Good Product, but isn't it overpriced?
Review by PurpLev posted 496 days ago 1382 views 1 time favorited 28 comments Add to Favorites Watch
Good Product, but isn't it overpriced? Good Product, but isn't it overpriced? Good Product, but isn't it overpriced? Click the pictures to enlarge them
So I went to an Estate Sale, and found this Starrett 12” combination square still in the original packaging with the nylon wrap, and for $20… obviously I snagged it before anyone else had the chance to even think about looking at it…
I recently commented on teenagerwoodworker review of his Empire combination square. I’ve been using the Empire squares for the longest time, and had great results with them (12”,6”) they are accurate, slide fairly smooth, and lock pretty ok…. and they are $9-$6 respectively.
So I figured I might as well run a head-to-head test between my $9 Empire square, and my newly purchased (originally priced at $50-$70) Starrett which everyone is raving about.
1st test: Appearance and machining
I’d be honest – I like the way the Starrett look and feel, it’s heftier, and the chrome ruler, and cast iron head look nicer. I also like the finer measurements on the ruler – which – is the primary reason I wanted to get this one over the Empire. Also look at the picture above – you can see the difference in the groove in the ruler – supposedly make it slide smoother- does it really ? maybe… by just a little, does it lock better? maybe , but to be fair – when it locks it locks well, as with my empire I had on occasion locked it and the ruler slid off… but maybe it was me.
If you’ll look closer at the parts that make up the Starrett you can see that the materials are of better quality, thicker, and machined to a better degree.
2nd test: Leveling
I took an extra level, and put both combination squares on both sides of the level when it wasn’t completely leveled to ground. you can see from the picture that the Empire square has a similar size leveling capsule and looks similar to the level, whereas the Starrett has a smaller capsule, and the off level seems more pronounced. better worse? I guess its a matter of opinion…
Levels Off
Notice that when I did level the surface both combination squares show same result:
level on
3rd test: Squaring the ruler
For this test I took a piece of wood, butted the combination square against it’s edge, and drew a line along the ruler – then flipped the square 180 to it’s other face, and drew a second line at the same place I did the first line. reason dictates that if the combination square is really square and accurate- both lines should merge into a single thin line – and as you can see from the picture- both squares produced the exact same result – accurate and precise! the starrett is the line on the left, and the Empire is the line on the right:
Lines
Conclusion?
I am a sucker for quality tool like every other person reading this review… so I appreciate the fact that I got this Starrett combination square, and for the price I got it – It’s definitely worth it, but compared to the Empire – if the Starrett was at it’s original market price- I don’t think I’d EVER buy one not at 600%-700% of the Empire price.
Good tool, feels good, looks good, GREAT measurements (64th”), but personally I think it’s over hyped. If you have a good accurate Combination square – don’t feel like you’re ‘behind’ go make some square lines!
View PurpLev's profile
PurpLev
2752 posts in 543 days
28 comments so far
View sIKE's profile
sIKE
1094 posts in 648 days
posted 496 days ago
Nice to see a comparative review of these two products. I surprised not to see a big difference in fit and finish of the Starrett product.
View Chris 's profile
Chris
1469 posts in 886 days
posted 495 days ago
Thanks for the review… I spoke with a machinist friend of mine regarding why the Starret would be worth the cost and he said time is the real test; that he has had quite a few different rules and squares that started of good but after use & abuse could not keep up with his demands and only the Starret did. Maybe that the case here?
I can’t say for sure as I don’t own either of these combo squares. I just thought it might be food for thought…
-- Chris
View depictureboy's profile
depictureboy
306 posts in 537 days
posted 495 days ago
I wish I could find stuff like that. I always find out about the sales after they are done, or they are too far away to reasonably get to on a busy weekend. The one time someone close by had some stuff, they knew what they had and it was all marked accordingly…sigh
I was lucky enough to snag some waterbed railings a couple weeks ago. Sure its probably only pine, but it was free, thick, and wide….all the rails were about 8/4 by 10 or 12 inches…the only problem is they have a finish on them, but I figure I can resaw that off. Gives me some play around wood.
but my dream is to find a decent jointer or fore plane, maybe a jack or smoother for a song…hehe. Course I think I share that dream with a lot of people.
by the way I went out and got the empire 6” pro version based on your recommendation in your other review(I think it was yours) eheh
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View steveosshop's profile
steveosshop
208 posts in 520 days
posted 495 days ago
Nice review and nice find for $20. Its good to know that a less expensive square holds up to an extent with the more expensive squares. But I guess if you need pinpoint percission the price may not be a big deal. I still think thats a great find at $20.
-- Steve-o
View BroDave's profile
BroDave
86 posts in 709 days
posted 495 days ago
Looking through Empire’s specs I can’t find any mention of the squareness on their combo squares, other than the True Blue level vials.
