Trend Diamond Whetstone Kit, Up For Review
Review by woodshopmike posted 11-04-2014 06:58 PM 3937 views 1 time favorited 17 comments Add to Favorites Watch
Trend Diamond Whetstone Kit, Up For Review No-picture-s No-picture-s Click the pictures to enlarge them
The things that make this kit great are that it’s quick and easy to use. Woodworkers are famous for “being one tool away from greatness”. Well, I’m here to say that as far as sharpening my hand tools goes, I’m set and this is the only sharpening kit I’ll be using. I’d highly recommend this product to professional and hobbyist woodworkers alike.
For my complete tool review check out the post, Trend Diamond Whetstone Kit, Up For Review.
Thanks for reading y’all!
Regards,
Mike
-- www.woodshopmike.com, www.woodshopmikestudio.etsy.com
View woodshopmike's profile
woodshopmike
225 posts in 1569 days
17 comments so far
View RogerBean's profile
RogerBean
1605 posts in 2859 days
#1 posted 11-04-2014 07:27 PM
Not to seem like a malcontent, but it would seem that if you are going to post in the review section, you ought to post the review. Not just a link. Just my opinion.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
woodshopmike
#2 posted 11-04-2014 07:32 PM
Roger,
Not a problem and I understand your opinion. Most don’t seem to have a problem with it.
Honestly, I’m just wanting to share what I’ve learned. Also, after putting as much time into a blog post or review to make it look and read the way I want, I’m disinclined to increase that effort especially on a different platform.
I do hope you enjoyed the review though.
Kind Regards,
Mike
View CharlesA's profile
CharlesA
3305 posts in 1703 days
#3 posted 11-04-2014 09:27 PM
Thanks for the review.
With this kind of review, it would be really helpful to know what you’re comparing it to—how have you been sharpening? It’s hard for me to know how to evaluate all your superlatives when I don’t know if you’re moving from hand sharpening, a Tormek, or scary sharp.
It’s a little like a cordless drill review. If you say it is the greatest thing ever, and you’ve been using a 2012 Makita cordless drill for the past 2 years, that holds a different weight than if you’re comparing it to the B&D 1978 corded drill you’ve been using.
Make sense?
woodshopmike
#4 posted 11-04-2014 09:52 PM
Charles, that’s a great point you bring up. For chisles and planes my method of sharpening has been completely by hand. My experience with sharpening these kinds of tools is with whetstones (oil & Japanese waterstones), and a similar system to the Tormek.
I consider my straight razor scary sharp, and for good reason! The Trend diamond abrasives only go to 1000 grit, so if I were sharpening my razor, I’d want to go to a high grit whetstone before stropping the blade. However, for woodworking, one does not want the same edge that would be on a straight razor as the edge would blunt way to easily. I can shave with the edge of chisels and planes after using the Trend honing kit which is plenty sharp for me.
Does that help to quality a bit of my background and what I’m comparing the Trend products too?
Thanks for the feedback.
Regards,
Mike
CharlesA
#5 posted 11-04-2014 09:54 PM
Yes, that is quite helpful.
View timbertailor's profile
timbertailor
1594 posts in 1330 days
#6 posted 11-05-2014 12:13 AM
Roger
- RogerBean
I agree. Makes us feel like just an afterthought.
View longgone's profile
longgone
5688 posts in 3214 days
#7 posted 11-05-2014 01:34 AM
Roger
- RogerBean
- timbertailor
View bobasaurus's profile
bobasaurus
3377 posts in 3090 days
#8 posted 11-05-2014 02:00 AM
I have the diamond stone from this kit, and it’s been okay. I use the 300 grit side to flatten my fine shapton waterstone, then use the 1000 grit side and the waterstone for sharpening freehand. I use water with honerite additive for lubrication, but still a small amount of rust occurs despite the additive. Hearing about the water-soluble honing compound is interesting, I may have to get some.
I have found that the diamond stone is not entirely flat. I can see it with a straight edge + light or a feeler gauge, and it telegraphs onto my fine waterstone, giving me sharpened plane irons that are slightly concave in the center. I’ve learned to work around the curvature to get a flat-enough edge, but it is somewhat vexing. I’ve considered going the DMT route in the future to get around this.
I do like the idea of diamond+stropping for the entire sharpening process, as it would save a lot of flattening time and mess. How fine of a plane shaving can you get with irons sharpened from this kit?
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
woodshopmike
#9 posted 11-05-2014 12:26 PM
Hi Allen,
I’m curious about your stone rusting a bit. Could you snap a photo and share?
The stone should be flat to .0005”. If yours isn’t I’d call Trend about the issue. They have great customer service and will take care of you. The number for their US HQ is (336) 292-5051.
I can take a shaving that is .0015” thick and leaves a surface that doesn’t require sanding. Yes, I actually broke out the calipers for ya :)
Let me know if I can help out resolving the issue with your stone.
bobasaurus
#10 posted 11-05-2014 05:36 PM
Hi Mike. I’m at work and don’t have a picture handy, but it tends to slightly rust unless I’m very careful about cleaning off all steel swarf/dust from the stone after each use. I bought the stone 2 years ago, so I’m not sure if their warranty applies (also since I’m using water+honerite instead of their honing fluid).
View jinkyjock's profile
jinkyjock
488 posts in 1480 days
#11 posted 11-06-2014 10:42 AM
Mike,
thank you for a nice comprehensive post.
But let’s get down to brass tacks with a pertinent question from a typical Scotsman.
How much does this product retail at in the States.
Over here the cheapest I can see it at is £120,
which is not bad if it does what it says on the tin.
Cheers, Jinky (James).
woodshopmike
#12 posted 11-06-2014 06:27 PM
Allen,
The stones have a 5 year warranty. I’m not sure if there is a stipulation about what fluid is or isn’t used invalidating the warranty. However I think the bigger issue would be the flatness of the stone…
James,
You’re very welcome, I hope you enjoyed it. If the question of cost is typical of a Scotsman, we must be related :) In the states the kit retails for $200. Honestly, for the money you can buy a couple of other stones and have the maintenance that goes along with them. For my money, I like simple. I’m by no way saying that other stones are defunct or without use. Just that for what I need in a sharpening solution, the Trend system delivers with a simple product.
jinkyjock
#13 posted 11-07-2014 11:30 AM
Mike,
thank you for that info.
I was asking about cost as I will be in USA in near future,
and if I could have saved a couple of bucks….......
woodshopmike
#14 posted 11-07-2014 01:49 PM
I hear ya. Where in the states are you headed?
jinkyjock
#15 posted 11-08-2014 11:47 AM
Mike,
heading over on 17th Dec. for one month.
Hope to visit family in Columbia SC, Boone County WV,
and nr Jacksonville FL.
Will mainly be based at my niece’s place at Roxboro NC.
Busy times ahead…
