Modest Accuracy, Flimsy Design, Dangerous Features
Review by mot posted 686 days ago 1345 views 0 times favorited 21 comments Add to Favorites Watch
Modest Accuracy, Flimsy Design, Dangerous Features No-picture-s No-picture-s Click the pictures to enlarge them
I wrote this review for Epinions in 2004 and felt that, as Sears is still selling the saw, it is still relevant.
Pros
Outfeed extension
Cons
Extremely unsafe saw. This is an avoidable kickback waiting to happen.
The Bottom Line
If you buy this saw, you will end up buying another saw in a very short period of time.
I was given this saw as a gift. It was a thoughtful gift and I appreciated the sentiment….however…
Saw Specs from Sears:
15-amp direct drive ball bearing motor produces 5000 rpm
Extension allows for 24” right and left rip capacity
Diecast aluminum table with outfeed support
rip fence with self alignment and quick release
45º right/left adjustable mitre gauge
Motor produces 3hp at peak
Carbide-tipped blade
Rolling casters
Dust collector bag
Table without extension is 26 7/64×19 1/2”
First Impressions:
Flimsy and light. The entire saw is made of aluminum and plastic and HAS to be used with the enclosed stand. The owners manual gives suggestions for permanent benchtop mounting, but the theme is, it has to be mounted permanently to something as the strength of the saw itself is integrally reliant on the surface it’s fixed to.
The table extensions are clamped poorly and if you use them, you destroy ANY accuracy that the little fence had. The reason is the table wings don’t come out evenly and aligning them is impossible. They slide out unevenly and there is no gauge on both sides of the extension to attempt to align the wings. Even if you align them to the mitre slot, the clamping mechanism is not secure enough to ensure that it is going to hold it’s position once you start work with the saw.
The fence is flimsy and movement is ragged. I did, however, get it squared but even with continued use, I didn’t gain confidence in it.
The blade insert fits below the level of the table. This makes this saw insanely dangerous to use and drastically reduces the accuracy of any rabbets or dados you are going to cut. There is a rubber spacer/washer on the outfeed side of the blade insert to allow for some adjustment to compensate for this, however, the blade insert then is too loose as the screw holding it would not be secure with the insert level to the tabletop. I think one could put in a washer/spacer to help with this problem but if you change your inserts out as often as I do, (switching from dado blades to cutting blades) it becomes one more little piece to control during the swap.
It is not possible to make a safe, zero clearance insert for this saw as there is only support for the insert on the right side of the blade. There is nothing to support the insert on the left so it is not possible to do tongue and groove rails and stiles with this saw.
The arbor is short and only allows for a 1/2 inch stack. Plus, with a 1/2 inch stack you can’t use the arbor washer. Though most tablesaw manufacturers suggest that not using the arbor washer is okay, as long as the arbor nut is grabbing all thread of the arbor, I just don’t like the idea.
The mitre slot is not standard. Therefore, in order to make featherboards and crosscut sleds, you have to either find some milled aluminum that fits the slot or mill your own guides out of some hardwood. This is inconvenient more than anything, but the slot is shallow, narrow and retains the guide only by 1 cm lips that are placed about every 12 inches along the slot. I made some inserts out of oak and they work okay, but the slot is not smooth and the little lips catch your homemade rails and…well, it became a frustrating process. Now, I make all my own jigs for my shop. There are many that like to buy featherboards and assorted other saw utilities that require a standard mitre slot. They will be out of luck. Also, as this saw seems to be directed to the casual woodworker, I think the non-standard mitre slot would lead the casual user to skip important safety issues with tablesaw use, due to the inconvenience of the mitre slot.
The dust collection bag is almost useless. I found that I was able to contain the arbor nut and washer when I dropped it trying to change out the blade. It also provided a softer cushion for my outside cutter on my dado stack, when I dropped it as there really isn’t very much room to get your hand into the table top. The dust from this saw all comes blasting off the top of the saw right at you and out through the blade elevation adjustment slot. I’m not sure any falls into the bag, possibly only when the saw is starting up or shutting down.
The outfeed attachment is a pleasant surprise as it works exactly as it is intended and is very useful, so thumbs up on that point.
The blade guard with splitter is a great feature, but removing it and replacing it, depending on the current use of the saw is a real exercise in dexterity. It has one screw for a fastener and I feel like I have pop cans on my thumbs trying to put it back on.
