Review of Delta 14-461 Deluxe Mortiser
Review by Al Navas posted 677 days ago 1295 views 1 time favorited 5 comments Add to Favorites Watch
Review of Delta 14-461 Deluxe Mortiser No-picture-s No-picture-s Click the pictures to enlarge them
The bottom line: This machine works, but you must watch out for several things, common to all mortisers of this type, as I already have pointed out on my recent blog posts.
The weak link: The fence. It recently gave me many headaches, as the inside edges of the fence halves did not align properly – in the photo, Edge #1 and Edge #2. This resulted in misalignment of stiles to rails, something that should NOT happen. I probably did something to cause this, or maybe just sitting by a window in cold weather caused the cast iron to change dimensionally. I don’t really know. This is solved VERY easily by attaching a sub-fence; use screws to secure a wood fence to the cast iron one using the holes provided for this purpose; this is my guess, as I am not really sure why these holes even exist on the ends of the fence :) .
With proper care, and making sure the chisels are sharp and square to the table top, anyone can make mortises using this machine. I would buy it again. But today there are other options, such as Festool’s Domino, at about 3X the cost. I don’t own a Domino, but that might be THE way to go if I must cut many, many more mortises than I do today.
-- Al Navas, St Joseph, MO, http://sandal-woodsblog.com
View Al Navas's profile
Al Navas
289 posts in 774 days
5 comments so far
View dalec's profile
dalec
580 posts in 787 days
posted 677 days ago
Thanks for the review Al. Will check out your blog.
Dalec
View GaryK's profile
GaryK
9539 posts in 887 days
posted 677 days ago
I have the same machine and didn’t have that problem you describe. I have used mine with no problems.
Thanks for your review.
View cajunpen's profile
cajunpen
5968 posts in 964 days
posted 667 days ago
I’ve been thinking about getting a bench top mortiser – Good review – Gary, do you think this is as good as I would want, or should I spend the extra $$$ and get the Powermatic 701? I doubt that I would use either of them that much.
View DRdeveloper's profile
DRdeveloper
23 posts in 364 days
posted 361 days ago
I purchased the same machine from Rockler and am very happy with it – it’s very easy to make mortises. My two complaints about it are really a wish list: (1) There should be some way to easily square up the chisel – it’s a pain in the posterior to have to square it up every time you chock up a bit (2) the chisel/bit combo jams up a lot with wood chips when drilling into hard wood (like mahogany) – this causes the motor to stop and you have to remove the chisel/bit combo, clean it out and put it back in again (see wish #1) – if there were chip holes on BOTH sides of the chisel, this might be less of a problem.
-- Mark, Dominican Republic
View woodymays's profile
woodymays
23 posts in 171 days
posted 66 days ago
I have been wanting a mortiser and after looking at several, I liked the Festool domino jointing system. This tool is somewhat similar to a biscuit jointer but does a lot more. This tool cuts the mortise via a drill bit that turns and oscillates at the same time making a rectangular shape hole. This mortiser will cut different size mortises depending on which cutter you have installed. The dominos fit exactly to size into the mortise. I toke a look at one of these tools and some day will own. I will say that this mortiser costs quite a bit but well worth the money. take a look at this web site: www.festooljunkie.com. review and watch the video clips on what this tool can do.
-- Mark, Ohio, www.swig@nktelco.net