Starrett specs. for the 12” combo is guaranteed accurate to +/- .00001”
I believe the difference can been seen if you miter a corner with each square and cut on the line.
The Empire square would be perfectly fine if marking rafters or joists, if you build a chest or a box, not so much.
I freely admit, I am anal retentive about square, plumb and level when there just isn’t any need it, like cutting the end of a log with a chain saw, character flaw on my part.
What I’m saying is the two tools have different intended uses.
PurpLev
posted 495 days ago
Chris – I thought about the time issue as well, and although I have been using the Empire for several years, it’s still somewhat of a short time, and since I am the weekend warrior – I haven’t really stressed out any of my tools – so thats a good point you mentioned there… I guess time will tell us all.
BroDave – Empire Pro combination squares are guaranteed to within +/1 .0001” (one thousand of an inch) – it’s a nice thing to see that Starrett has a guarantee for a higher precision than that… but as woodworkers – I don’t really reckon we need that much precision do we? even to setup our tools and tables… but one point you mentioned was the 45 miter angle which I forgot to cover in this test… I’ll try adding that up later… another part of the tool that is critical and was overlooked.
BroDave
posted 495 days ago
”Empire Pro combination squares are guaranteed to within +/1 .0001” ”
Ahh, I could not find that on their site.
“but as woodworkers – I don’t really reckon we need that much precision do we?”
It’s that anal retentive thing again Old Son. Probably don’t need it, just bothers me that I can’t get it. :D
Bench rest shooters have a saying.
Accuracy is a tiny hole that consumes huge amounts of money.
PurpLev
posted 495 days ago
Hmm…. so I went to check Empire website, and you’re right – the guarantee only refers to the Vial and within 0.001”... I bought this a while ago, and I forgot what it was referring to… good catch – my bad (PS- I accidently wrote an extra 0 on my last post… I was thinking one thousands of an inch, but for some reason added one too many 0 to it making it 1 ten-thousands of an inch)
I’m anal about precision and quality… but only to a certain degree where it doesnt hurt me… BroDave – I guess you surpass me on that one by a mile… ;)
But all said and done – it is true that the Starrett is much better made (material, machining, etc), and I can see it go for $30-$40… but not twice that much… I just don’t see the reasoning – is there such low demand for it that there are less products sold that they need to get their money’s worth?
View gizmodyne's profile (online now)
gizmodyne
1675 posts in 984 days
posted 495 days ago
Interesting review.
My thoughts:
I have never leveled anything with a combination square. Although you’ve got me thinking about what I could level.
I have found that the Starret handles more abuse (if you drop it per say (don’t ask how I know)).
Also the Starret has multiple styles of marking the various fractions. You can use a different side for each.
I would buy the Empire to lend to others though.
View sIKE's profile
sIKE
posted 495 days ago
Gizmo,
You slay me, buy a combo square to loan …..
25801 posts in 1295 days
posted 495 days ago
Thanks for the review and all of the comments.
BroDave
posted 495 days ago
Oh yeah, I pegged the weird meter long ago.
I don’t mean to knock the Empire square or hi-jack your thread at all though.
I have several brands and types of squares in shop and they all have their place.
PurpLev
posted 495 days ago
BroDave: hijack the thread? are you kidding? isn’t this is what its supposed to be? sharing info between everyone – the more input we get from more people, the closer we get to a real point of view. thanx for butting in… lol
View Tom Adamski's profile
Tom Adamski
309 posts in 665 days
posted 495 days ago
It is what it is… ! Starrett makes precision measuring and marking tools for people who value precision in their work. Price is subjective… Starrett charges what the market will bear. I love mine and consider it an investment in the future of my work. Should you decide your $20 Starrett is a needless frill, I’ll offer you double your money back. <g>
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
View sIKE's profile
sIKE
posted 495 days ago
I’ll plus $1 that offer >:)
BroDave
posted 495 days ago
Oh no you two, I’ve been working on Purp all day, anyone gets the Starrett for less than he paid for it it’s got to be me. Naturally I would be happy to entertain any reasonable offer…
PurpLev
posted 494 days ago
I’ll think about it guys…
20667 posts in 716 days
posted 494 days ago
This is a nice review and you found a nice tool at a bargain price. I have been considering buying one of these simply because I enjoy quality tools (I have 4 combo squares now). But given your review I may just hold off until I can find one at a bargain price.
View miles125's profile
miles125
1425 posts in 900 days
posted 494 days ago
I can’t say i’ve ever run into a square that wasn’t square enough for woodworking. Maybe irritated by the occasional cheapo that doesn’t slide and lock down good. Put me in the “have a bunch of em at less than ten bucks” category for the increased odds of getting my hands on one when i need it.
depictureboy
posted 494 days ago
gizmo I use mine to help set my router bit height. I set the measurement I want on the combo, set the ruler end on the table and raise the bit until the bubble is off-level, then lower the bit till its just back to level. Seems to work for me.
