Review: ETS 125 EQ Random Orbital Finish Sander
Review by pashley posted 08-10-2014 02:54 AM 8711 views 0 times favorited 21 comments Add to Favorites Watch
Review: ETS 125 EQ Random Orbital Finish Sander No-picture-s No-picture-s Click the pictures to enlarge them
REASON I BOUGHT A NEW SANDER: Sanding is not my favorite part of woodworking. I want the best result as quick as possible. I even considered getting a drum sander, but at $800+ and a chunk of floor space, I was reluctant. My DeWalt ROS would leave a lot of swirl marks, costing me time – in finding the swirls marks, and finding them after I started finishing! Also, the DeWalt would not do dust collection well. So, in an effort to finder better sanding down quicker with better dust collection, I went for the $195 ETS 125 EQ Random Orbital Finish Sander, plus $60 for 80 and 220 sanding pads.
EVALUATION: The unit is much lower in vibration and noise then my previous ROS sanders. You notice that the sander will “chatter” when it hits an uneven spot, because the platen the sanding disk attaches to is very flat and hard. This is actually a benefit because you know there is an issue in this area of the wood. It takes a bit of getting used to. The fit is comfortable, and it has a variable speed dial, which when turned all the way up is not that fast, but it doesn’t need to be, because of the results it gets.
DUST COLLECTION / POWER DOWN: The unit has an onboard cardboard bag, meant to be replaced – but can be emptied out, so you can reuse it many times. It collects dust vey well with this option, but is almost dustless with a vac. I can just attach my VacMaster (review of that is here), because they have a proprietary size port meant for their expensive shop vacs. I couldn’t find an adaptor.
When you turn off the unit, it powers down very quickly – about ½ second. This is wonderful because I no longer have to wait for the sander to stop spinning so i could set it down, which usually took about 5 seconds. Not an issue now!
SANDING / SANDING PADS: The sanding leaves no swirl marks. None. The reason for this is because of the very small rotational distance. And that is with 80 grit as well. The sanding is fast and very smooth. Impressive. The sanding pads, while expensive (the cheapest is about 34 cents each for a 1000 disks) DON’T clog, and last along time. Definitely a better value then what you’d buy at a big-box store. And they have a huge range of grits – from 24 to 1500 grit!
BOTTOM LINE: I am very impressed with this Festool sander. I love that it saves me time, gives me a better finish with no swirl marks, collects dust much better and the quick power down. I really see no down side to this sander, and will consider buying another Festool product when the time comes – I’ve been eyeballing their Jigsaws.
See the ETS 125 EQ Random Orbital Finish Sander here.
-- Have a blessed day! http://newmissionworkshop.com
View pashley's profile
pashley
1043 posts in 3713 days
21 comments so far
View waho6o9's profile
waho6o9
8189 posts in 2572 days
#1 posted 08-10-2014 03:06 AM
http://www.bobmarinosbesttools.com/article.asp?ai=209
Now’s the time to get in on the recon sale.
Great review and it’s one of the best finish sanders on the market
no doubt.
View cabmaker's profile
cabmaker
1730 posts in 2804 days
#2 posted 08-10-2014 03:14 AM
You will enjoy the ets 125 paired up with their extracteor it is nice. You will also like their jigsaw I only use the Bosch for coarse work now!
Jb
HillbillyShooter
5811 posts in 2288 days
#3 posted 08-10-2014 03:49 AM
Congratulations! You’ve just taken the first step to what can become an addiction. I started with this same ROS several years ago and have succumbed to being a green/black tool aficionado. If I might, I’d strongly suggest you check out their dust extractors. And, yes the sand paper is not inexpensive, but it lasts and does a great job. Best wishes and enjoy.
View Woodwrecker's profile
Woodwrecker
4148 posts in 3571 days
#4 posted 08-10-2014 02:03 PM
Good review.
I do a lot of sanding, and may need to look into one of these when it’s time to replace my current sander.
Thank you.
-- Eric, central Florida / Utor praemia operibus duris
View michelletwo's profile
michelletwo
2735 posts in 3011 days
#5 posted 08-10-2014 09:12 PM
i have one too, and it is all this review says.
View Dan'um Style's profile
Dan'um Style
14172 posts in 3978 days
#6 posted 08-10-2014 11:17 PM
Good review and I also enjoyed the link to the shop vac.
