A lifesaver for installing hinges, hooks, anything that requires a centered hole
Review by CharlesA posted 01-04-2015 07:14 PM 4832 views 0 times favorited 10 comments Add to Favorites Watch
A lifesaver for installing hinges, hooks, anything that requires a centered hole A lifesaver for installing hinges, hooks, anything that requires a centered hole No-picture-s Click the pictures to enlarge them
Okay, for some of you this tool may be unnecessary. But whenever I have installed hinges, coat hooks, or anything else that requires a centered hole, I always seem to be just a hair off. I would carefully mark with a pencil, then use a punch to mark the hole, drill it carefully, and voila, I’d end up with screws that were almost centered . . . every time.
Christopher Schwarz recommended this Starrett Punch, but I balked at the price tag. But I tried it, and I am glad I did.
A built in mechanism does the punching for you when you’ve depressed the tip all the way—a spring-loaded mechanism punches sharply.
What do I like?
  • the one-handed operation. Unlike the cheaper centering punch I tried before this one, I don’t need one hand to hold the punch and one to hit it with a hammer. I can use this one on a vertical surface. I am installing coat hooks this week on a vertical surface. I can hold the hood with my left hand and punch it with the right hand alone. I just push.
  • the punch itself is sharp and makes a workable hole. I can adjust the force and i can re-sharpen it if necessary.
What do I not like?
  • the mechanism requires that the diameter of the barrel be significantly larger than a simple punch. With some applications, this punch has a hard time fitting.
I wouldn’t go back to anything else.
View CharlesA's profile
CharlesA
3305 posts in 1703 days
10 comments so far
View pintodeluxe's profile (online now)
pintodeluxe
5566 posts in 2719 days
#1 posted 01-04-2015 07:22 PM
Here is another option… self centering drill bits. A set of three sizes runs $6-24. The ends of the cylinder is tapered, so even if it doesn’t fit the bore exactly, it will still be centered. If you have a shelf-drilling jig, you may already own one.
View tyvekboy's profile (online now)
tyvekboy
1719 posts in 2918 days
#2 posted 01-04-2015 08:22 PM
I second pintodeluxeʻs solution. Rockler also sells a set for $30.00.
http://www.rockler.com/rockler-insty-drive-self-centering-bits
I use these all the time. Drill the centered pilot hole in one swell foop.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
CharlesA
#3 posted 01-04-2015 08:29 PM
I’m installing some coat hooks like these:
I’m not sure I could get those self-centering drill bits in at 90 degrees. I use the punch for the initial placement, then remove the hook so I can drill the hole.
View KayBee's profile
KayBee
1083 posts in 3152 days
#4 posted 01-04-2015 08:40 PM
It’s a great punch! So good, that someone liberated mine from work. Those self centering vix bits are nice. Sometimes you don’t want the screw exactly centered or at a right angle. Center punch makes this easy to do.
-- Karen - a little bit of stupid goes a long way
View Rick's profile
Rick
8899 posts in 2938 days
#5 posted 01-05-2015 02:48 AM
I agree! I wouldn’t be without them for centering screws in Hinges and whatever else.
Lee Valley has the same ones you bought for about the same price.
I opted to go with a different set after going there and looking at them. Not saying mine is a better set, they just suited my needs better, and a set of three for various uses was $23.00. Price was not a factor in the buying decision.
They are also Spring Loaded and Adjustable Tension.
Thanks for the Review Charles.
-- I Take My Kids Everywhere! The Problem Is, They Keep Finding Their Way Back Home! (Rick, Ontario, Canada)
HillbillyShooter
5811 posts in 2198 days
#6 posted 01-05-2015 10:47 PM
Automatic center punches are great, and Starrett makes the absolute best IMHO. I’ve use one as far back as I can remember (50s or 60s); and, I prefer the all steel ACP to the aluminum body, especially the ones with replaceable tips. For centering hinges (and anything similar where it will work), I agree the vix self centering bits are the best. However, not all self centering bits are equal. I had great luck with the original vix bit (c.f., http://vixbitsonline.com/ ) and mediocre with other brands.
View dhazelton's profile
dhazelton
2689 posts in 2202 days
#7 posted 01-09-2015 01:54 PM
$47!!! I have the five dollar version from the homer depot and it works fine for my needs. I use it for installing door hinges. A full set of sizes might be nice for smaller cabinet hinges.
View bonobo's profile
bonobo
297 posts in 1962 days
#8 posted 01-15-2015 02:06 AM
Well made tool but I wish it was offered in a smaller size, more suited to box hinges and lock hardware.
-- “The easy confidence with which I know another man's religion is folly teaches me to suspect that my own is also.” ― Mark Twain
CharlesA
#9 posted 06-12-2016 04:58 AM
I was using this tool again today and was reminded how helpful it is.
View MrRon's profile
MrRon
4632 posts in 3149 days
#10 posted 01-26-2017 09:37 PM
A self centering punch is useful, but unless you use a brad point drill, you won’t get a concentric hole. Ordinary twist drills will go off center every time in both soft and hard woods. You need to use a very high speed with the brad point for reliable results. This is more or less a tip, not an endorsement or negative view, and certainly having a Starrett gives one peace-of-mind that you are using the best available.
