 saw. Yesterday I received the same model saw, also from Woodcraft. Have just gotten it unpacked and out of the crate and onto its mobile base and ready for assembly.
I had mine delivered with tailgate service and my first impression was, “Wow, nice protective packaging!!” I have never seen an item packaged in a steel cage like that. Most of the time you see wooden skids, lots of foam, and heavy cardboard. There were no signs of shipping damage, although one of the steel “feet” was bent slightly.
My wife and I were able to get the saw off the steel platform and onto the mobile base by ourselves using some 2×6 and 2×4 scraps. Pretty good feat for a couple of smallish, well over 60, grandparents.
I will finish assembling the saw today or tomorrow. Hopefully I will have the same luck as you with the alignment, and should be able to make a couple of test cuts by tomorrow or Friday.
-- JimJ - Oakton, VA
Chris
1469 posts in 886 days
posted 439 days ago
Steve,
My General has the same beismyer style fence with the glide foot at the rear. On mine that foot is adjustable to account for just this sort of issues. Does yours adjust?
-- Chris
SPalm
posted 439 days ago
Yes it is height adjustable, as is the front of the fence, so you can get it to just barely skim over the saw surface.
I guess I should not have put this down as a negative because it is no big deal, just different. But I always had a Biesemeyer before and it had plastic slide feet that rested on the top of saw, not on the rear fence rail. In retrospect after several years of using it, I did have shiny bar marks on my top where it had slid.
Have you had any problems with dirt/debris on the back rail or tried to attach an out-feed table?
Chris
posted 439 days ago
I get some dust build up on the back rail but nothing major and have not built an outfeed table as yet.
-- Chris
GaryK
9522 posts in 883 days
posted 439 days ago
Great deal! Did you have a left tilt saw before?
Steve2
48 posts in 465 days
posted 438 days ago
The rear guide business is a non issue – all the better fences are like this. Just allow a space for the out feed table. I did just fine.
-- Regards, Steve2
SPalm
posted 438 days ago
Hey Gary, the left tilt is new to me. I like the concept.
Thanks Molly. It seems to work just fine. I guess I just need to get out more often.
Jason Gerard
3 posts in 469 days
posted 438 days ago
I have the Steel City 35675 which is the same saw except that it’s 3HP 220V only. It is an awesome saw. It’s the first cabinet saw I’ve owned. I had a Ryobi benchtop on a stand before but I’ve also used the Sawstop cabinet saw for awhile.
I will say that the Splitter/Guard assembly on the Sawstop was better. While the assembly on the SC is easy to take on and off, I didn’t feel it locked into place as well as the Sawstop. I really wish it was not one assembly, that they were separate pieces. That being said, I don’t use it anymore but instead have switched to a Leecraft zero clearance insert with the MicroJig splitter installed. I would prefer a riving knife but I was too impatient to wait.
All other aspects of the saw are excellent except for the dust collection. While the dust collector gets most of the chips, the power cord for the motor is pinned to the bottom of the cabinet where it slopes. This causes a lot of dust to build up and get trapped.
Perhaps I’ll repost this as a review with more info and pictures.
-- Jason Gerard, Jacksonville, FL
PurpLev
posted 438 days ago
PSalm, I was researching SS website looking for an optional riving knife for the hybrid saw, but couldn’t find anything as you suggested. were you referring to after market riving knife? or did you actually get to choose an option from SS to have a riving knife on your saw?
SPalm
posted 438 days ago
Hey Purp,
I have not seen it as an option or an upgrade. It is only available at time of purchase.
http://www.steelcitytoolworks.com/products_tools.cfm?section=2&category=12&tool=35900
1.75hp Cast Iron #35900
1.75hp Granite #35900G
3hp Cast Iron #35905
3hp Granite #35905G
Not sure if Woodcraft carries these yet (or will). But what do I know?
Steve
PurpLev
posted 438 days ago
Cool, thanx for the link!
Leo
2 posts in 386 days
posted 386 days ago
Well I wish I found this forum site earlier. I have been hunting around to find out info on SC and their saws. I have just made the plunge to get the 35685, basically, the 35675 just with a 50” fence. Wood Craft had a great deal and at $1099.99 with an additional 10% off bringing it to $989.99. Too good to pass up since the Grizzly I was looking at was consistently going downhill and in weighs and balances were not going in their direction. I am excited to get the saw it should be here in about a week they had to order it so check back and I’ll have more info for others.