View Dusty56's profile
Dusty56
3462 posts in 583 days
posted 492 days ago
Yes the look and “feel” of the Starret brand is superior , but that’s a whole lot of money that I’ve put elsewhere and the squares that I have purchased for much less are STILL square for some reason …..go figure !
View Billp's profile
Billp
330 posts in 1094 days
posted 492 days ago
Iam still using the 12” starret I bought in 1972 and it’s just like the day I bought it. You get what you pay for.
-- Billp
View CessnaPilotBarry's profile
CessnaPilotBarry
1273 posts in 597 days
posted 472 days ago
My all time fave is a 6” Starret combo that rides in my apron. It’s always ready to check a tool or a cut edge.
I also have a 12”, with an additional 24” blade. Having had lots of layout tools, the part of Starret squares that keeps me coming back is consistency. The lock always works well, it stays square, the scribers always fall out and get lost <g>... I find the Starret blade the easiest to read in many different conditions, which is very important to me.
I have some others, ranging from cheap, and varying to the same price as the Starrett tools. The cheapies have a place, but none have the same day to day feel as my Starret versions.
FWIW, I’m not a brand loyalist. My favorite tapes are $7 Fast Caps, and my “reference” straight edge is a Veritas. I don’t like Starret tapes, and the Veritas edge is good enough for my uses.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
CessnaPilotBarry
posted 472 days ago
Sorry to reply to my own post, but I left something out…
When I decide to spend on an expensive vs. cheaper tool with similar capabilities, one of the big factors is frequency of use. My 6” Starrett square can be touched literally 100 times in the course of a woodworking session. It gets used every session where wood size or shape is changed. About the only other tool where I can say the same is my tape, where I prefer a cheap Fast Cap.
To me, such a frequently used tool should be the version that feels exactly right to our own personal taste, regardless of cost.
BTW… A very nicely done, thought provoking review.
View Sawdust2's profile
Sawdust2
1186 posts in 982 days
posted 472 days ago
Given that the IWF is coming the end of this month I think I’ll post a little note with this.
Last time IWF was in town I was able to get a number of good deals on a number of products, including a Jet 14” bandsaw with riser and an Apollo HVLP sprayer. (To me a good deal is better than 30% off list.)
I stopped at the Starrett display and asked if they had any deals.
“Nope.”
“Why not?”
“Because we don’t have to.”
‘Nuff said.
View Derek Cohen's profile
Derek Cohen
48 posts in 863 days
posted 468 days ago
The review here looks at whether the squares are … well .. equally square and that their level bubbles line up … and then concludes that, since they do the same thing, therefore the Empire is equal to the Starrett and why pay the extra?
With this thinking, all planes are the same, all chisels are the same, all tablesaws are the same, all routers are the same ….
What about the construction of the two – materials used, construction, and finish. What about how they work in practice – which is easier to adjust, and how they feel in the hand. Does one want you to use it more than the other?
I have a Starrett (I have 4 different sizes, all purchased on eBay quite cheaply). I have the Empire (purchased before I knew better). There is a WORLD of difference between them: try a Starrett and feel it glide silkily. Notice the spring-loaded knob. Become aware of the reflection nature of the steel rule that is hard to read on the Empire but easy to do so on the Starrett. The Starrett comes in two finishes – chrome and matt. Check out the etching of the numbers, which is clearer. Guess what?!
Yes the Starrett is several times more expensive. If all you can afford is the Empire you are doing fine. At that price range it is a good enough square. But don’t compare it with a Starrett. It does not rate.
Regards from Perth
Derek
-- Building and Reviewing Tools at http://www.inthewoodshop.com
View gusthehonky's profile
gusthehonky
131 posts in 637 days
posted 468 days ago
Thanks for your post, a very thoughtful point by point comparison. I had often wondered the same. After reading I went to the basement to see what types I owned, most found at flea markets, yard sales, BORG. Mainly Empire, 2 Starrett , and some Brown and Sharpre, and a very nice Union. I own the 6” Empire, which I use often in the shop. They work well enough for my needs, but when a rafter square is used daily for work, who am I talk precision. Sadly many of mine, clearly designed and built to a finer degree, long histories of improper upkeep is clearly visible. However, despite abuse, quality is still evident despite rust, knicks, etc. I guess, like anything, its up to the buyer to justify expense of any purchase. Bottled water for example, comes to my mind, empties litter my shop and truck. Should anyone know anything about the Union or B&S, how they compare to the Starrett, please let me know, seem to be very well built & relialable. Maybe the most expensive ones never lose their scribes.
-- Ciao, gth.
View Vince's profile
Vince
16 posts in 350 days
posted 349 days ago
Never loan out your tools…......
