DAILY DEALS Rockler 3-Pc. Roundover/Beading Bit Set at Rockler  |  DeWalt Gauge Narrow Crown Stapler at Tool King
Not what you normally think of "Poly"
Review by CessnaPilotBarry posted 437 days ago 582 views 2 times favorited 7 comments Add to Favorites Watch
Not what you normally think of "Poly" No-picture-s No-picture-s Click the pictures to enlarge them
A year or so ago, a gentleman on another forum recommended this product to me for interior trim, doors, and cabinetry.
Kwick Kleen Fast Dry Poly is a polyurethane finish that handles a lot like nitrocellulose lacquer. Before we go any further, let me say that you need spray gear to use this product. Don’t own spray gear? You can’t use this.
Fortunately, I own a Fuji 4 Stage HVLP setup, which I usually use to spray ML Campbell Nitrocellulose Lacquer on furniture. I needed a more durable finish for certain items. So, I tried KK Fast Dry Poly.
This stuff is cool! It handles just like NC lacquer. It’s a one part product, with no mixing, catalyzing, or expiration date. There is an open “window” where subsequent coats will melt into the last. Once the window closes, you have to wait for it to reopen five days later for full burn-in. I sprayed it right from the can, with a #4 Fuji tip in a suction gun.
I tested this product on a mahogany mirror frame located in my main bathroom. I chose the test subject because it will be handled several times a day, will be exposed to wide humidity swings, will be touched by cleaning products, some containing bleach or ammonia, and it will see alcohol based hair care product overspray. I used the “satin” sheen for natural, rubbed lacquer look. It looks like lacquer, resists damage like urethane… GREAT Stuff!
After a year, I’m happy to report the frame looks like the day I finished it! I highly recommend this to lacquer fans that need a really tough, easy to use finish.
Find it HERE
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View CessnaPilotBarry's profile
CessnaPilotBarry
1225 posts in 581 days
7 comments so far
View griff's profile
griff
901 posts in 641 days
posted 436 days ago
What is the drying time on this fast drying urethane?
-- Mike, Bruce Mississippi = Jack of many trades master of none
CessnaPilotBarry
posted 436 days ago
It was tack-free in 10-15 minutes for me, almost identical to NC lacquer. There is a retarder available if conditions warrant.
To me, the stuff seems like a lacquer with polyurethane resins.
View lclashley's profile
lclashley
243 posts in 993 days
posted 436 days ago
This sounds like a product I’ve used by Taget coatings, but cheaper. Thanks for the heads up.
2991 posts in 900 days
posted 433 days ago
Do you know if it’s tintable?
CessnaPilotBarry
posted 433 days ago
It doesn’t say you can’t, but I’d try it on scrap. <g>
Off the top of my head, I’ll bet a small amount of colorant compatible with lacquer would be fine.
View Ryan Shervill's profile
Ryan Shervill
238 posts in 691 days
posted 433 days ago
Interesting…...what solvent? Just min. spirits?
-- If you can't set a good example, at least serve as a horrible warning... www.rarewoodcreations.com
CessnaPilotBarry
posted 432 days ago
Lacquer thinner
