Begininng with the Installation of the EEZE FEED infeed table
Review by psient posted 12-27-2014 07:48 PM 3874 views 0 times favorited 5 comments Add to Favorites Watch
Begininng with the Installation of the EEZE FEED infeed table Begininng with the Installation of the EEZE FEED infeed table Begininng with the Installation of the EEZE FEED infeed table Click the pictures to enlarge them
I was on You Tube looking for someone’s experience installing Lee Jesberger’s EEZE FEED infeed tablesaw table. I did not find any videos capable of helping my installation. Here, I’ve started to describe my own installation as a review and something of a guide for others.
I’ll be installing the EFIT on my powermatic PM3000 7 HP table saw:
http://www.powermatic.com/Products.aspx?Part=1720305K
I purchased the saw several years ago. This was as much a health decision as anything else. That is to say (abrev. TITS) I had just begun dealing with a health problem and needed some way to stay active. As I am a journeyman carpenter with enough experience to work alone, I started equipping a shop to provide projects that would keep me busy. I’m still getting started although purchasing the EFIT was in anticipation of providing a level of control in my using sheet-goods. I cut a lot of 1.125 subflooring to use in construction of various things on my Horse Ranch. The sheets are very heavy and hard to handle on the table saw. It has been my practice to use a FESTOOL track saw in the past. I hope that Lee’s EFIT will allow me to be more efficient in the use of my time when dealing with this and other materials.
This post is the beginning of an overall review. I have chosen to review the installation so that others may judge time and effort involved.
View psient's profile
psient
82 posts in 2553 days
5 comments so far
psient
#1 posted 01-07-2015 08:52 PM
I first opened the box. It is very carefully packed and protected. Interesting that the time it takes to package the table is clearly visible in that nothing seems left to chance. Nice support for all items in the table and there is no over-stuffing. Very industrial of Lee.
On to reading the manual.
psient
#2 posted 01-07-2015 09:20 PM
The manual assumes a degree of understanding how to visualize what is being read. There are some illustrations but these are sort of hand drawn pictures with a listing of parts in the picture. So you seem to have to rely upon being really familiar with your saw in order to interpret the instructions prior to installation. I imagine that when you are actually installing the table, you begin to understand what Lee is telling you. He has a phone number where you can reach him. I really can’t find any criticism although photographs of an installation would be helpful to me. That is, remedial photographs. Maybe I’ll try to provide them as I go along. It’s too late to begin my installation right now but tomorrow is a possibility.
psient
#3 posted 10-19-2016 06:11 PM
The installation was straight forward except the the tablesaw power switch could not remain in the original mounted position. I designed, fabricated and installed a bracket to re-mount the switch and that was the end of the difficulties with the installation. I’d estimate it would be about a one day job given the interference of the switch. I estimate because I had to take several work sessions for the mounting of the rail on the table saw, I was unable to work straight through.
There turned out to be no problems with installation instructions.
psient
#4 posted 10-19-2016 06:18 PM
I have been working with the EZEE feed table for about 8 months now. Here’s what I perceive to be the pros and cons. NOte that when I built my shop I ensured that the floor was level and did not slope:
Pros:
Very easy to install and use.
Handles heavy sheet goods much better than a fixed solid table.
Mobility/on-off allows much more space in the shop.
Storage is easy.
Height adjustment is simple to understand.
Cons:
Table’s transfer balls leave indelible marks on surface of soft and semi hard wood. These cannot be removed.
Height adjustment is unreliable across time/occasions.
Awkward to handle table as a unit although once folded it is easy to store.
I think the 400 bucks was well worth it and except for the marring of the wood, I am happy with it. Lee is right to be proud of what he created.
Jon
6866 posts in 4219 days
#5 posted 10-19-2016 09:22 PM
Hi Jon;
Thanks for taking the time to do a review.
We now provide a link which shows photos of the install process.
On your cons, you mention the transfer balls leaving marks on your sheets. I suspect your unit is equipped with a batch of transfer balls that came from the manufacturer, which had more than the usual amount of oil on them. We didn’t catch that immediately, and several units were shipped with this oil coating.
A customer called us with the same comment, and after a little investigating we discovered the problem. We called the customer and informed him of the find. He did get back to us, letting us know that was indeed the problem.
We cleaned the remainder of them in stock, prior to shipping them. (what a fun job that was), and now watch all shipments for the same problem.
We’ve run thousands of sheets across these tables, using very high end plywoods and veneers, with zero problems with marking. (or anything else). Hopefully, cleaning them well will eliminate that problem for you.
Again, thank you for the write up.