The power button is a pull-up switch with a safety insert. It seems to function quite well and removing the insert disables the switch thus disabling the saw startup. Of course, unplug the saw before any blade or table adjustments and don’t rely on this saftey feature.
Now, I use this saw for all sorts of things, but not large sheet rips or very long rips. For those type of applications, I use jigs and a circular saw with stable saw horses. I do, however, use this saw for cross cuts, smaller rips, tenons, dados, rabbets and various other joinery du jour and the mitre gauge slot and the fence, combined with the blade insert join together to form this rating for the saw.
Overall, I don’t recommend this saw as even small jobs and infrequent use only serve to magnify it’s safety issues.
Recommended:
No
View mot's profile
mot
4904 posts in 936 days
21 comments so far
25871 posts in 1300 days
posted 686 days ago
Other than that Tom What do you think of it a fish reef.
View rikkor's profile
rikkor
11335 posts in 774 days
posted 686 days ago
Since Sears was taken over by KMart their tools have been mostly junk.
View Dadoo's profile
Dadoo
1722 posts in 890 days
posted 686 days ago
Excellent review Tom! Craftsman needs to pull this one from the catalog.
3709 posts in 879 days
posted 686 days ago
Hi Tom;
It is good of you to post your experiences with this saw. If you save someone from wasting their money on it , it was worth the time to write.
Many of these small saws are pretty much useless, and instead of helping someone to get a feel for woodworking and then move up to a better model, often they think they don’t have the talent necessary to make woodworking an enjoyable hobby, so they give up.
It’s too bad manufacturers feel the need to make products like this.
View Blake's profile
Blake
2763 posts in 774 days
posted 686 days ago
Thanks for being tom, Frank.
Scratch that, I meant thanks for being frank, Tom. I agree that it is necessary to scare people out of buying tools like this sometimes even when they are just trying to save a buck… it’s not worth it. I see a lot of Craftsman tools come and go through our shop and I am always weary of them. Anything Craftsman with a cord I avoid like the plague. There hand tools are ok for shop use but if it plugs in it will probably either break or kill you.
View gizmodyne's profile
gizmodyne
1679 posts in 990 days
posted 686 days ago
Great review.
Just curious… 2 Stars for the outfeed? What are you holding out for?
View mot's profile
mot
posted 685 days ago
1 star because it does have a spinning blade that protrudes through the table. Another for the outfeed. I used to have a professor, while in University, who felt that a failing grade was a failing grade…why belabor the point. At that time, in Canadian Universities, the grading system was out of 9. A 4 was minimum pass. A 3 was a failure. A 1 and 2 were possible, but he figured they weren’t worth giving. A 3 made his point loud and clear. :)
14188 posts in 1060 days
posted 685 days ago
nice review ….. gives the beginners, such as myself, an idea of what to look for.
View CedarFreakCarl's profile
CedarFreakCarl
565 posts in 953 days
posted 682 days ago
Well Tom, I truly wish I had read your review in 2004, because in 2005 I bought one in 2005. I guess for 200 bucks it was ok. About a year later, I burned the motor up in it. I later bought a Ridgid TS3650. I’ve still got the Craftsman, but it is now the portable base for my OSS. It does that real well in that capacity. Live and learn.
-- Carl Rast, Pelion, SC
View Obi's profile
Obi
2191 posts in 1137 days
posted 680 days ago
I gave mine 2 stars. 1 for the same reason Mot did: it has a blade that spins and protrudes from the table.
-- http://ye-olde-cabinet-shoppe.com/
rikkor
posted 680 days ago
I threw my last Craftsman TS into the steel barrel at the recyclers.
Dick, & Barb Cain
7050 posts in 1199 days
posted 680 days ago
It’s way to bulky for a boat anchor.
View mot's profile
mot
posted 680 days ago
It’s too bulky but too light, Dick. It can’t weigh 60 lbs.
View dalec's profile
dalec
580 posts in 788 days
posted 676 days ago
Thanks for the review. It is great getting the real feedback with these LJ reviews.
Dalec
View Hawgnutz's profile
Hawgnutz
522 posts in 976 days
posted 638 days ago
I started out with this exact TS back in 2004. It served me OK, but it did have a lot of failings. These Craftsman saws are designed for thr weekend warrior doing a deck or some other one-time project. I bought mine because of eth wheels made it portable and I could wheel it in and out of my little storage area. I now have a Ridgid TS 2400 with big wheels! LOL
I made some great banwood frames with it, but I would NEVER buy another! It is strictly entry-level!
