Despite being kind to me, 4 years of use has been unkind to this compressor
Review by paxorion posted 09-08-2014 09:10 PM 4612 views 0 times favorited 11 comments Add to Favorites Watch
Despite being kind to me, 4 years of use has been unkind to this compressor No-picture-s No-picture-s Click the pictures to enlarge them
If there’s one tool I use every time I try to get any woodworking done, it’s my HF air compressor. Everytime I get any woodworking done at home, the first tool I fire up is my compressor. I purchased it on a whim 4 years ago, and was giddy to have pneumatic power for the first time. This bare bones unit has (and continues) to serve it’s duty, driving nails (I have a HF 18 gauge brad nailer/stapler) and blowing compressed air. There isn’t much to say about how well it does it’s job cause, well, it’s a compressor. It charges up and shoots air out whenever I pull the trigger for the connected tool. It’s permanently stored outdoors in a resin shed. Despite doing it’s duty, over what I would consider light use, I opted to give it a 3 star rating because of the number of workable (for the $40 price point) problems that popped up over the course of time.
  1. After a few uses I haven’t been able to charge the compressor past ~90-95 PSI. The first 3 times I fired up the compressor, it hit 100 PSI no problem, but after I’d say 3 months, I noticed it stopped charging past the 90 PSI mark. Despite hunting all of the (sparse) settings, I haven’t found anything that would indicate user error.
  2. The gauges and quick connect coupler isn’t securely fastened and can be easily moved with light pressure. This doesn’t mean functional issue, but is rather disconcerning when you’re trying to connect a tool in. The last thing you want to think is that you’ll be breaking off the coupler/valve. Which leads me to my biggest concern…
  3. After repeated usage, you may create a situation where the air leaks. I first noticed a problem about 2 months ago, when the compressor would keep cycling and never go past 20 PSI. The issue can be circumvented by closing the tank to tool valve, or lightly jiggling the quick connect coupler until it finds a position that doesn’t leak. A major nuisance and consequence of loose product quality/tolerances paired with (sadly light) usage wear and tear.
  4. One may argue this has to do with tank capacity, but I find that the compressor seems to almost always be cycling. At 3 gallons, it doesn’t take much to exhaust the air supply, but it charges very slowly.
Summing all of these things up, and paired with the price, I think it was a fair buy for the price, and a good first compressor to buy IF you are a very time-strapped hobbyist who is almost never in “the shop”. It certainly is workable for the foreseeable future for me, as I don’t use it every day (or every weekend for that matter). But I am starting to worry that it will stop working on me mid-project. Once the unit finally bites the bullet I do not think I will be replacing it with another HF oil-less unit, but rather will spend a bit extra for a better unit.
-- paxorion
View paxorion's profile
paxorion
1107 posts in 2286 days
11 comments so far
runswithscissors
2928 posts in 2265 days
#1 posted 09-09-2014 06:34 AM
Couldn’t at least some of those components (such as the quick connect fitting) be easily and cheaply replaced? Even a pressure regulator should’t be that hard to do (you seem to be saying it doesn’t have one?). It’s simple to adjust those for both maximum pressure and minimum (where it kicks in). And of course all fitting should be done with teflon plumbers tape.
View StumpyNubs's profile
StumpyNubs
7690 posts in 3041 days
#2 posted 09-09-2014 12:50 PM
It’s a shame that things don’t last these days. I also have one of these and it’s still fine, but I use it very little.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2610 days
#3 posted 09-09-2014 01:47 PM
It s a shame that things don t last these days.
- StumpyNubs
They still make things that do, just not compressors for 40 bucks (not bashing HF, I own quite a few things from them).
View brtech's profile
brtech
1054 posts in 3163 days
#4 posted 09-09-2014 02:25 PM
We had an early version of this unit in a traveling kit for a national sport event series (fencing, with swords). For like 8 years this unit sat in a storage case and got loaded into trucks and sent hither and yon across the country. Every month for 10 months it would be in a new city. In about half the events, it got pulled out and used, mostly for replacing rivets. The pressure sensor stopped working after a few years, so it basically always cycled, unless you manually turned it off. Damn thing would not die. Actually, I think it’s still in the kit, but the use for it went away a couple years ago.
paxorion
#5 posted 09-09-2014 03:28 PM
Couldn t at least some of those components (such as the quick connect fitting) be easily and cheaply replaced? Even a pressure regulator should t be that hard to do (you seem to be saying it doesn t have one?). It s simple to adjust those for both maximum pressure and minimum (where it kicks in). And of course all fitting should be done with teflon plumbers tape.
- runswithscissors
I do suspect that some diagnosis and tweaking will address point #3, maybe #2. Nevertheless, I stand by my 3 star rating as these developed over time of very light use. I’m unwilling to go lower because it is functional and does a the job at being functional.
-- paxorion
View dschlic1's profile
dschlic1
442 posts in 2210 days
#6 posted 09-10-2014 05:22 PM
I have that same compressor. About a year ago it developed the same problem you have would not go above a certain psi. I disassembled the compressor end a discovered some debris in the valves. Clean it up and now it works like new.
paxorion
#7 posted 09-10-2014 06:19 PM
- dschlic1
Compressor end? The release valve at the back of the compressor?
-- paxorion
dschlic1
#8 posted 09-11-2014 04:43 PM
There is one valve in the head (looks like a flat piece of metal, and another I believe in the piston. Valves on these small compressors are usually just a flat piece of metal that rests against a seat. Functions like a one way check valve.
View Todd's profile
Todd
411 posts in 1917 days
#9 posted 09-11-2014 09:50 PM
Had mine for a couple of years with no problems. Used it a lot for finish nailing.
-- Todd, Huntsville, AL
View NormG's profile
NormG
6378 posts in 3244 days
#10 posted 09-13-2014 07:12 PM
I have the tank version it is does pretty good for what I need
-- Norman - I never never make a mistake, I just change the design.
View dhazelton's profile
dhazelton
2805 posts in 2537 days
#11 posted 09-15-2014 12:58 PM
”....or lightly jiggling the quick connect coupler until it finds a position that doesn’t leak” – shoot some WD40 or something in the end of the hose. Sometimes the little ball bearings in there get gummy and don’t fully seat.