View Matt Przybylski's profile
Matt Przybylski
546 posts in 2373 days
#7 posted 08-11-2014 01:42 PM
I have the 150/3 version which has a 6” pad and I also bought the hard pad (it comes with the soft if I’m not mistaken). I too have a CT36 and you can sand without a respirator the dust collection is that good. I love this sander.
-- Matt, Arizona, http://www.reintroducing.com
View JohnChung's profile
JohnChung
408 posts in 2070 days
#8 posted 08-11-2014 02:15 PM
How is this compared to Bosch ROS? Any opinions?
JohnChung
#9 posted 08-11-2014 02:15 PM
Todd A. Clippinger
8901 posts in 4095 days
#10 posted 08-11-2014 02:57 PM
JohnChung – I own the Bosch 6” sander (I have 2 of them) and I have a few hundred hours on the Festool doing work for Andy Chidwick building dining chairs (professionally, not as a student.)
Both are great machines. For flatwork or casework, I would put the Bosch up against the Festool any day of the week. But when it comes to sculpted work, Festool is the only good answer.
The sanding pattern is a bit different on the Festool than most other R.O. sanders. It seems to be more rotational and so it handles a bit different but it does an amazing job.
I think the Festool sander’s design is a bit more ergonomic when it comes to doing sculptural work than the Bosch design.
The Bosch R.O. sander is more conventional in it’s pattern but they seemed to have pinned it down pretty good because their machine has the right amount of aggressiveness and finesse combined. It leaves a perfect finish and I rarely ever sand past 180 grit.
I like the fact that with both the Festool and Bosch I can choose to use a hard or soft sanding pad. I prefer the hard sanding pad to keep edges crisp on flat work or case work projects, and the soft pad works better if curves are involved.
I think the quality of both machines is fitting for the professional. My Bosch sanders have a million miles on them after years of use as a professional. The only thing I have had to do is replace worn sanding pads, cords, and motor brushes.
Both have great dust collection when hooked up to a shop vac and I think that is the only way to go. The dust canisters on any R.O. sander fill quickly and then the dust becomes an issue.
I hope this information helps in deciding between the two.
pashley
#11 posted 08-11-2014 03:06 PM
JohnChung – the Bosch was pretty good, even the dust collection, but left swirl marks, and died after 2 years.
Todd A. Clippinger
#12 posted 08-11-2014 03:24 PM
After the pinch on the front-end, I never regretted spending money on any of my Festool machines.
I have a track saw, the Domino, and a planer by Festool. All fine machines.
Sorry your sander died after 2 years, I have been using mine for 15 yrs. My Bosch tools have held up to the pro contractor and custom wood shop standards and have never let me down. However, I don’t believe any company makes the best of everything.
Milwaukee tools have not been good to me. I will not buy any more of them.
View SteveMI's profile
SteveMI
1094 posts in 3290 days
#13 posted 08-11-2014 03:30 PM
I have a Bosch ROS and it has been great for everything the past several years with the exception of veneer parquetry. Like most all ROS the Bosch and 150 have some weight associated with them. They didn’t seem to run as flat, maybe due to the offset handle weight. More than a few projects became non-commercial after a slight tip (maybe operator error) with the Bosch that created a divot type mark.
So, couple months ago I borrowed a friends 125 and a Rotex and it opened a whole new potential. First the 1250 weight is seriously less which gives you more control on veneer. No lost work since using it. The Festool Garnat paper gives great results on veneer. Only took a couple days of use to go buy a 125.
This is a “finishing” sander so the power isn’t the same as most all other ROS I have tried. The sales person sold me a wool buffing H&L pad for it and the 125 will not spin it with any kind of wax. Pad works fantastic on the Bosch. The ETS 125 is not a Rotex model and only has random orbital, no eccentric motion option.
Full disclosure: this is only Festool I own.
Steve.
Todd A. Clippinger
#14 posted 08-11-2014 03:35 PM
Steve – Oh good point, I used the Rotex model. I actually have not used this one. Crap I need to pay closer attention.
I have sanded a lot of different types of veneer with my 6” Bosch and have had no problems.
Todd A. Clippinger
#15 posted 08-11-2014 03:39 PM
Festool does sell itself. I also have the Kapex. I thought it was just an over-priced luxury miter saw until I used one extensively on a job site that someone else owned.
After using it day in and day out, I came to appreciate it’s accuracy, speed of settings, and that unbelievable dust collection.
All of a sudden, $1400 for a miter saw was justifiable as a business.
I think the Festool sanders are the same.
