| Review by Tim Dorcas | posted 482 days ago | 1689 views | 2 times favorited | 13 comments | ![]() |
- Rockler Thin Rip Tablesaw Jig
- Brand: Rockler | Category: Tablesaw Accessories
In the past one of the things I hated to was rip thin pieces of wood. Typically this is done to create keys for mitered joints. Last December I was going to build a one of the many jigs that you can find online when Rockler came out with their Thin Rip Tablesaw Jig. For $20 I thought, “Why not?” It arrived about three weeks later (They were sold old initially and everything takes longer in Canada.) and I was surprised at the quality of it’s construction. If anything the fit is a bit tight. After fitting everything together I immediately gave it a workout. I already had a box made that I needed keys for. The first cut was a little too thin. After struggling with the tight fit to slide it back, I finally got what I needed. There is a ball bearing at the tip which makes the wood flow nicely.
Most of the woodworkers I know are a frugal bunch but for $20 bucks I think it more than pays for itself. The only thing I wish it had was a numerical system for ease of setup. That and the fact that it is bit hard to move at first knocks off a half of a star. I would rate this 4.5 stars. If you need to rip thin strips I would recommend getting one.
-- www.responsetolight.com - A Woodworking & Renovation Blog & www.craftedbytim.com - I make. You buy.
13 comments so far
home | projects | blog
20575 posts in 715 days
posted 481 days ago
Nice review, Tim. I have looked at one of these and been debating whether to get one or not. It is nice to hear from someone who has used one.
Bob N
75 posts in 820 days
posted 481 days ago
Tim,
Thanks for a very nice review. I am sure it is a great product, but to me it looks like a kickback just waiting to happen. I certainly hope I am wrong.
Brad_Nailor
1213 posts in 850 days
posted 481 days ago
I did a review on this item about a 1 1/2 months ago. I like it allot and think it is worth the money. Although in that first picture you have it set way too close to the blade. The directions said to position it at the bottom of the table saw insert. From my personal experience when I placed it any closer than that, I was getting burning on the keeper piece due to the jig pushing the piece back against the blade, and I think it drastically increases the chance of pinching the blade and kicking the piece back.
Tim from Iowa City
183 posts in 493 days
posted 481 days ago
Thanks for the review. Interesting jig.
-- Tim from Iowa City, IA
marcb
696 posts in 566 days
posted 481 days ago
Shopnotes had a jig like this in their magazine once. Setup right it shouldn’t kick back as the keeper piece is thin and should peel away from the saw. Its basically a really low friction (Ball bearing) single point feather board.
motthunter
2079 posts in 692 days
posted 481 days ago
Interesting.. can you show more pics of it in use…
-- making sawdust....
Tim Dorcas
130 posts in 751 days
posted 481 days ago
Thanks for the comments.
1) The bearing is actually touching the blade. I think I was more interested in getting a picture than anything else. In actual use it would be closer to the operator. I have never experienced anything close to kick back using this jig.
2) I usually make it a hair or two thicker than it needs to be and finish it with my Smoothing Plane. This also helps because it can be very difficult to move the blue adjusting piece.
Bob O'Brien
11 posts in 507 days
posted 481 days ago
I have one of these, and I agree with your review comments: difficult to adjust and I wish it had some numbers (any sequential numbers) instead of just ticks on the slide. I lubricated it with a little Waxilit, and that has helped with the slide. I do not use it often, but when I have it did the job. I always have a riving knife in place when rip sawing, and I have had no problem with kickback.
-- Bob
Brad_Nailor
posted 481 days ago
The increments on the unit are 1/16 and 1/32. The reason it doesn’t have any numbers is every saw and blade is different. To get an accurate measurement you touch the blade tooth with the bearing, and then use the marks to move the unit back the thickness of the piece. I like the fact that the jig was snug…it made it easier to hold my settings while i slid it down and tightened it up in position.
teenagewoodworker
2480 posts in 661 days
posted 478 days ago
cool review, i’ve had my eye on this for awhile. looks like a cool little tool!
gbvinc
537 posts in 839 days
posted 478 days ago
Picked one up last week, ripped a bunch of strips for screen door screens. Worked great. A keeper.
Paul
118 posts in 482 days
posted 478 days ago
I made one similar to this a few months ago, there was a pattern in one of the woodworking magazines. It does the same thing and is a very reliable way of reproducing thin strips. I think this one or the one I made are very worthwhile additions to the shop.
-- Paul, La Center, Washington
Don Newton
528 posts in 511 days
posted 473 days ago
I’m not new to woodworking and have been staring at the pictures but haven’t a clue what this device does. Do you use it instead of a fence?
-- Don, Pittsburgh
