disappointed in Veritas
Review by libraryman posted 01-22-2015 04:21 PM 5474 views 0 times favorited 13 comments Add to Favorites Watch
disappointed in Veritas No-picture-s No-picture-s Click the pictures to enlarge them
My son presented with me with a Veritas low angle spokeshave for Christmas. We were going to use it for shaping an oak axe handle we had cut out. I initially tested it on Christmas day using some pine and cherry scraps around the shop. Worked great on this fairly soft wood. However when we later tried to shape the oak handle the problems began. The blade is held in place by two bolt heads which contact side bevels on the blade. The instructions for the shave say you need to sand the back of the blade to better hold the blade in place – which we did. After adjusting the blade with the mouth we proceeded to shape the handle. The blade quickly skewed and then dropped out. After reinserting the blade we really tightened down the bolt thumb nuts and tried again – same results. We readjusted the blade over and over but it continued to come loose and drop to the floor. The problem is that the two bolt heads do not have enough contact with the blade’s beveled sides when shaving really hard wood. I am very disappointed in the spokeshave especially after using other Veritas products which have always been outstanding.
View libraryman's profile
libraryman
45 posts in 3986 days
13 comments so far
View helluvawreck's profile
helluvawreck
32086 posts in 3107 days
#1 posted 01-22-2015 04:35 PM
If I were you I would send it back. I believe Veritas would take it back. They seem to be good people.
helluvawreck aka Charles
View JADobson's profile
JADobson
1335 posts in 2352 days
#2 posted 01-22-2015 05:07 PM
+1 Charles.
I brought a roughing gouge back to LV that I’d had for well over a year that had snapped in half. They took one look at it, said it shouldn’t do that and sent me home with a brand new one. Let them know your problem and I’m sure they’ll take care of you. Let us know how it turns out.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View Fish22's profile
Fish22
83 posts in 3354 days
#3 posted 01-22-2015 05:18 PM
I would give them the opportunity to make the issue right, instead of coming here first to complain about it. Anytime I have had a issue with LV/Veritas, a simple phone call gets it resolved.
-- Bryan, South River, NJ
libraryman
#4 posted 01-22-2015 05:29 PM
I should have written that we returned the spokeshave to Highland Woodworking where it was purchased. They have a 60 day return for any reason policy. I’m sure if I had need to return it to LV/Veritas they would have done the same.
View Dedvw's profile
Dedvw
176 posts in 3122 days
#5 posted 01-22-2015 05:41 PM
- Fish22
I would call this more of an observation than a complaint. I worked in a shop where four other people (including myself) had this spokeshave. Not a single one of the group really liked it for the same reasons that Libraryman pointed out. One of the guys ended up returning it without any problems. I kinda wished I had, but it was the only spokeshave in my tool box and I needed it regularly.
One other part that I don’t like is how you adjust the toe piece. The two screws make it difficult to make parallel to the blade because they shift the toe piece as you tighten them. They are also difficult to make very fine adjustments with.
I bought this in 2007 and I’m kinda surprised they have not improved the design of this plane.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3826 days
#6 posted 01-22-2015 07:58 PM
I think the guy was just pointing a flaw in their design and telling everyone here about it.And good for him If it broke then I could perhaps see your point but in this case it was badly made or designed.Of course veritas could always post here and explain why they so designed it faults and all.The man has an absolute right to point out any flaws in design which are not one off’s but inherent withing that particular tool made by them at Veritas and sold to us at great cost THEY AINT CHEAP TOOLS after all .He never once said anything negative about their handling of the case. Alistair
View Lumberpunk's profile
Lumberpunk
334 posts in 2578 days
#7 posted 01-23-2015 02:31 AM
As a note to all those using this shave I bought the low angle shave kit where you make your own handle and I really like the shave… great skill builder too.
-- If someone tells you you have enough tools and don't need any more, stop talking to them, you don't need that kind of negativity in your life.
Dedvw
#8 posted 01-24-2015 07:26 PM
Yea Lumberpunk, it might be worth making my own spokeshave. What kit did you end up getting?
View SPHinTampa's profile
SPHinTampa
567 posts in 3926 days
#9 posted 01-26-2015 01:59 PM
I have had the same experience as others that have posted – the spokeshave is a poor design and the blade slips too easily.
As others have noted, Lee Valley’s customer service is fantastic and will take it back so you can buy one their many tools that do work well.
-- Shawn, I ask in order to learn
Dedvw
#10 posted 01-26-2015 11:31 PM
I agree Shawn, Veritas should get rid of this tool. It is a scar in their lineup.
View Dusty56's profile
Dusty56
11830 posts in 3929 days
#11 posted 01-28-2015 01:05 AM
What made you rate it at 2 stars if it continually fell apart ?
libraryman
#12 posted 01-29-2015 05:15 PM
As I said – the shave worked perfectly in soft wood – If I had only used it for pine or other soft woods it would be a nice little shave and I would probably have given it a higher score- however I needed it for very hardwood which it failed. I really hated rating this tool as I have many Veritas tools which have always been a great value and worked hard and well. I have been looking at their higher priced flat spokeshave which has a substantially stronger blade adjustment and may get it.
View bowedcurly's profile
bowedcurly
519 posts in 1970 days
#13 posted 02-02-2015 06:14 AM
I have one and it works great I love it cuts flawless, works great in any wood, I can’t lie I hated the dam thing at first, until I put some muscle behind it a pair of rubber jawed channel locks I snugged it just a bit and it works like a charm
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
