Cree 40 inch LED lighting fixture
Review by Sawdust4Blood posted 10-25-2014 12:07 AM 2977 views 4 times favorited 10 comments Add to Favorites Watch
Cree 40 inch LED lighting fixture No-picture-s No-picture-s Click the pictures to enlarge them
I have a basement shop that had some lighting put in by the builder. It was enough to keep you from running into things but wasn’t really the quality of light that you would like to have while woodworking. So I had been looking at putting in something that would provide better light while I was working.
Originally, I was thinking about standard T8 fluorescent tubes. While fluorescent has never been the kind of light that I prefer, for shop lighting it’s probably been the most popular option.
However, in the course of trying to figure out which brand’s fixture would work best, I stumbled across these 40 inch LED light fixtures from Cree. Each fixture is rated to put out 4000 lumen (should be about the same as a 2 tube F25T8 fluorescent). At 3 and half pounds, they are much lighter than fluorescent fixtures and install easily. I installed two fixtures in about 30 minutes.
The down side is that they are significantly more expensive than a fluorescent fixture. The up side is that they use less electricity, don’t have cold temperature issues, and are immediately full bright.
My shop area is significantly brighter than it was before and I am happy with the results. I would consider these a good option in either a garage or basement shop when cold temps in the winter can give fluorescent lights fits. However, if I had to put in a lot of fixtures, the price differential might have made me stick with fluorescent.
-- Greg, Severn MD
View Sawdust4Blood's profile
Sawdust4Blood
408 posts in 3261 days
10 comments so far
View djwong's profile
djwong
176 posts in 3459 days
#1 posted 10-25-2014 04:57 AM
Interesting. Thanks for bring this to everyone’s attention. May I ask how high your ceiling is where they are mounted? Are you having any issue with glare?
-- David W. Cupertino, CA
View timbertailor's profile
timbertailor
1594 posts in 1663 days
#2 posted 10-25-2014 11:50 AM
What color temperatures do they come in?
Sawdust4Blood
#3 posted 10-25-2014 02:01 PM
@David… my basement has 8 foot ceilings and they installed easily to the existing std electrical box. No problems with glare yet
@Brad… as far as I know, the only available color temp is 3500
-- Greg, Severn MD
View Woodknack's profile
Woodknack
12465 posts in 2619 days
#4 posted 10-25-2014 04:38 PM
Wheee, at $200/fixture they are definitely more expensive but I’d love to switch over. I have LED under cabinet lighting in my kitchen and love it.
Sawdust4Blood
#5 posted 10-25-2014 06:37 PM
@Rick…. actually I paid $114/fixture from Shine Retrofits
-- Greg, Severn MD
View oldnovice's profile
oldnovice
7380 posts in 3607 days
#6 posted 10-26-2014 02:00 AM
Glad to see you are using the latest, most efficient technology available!
I have switching out all my old lamps and fixture a cost allow.
The first LED I used professionally only put out a pin point amount of red light. That was in 1972 and no one at that time would have thought that they could replace lighting in the home or headlights in automobiles.
LEDs have certainly come a long way!
I found this one on Google shopping, is this the one you have?
View Jeff's profile
Jeff
500 posts in 3433 days
#7 posted 10-26-2014 02:12 AM
When I was a teenager in the late 70’s I made a clock radio with big LED numbers from a Radio Shack kit. I asked an electronics technician how long the LED’s would last and he told me longer than I would. It’s still going strong 35 years later and except for power outages is always on. I, too, am slowly replacing the bulbs in and around my house as cost permits. They’re costly up front but hopefully I’ll never have to replace them.
Sawdust4Blood
#8 posted 10-27-2014 11:07 AM
@old novice…. yes, that is the same one
-- Greg, Severn MD
View OSU55's profile
OSU55
2030 posts in 2228 days
#9 posted 10-29-2014 11:46 AM
Another benefit of LED lighting – it does not attract bugs!. The UV wavelength in incandescent and fluorescent lighting is what attracts them. It’s a little late in the year now, but to test this put one in an outside light fixture on your front or back porch. If you like to leave doors to your shop open in the evenings but the bugs are a problem, LED’s will greatly reduce the bug count.
woodbutcherbynight
5832 posts in 2648 days
#10 posted 11-02-2014 04:22 PM
I have been playing with LED strip lights as of late. 27 feet of light lights up a 6×10 laundry room very well. My installation was 3 strips of 9 feet each all run to a single transformer 110VAC to 12DC. The only catch I encountered was that my old motion sensor switch would not work, it made the lights flicker fast. This required a LED motion sensor switch.
Total cost for this conversion: 42.98
2 LED 16 feet strip lights 18.00
1 LED transformer 8.99
1 LED motion switch 15.99
Currently I am working on a LED set-up for my utility shed, measures just under 8×10. So far using a single 16.5 feet strip have what I call a nightlight. Enough to see and navigate the small shed but not enough to see any details such as a measuring tape in a shadow. I am guessing it will need a total of 3 LED strips (50 feet) to get the light up to par with my previous 4 incandescent light bulb set up. Below is a picture of the laundry room set-up.