Nice review.
God Bless,
Hawg
-- Saving barnwood from the scrapyards
View Dave's profile
Dave
6 posts in 409 days
posted 401 days ago
Mot, I am new to lumber jocks (and I know this is an old review) but felt I had to reply to this as I had exactly the same experience with this Sears saw! I did a couple of outdoor projects with it that did not requiure accuracy. Later I really tried to get it to cut straight and could not…I returned it to Sears after 6 months for a full refund and bought a General StarShop contractor saw. I wish it had cast side wings and a better fence but with some excellent jigs and an auxillary fence made of plywood it cuts pretty well now. I’m redoing all the door casings, baseboards and crowns using it and having a good time.
Dave
-- Dave
View 8iowa's profile
8iowa
592 posts in 661 days
posted 389 days ago
This Craftsman saw is typical of the introductory level table saws in that they are powered by universal type electrical motors. This is a much cheaper type of motor that has brushes and operates at very high speed, usually 5000 rpm and up. Since there are no standards for this type of electric motor they are often rated in amps. If the maker claims a horsepower rating you can be sure that it is suspect. Universal motors are noted for their short life.
Even if you are on a tight budget, at a minimum, look for a saw with an induction motor. The speed, amps, and frame sizes of induction motors are standardized by NEMA. thus they are easily replaced by an electrical motor shop. The horsepower rating is determined by a continuous load on a dynomometer with a temperature rise limitation.
View Gary's profile
Gary
44 posts in 378 days
posted 378 days ago
Unfortunatly, I have the same saw, a little to late reading your review. I could not agree with you more though and as soon as possible will be replacing it with one of better quality and more standard features, but for now it does ok.
-- Gary, Missouri
View Sawdust2's profile
Sawdust2
1190 posts in 987 days
posted 378 days ago
For a little comparison:
When I was 8 I was given a Craftsman saber saw (what we now call a jig saw).
When I was 58 it died.
Somehow one of the cooling impeller blades had weakened and bent. Could not be fixed nor replaced.
14949 posts in 751 days
posted 378 days ago
Thats what a review is all about. Well done Tom.
View Thomas Keefe's profile
Thomas Keefe
64 posts in 309 days
posted 67 days ago
I have pretty much the same saw. I paid about $200 for it about 4 years ago. I agree with everything
you said about the saw. I originally planned to buy a Jet Benchtop table saw from Sears. They appeared
in the catalog but were not in stock and did not become available for a long time after my purchase.
It seemed like some kind of bait and switch, but I don’t know if Sears or Jet was at fault.
Shortly after I started using the saw I realized that it had a lot of problems. But, there was no way my
wife was going to let me go buy another more expensive saw. Instead I made a lot of changes to the
saw to address its problems. I have not fixed every problem but I have improved it greatly. Here are
some of the things that I did:
1. Used a router to widen the miter channel out to a standard 3/4” x 3/8” and bought an Incra miter gauge. The Aluminum is very soft so I am not sure that it hurt the carbide bit very much. It does make a big mess and if you are not careful, you can destroy the top (like I did on my first attempt).
2. Sanded the coating off of the table top to expose the bare aluminum. Probably not necessary but I do like it much better.
3. Added supports on the left of the blade to support Zero clearance inserts. Made inserts out of 3/4” oak. This can be fairly tedious because of the irregular shape of the blade opening. I just did 5 and it took me most of the day to prepare them. They have four set screws that the insert rests on along with a nail in the back to hold it down.
4. The fence is quite flimsy and was canted toward the blade. So I added oak faces with embedded set screws so that I can properly adjust it. This of course invalidated the rule for fence alignment, so I had to buy new tape.
5. I just recently removed the old dust collection parts from the saw. (They never worked very well anyway.) This consisted of a shroud that went under the blade and a dust port. The shroud tended to jam and make it difficult to adjust the height of the blade. They work better now. I added a new dust port near the bottom of the case and have closed up some of the holes. I still have more work to do.
I agree that the wings are completely useless. They droop an awful lot to start with but also move with moderate pressure.
The fence also will move some when modest pressure is applied near the back. I don’t know if that can be corrected with adjustment.
The saw I have today I enjoy using even with its remaining problems. However, it is not the saw that
I purchased.
Tom
