Can't believe how smoothly this jigsaw cuts
Review by CharlesA posted 08-15-2014 01:52 AM 8050 views 1 time favorited 33 comments Add to Favorites Watch
Can't believe how smoothly this jigsaw cuts Can't believe how smoothly this jigsaw cuts No-picture-s Click the pictures to enlarge them
For years I had a Skil jigsaw, a hack tool if there ever was one. I got in the habit of always cutting well outside the line and then sanding down to the line because of the roughness of the cut, no matter the blade or cutting mode on that machine.
I found this Bosch on the CPO website for about $95 18 months ago. The first thing I noticed was how big and hefty it was compared to the Skil I think that helps stabilize it on cuts.
I’ve mainly used it for rough work. Yesterday I needed to put a slight curve on the two side ends of a long board. After drawing the line, I stayed well outside it to sand up to the line afterward. I was stunned, stunned to see the surface of the cut when I had finished—almost had a planed finish. This was a small cut, so I had a little line where I entered the cut, but after seeing the surface, I realized I could cut closer to the line.
If there are better jig saws out there, I’d love to see how they’re better. I’m sold.
View CharlesA's profile
CharlesA
3329 posts in 1821 days
33 comments so far
View waho6o9's profile
waho6o9
8207 posts in 2600 days
#1 posted 08-15-2014 04:35 AM
Good review and the resulting cuts are nice to have.
A used a Bosch blade on my jig saw and was stoked at
the results.
Craftsman on the lake
2794 posts in 3461 days
#2 posted 08-15-2014 01:22 PM
I agree. I have one of their jigsaws. With the right blade and setting it can be smooth and with another blade and setting it can be very aggressive. Mine has a little adjustment on the side. On one setting the blade just moves up and down. on other settings the blade rotates into the cut so the blade lunges forward for every down stroke. You can cut through a piece of plywood you’re rough cutting pretty much as fast as you can push the saw.
CharlesA
#3 posted 08-15-2014 02:32 PM
Yes, this one has multiple settings from quick to smooth cut. My Skil had a two-option setting, but I couldn’t tell that much difference. Bosch is a big step up.
View Manitario's profile
Manitario
2630 posts in 2906 days
#4 posted 08-15-2014 03:03 PM
My dad wanted a jigsaw so I bought this for him for his birthday; he loves it. It’s amazing what a difference good tools make!
View Julian's profile
Julian
1347 posts in 2714 days
#5 posted 08-15-2014 03:21 PM
I have the same jigsaw. Previously I had a Black & Decker jigsaw which cut rough and vibrated a lot. Bosch makes good quality tools in my opinion.
-- Julian
View BoardSMITH's profile
BoardSMITH
121 posts in 2287 days
#6 posted 08-15-2014 04:02 PM
Remember, Bosch invented the jig saw in 1947 in Switzerland. The others are just cheap knock-offs. I have a Bosch jog saw I bought in 1990 and it still works very well.
Their blades have individually ground teeth as opposed to the much cheaper stamped blades everyone else uses.
-- David www.TheBoardSMITH.com
View MrRon's profile
MrRon
4793 posts in 3267 days
#7 posted 08-15-2014 04:11 PM
I’ve used Bosch jigsaws for the past 30 years and see no reason to ever use any other brand. My first jigsaw was a “scroller” by Crapsman. It broke soon after buying it.
View Billy E's profile
Billy E
162 posts in 2104 days
#8 posted 08-15-2014 06:23 PM
I have a Bosch jig saw and, aside from one issue, it is a great saw. That one issue is blade changeout. I don’t think the model you are describing is like this, but mine uses a crank on top of the handle to tighten or release the blade. It’s a horrible design. Anyone reading this—check the issue of blade change before you buy a Bosch jig saw. Some are really easy and some are a pain.
-- Billy, Florence SC
CharlesA
#9 posted 08-15-2014 06:42 PM
This one has easy tool-less blade change.
View Earlextech's profile
Earlextech
1162 posts in 2714 days
#10 posted 08-15-2014 07:01 PM
Over the last 30 years I’ve had two Bosch Jig saws! I wouldn’t have any other!
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#11 posted 08-15-2014 07:01 PM
I have an older Bosch jigsaw from before tool-less blade changes but it’s a great saw, much better than any other I’ve used.
View TheFridge's profile
TheFridge
9606 posts in 1510 days
#12 posted 08-15-2014 07:17 PM
Is it like a rainbow in the dark?
View Routerisstillmyname's profile
Routerisstillmyname
763 posts in 3533 days
#13 posted 08-15-2014 09:09 PM
Add a zero clearance and it gets ever better.
-- Router รจ ancora il mio nome.
View exelectrician's profile
exelectrician
2327 posts in 2451 days
#14 posted 08-16-2014 03:35 AM
I totally agree.. I also went from a Skilsaw to the Bosch and was I blown away. I simply could not believe how easily I went from a bucking bronco to a silky smooth swiss sewing machine with only one trip to the store.
-- Love thy neighbour as thyself
View Dutchmn's profile
Dutchmn
27 posts in 1803 days
#15 posted 08-16-2014 08:30 PM
Thank you for the review, I went out and bought one of these today on sale at Menards +the 11* rebate it came to $115 and wow what a difference a good saw makes , I always thought my bad cuts were me not being able to use a jigsaw and now I know it was the saw.
showing 1 through 15 of 33 comments
