| Review by dmann | posted 471 days ago | 2180 views | 2 times favorited | 10 comments | ![]() |
- Other Drill Press Safety Planer
- Brand: Other | Category: Planers
As much as I’de love an excuse to get another piece of equipment for the shop I don’t use a planer enough to justify the expense or space.
I saw this Drill Press Planer at the Woodworker’s Supply and figured for the price I would give it a shot. I was able to plane my first pieces of wood this week. I was preparing a section of a 3×3x9 block of maple to create a laminated bowl blank.
The Planer worked well for my purposes. I secured the planer in the chuck and adjusted the table to take 1/16” to 1/8” off. Took a little while to get the hang of the cutting action but in no time I was making a huge mess in the shop. I was cutting endgrain so a little sanding to remove the raised grain and I was able to have a surface suitable for the lamination.
I’m giving this a 3. Not because of the quality or instructions, it definitely works as advertised, but I would only suggest this if you only need a planer a couple of times a year. To plane the edge of a board (very easy on a dedicated planer) you would have to do a lot of messing with your drill press table and fence to get a good edge.
Sells for around $30 at Woodworker.com. Grizzly and Woodcraft have similar items on their sites for $50.
Pros:
Cheap
Quick cutting action – cutters are pretty substantial
Comes with sharpening supplies
Cons:
Must be careful around the spinning cutter head
Messy, wood chips go everywhere
Quality of cut depends a lot on the drill press table and fence setup
-- David / Durham, NC
10 comments so far
woodworm
home | projects | blog
8219 posts in 484 days
posted 471 days ago
MHO is this drill press planer is for light duty. I am talking about the “drill press” not the planer, in this contex.
The drill press’s bearings are designed for axial force (load). Putting extra “side force” (load) ie when we push the work-piece to feed (wether using DP drum/spindle sanding or DP planer) may cause quill wear out.
I think if we maintain slow and light force feeding, the possible quill damage is minimal.
What others think?
-- masrol, kuala lumpur, MY.
Dominic Vanacora
504 posts in 763 days
posted 471 days ago
This seems like a tool that would be a bit dangerious. I can see me feeding the material too fast and a lot of kick pack. And I can’t see it giving you a good finish. But $600.00 verse $30.00 It may be worth a try.
Thanks for the review.
-- Dominic, Trinity, Florida...Lets be safe out there.
Don Niermann
155 posts in 866 days
posted 471 days ago
I hace had one for 15 years. Works good for it was planned for. Not A PLANNER BUT FOR SMALL jobs.
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
brianinpa
1365 posts in 617 days
posted 471 days ago
Very good review. I have been looking at planners for a while now and still don’t want to spend the money for one. I recent bought a 4” joiner at an auction for $10.00. It works for surfacing small projects, but I can see where this drillpress planner could be useful.
FJPetruso
163 posts in 604 days
posted 470 days ago
I’m glad that you bought the good rotary surface planer! Yours is designed much better with cutters that have a totally different design. Years ago I bought the rotary planer that Sears used to market. The old Craftsman model that I tried on my radial saw is the absolutely most dangerous tool that I ever used! Your new planer has a step/ridge around the edge that prevents the cutting edges of the cutters from projecting to far & only allows the cutters to take out a small amount. The old Craftsman model doesn’t have this step & the cutters can take a HUGE BITE that causes a severe kick-back problem. I have a scar on the heel of my hand as proof. Never buy an old Sears Craftsman model. I actually deliberately ruined mine with a hammer so it couldn’t be used again.
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
marcb
696 posts in 567 days
posted 470 days ago
The bearing issue mainly depends on the Drill Press you’re using. My drill press talks about using it for routing in the manual. Uses a Deep Groove Bearing which takes axial forces in stride.
scottb
3402 posts in 1221 days
posted 470 days ago
my (wicked cheap) drill press probably couldn’t handle this, but I bet it would work pretty well on the shopsmith – certainly cheaper, easier and/or faster than (finally breaking down and building) a router sled.
Don Niermann
posted 470 days ago
I also only use mine only in my shopsmioth
Doug S.
306 posts in 602 days
posted 469 days ago
Like others have mentioned, it’s for small stuff only but that’s where it really shines anyway. Stuff that’s just too small tends to get shredded in a standard planer even riding on carriage boards. It CAN kick some if the work is fed from the wrong direction but after you get the feel for it, it’s pretty easy to control. You can find a number of Inet posts from luthiers using it for thicknessing small instrument parts. I’ve used it to thickness 1/16” inlay stock prior to getting a drum sander and it worked well.
-- Use the fence Luke
KRAIG
8 posts in 914 days
posted 468 days ago
WHEN BUILDING OUR NEW HOUSE. I ONLY HAD THE RADIAL SAW, ROUTER, JIGSAW AND ASSORTED HAND TOOLS. PURCHASED THIS FOR MY RADIAL SAW. STUCK ON A 1/2” CHUCK WITH A SPEED CONTROL. IT WORKED GREAT FOR ME. YOU MUST MAKE A SAFETY COVER OR FENCE. AS I DID. DURING THIS TIME. I MADE NORM’S BLANKET CHEST AND A MATCHING MIRROR.
-- kraig stewart
