Good bandsaw for a small shop
Review by MoshupTrail posted 06-07-2014 09:07 PM 12430 views 0 times favorited 18 comments Add to Favorites Watch
Good bandsaw for a small shop Good bandsaw for a small shop No-picture-s Click the pictures to enlarge them
I wanted a small bandsaw to cut some curved parts from time to time. When I saw this one at Menards for just $229 it just had a look of being solid and the right thing for my small garage shop. The table is cast iron, and the housing is heavy duty steel and the motor appears to be a sealed 1/2 hp motor. You can see the specs at Menards site.
Assembly was pretty easy, but I did not choose to assemble the stand. The directions are pretty typical – you have to read carefully twice to understand what they mean and translate all the obscure part references to the mess in the bag.
The only problem I had was that after I leveled the table left and right, I noticed that it wasn’t level back to front. There is no adjustment for this. You see the gap between my little square and the blade in this picture.
So I took out the two lower bolts holding the trunion to the housing (next picture)
And I found a couple of thin nylon spacers to add between the trunion and the housing.
Which seemed to just about fix it perfectly.
Finally, I tried sawing a few scraps. Starting with a 1/16” slice off a pine board.
Then I drew a curve on the board and tried cutting that.
The saw cuts well and is very stable. Although it cut smoothly I don’t think the blade is very good. It makes a click-click sound as it goes around. I think it’s the weld. But the blade is easily replaced with a nice one from Highland Woodworking.
On the whole, I think I’ve got a great band saw for a small shop!
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
View MoshupTrail's profile
MoshupTrail
304 posts in 2567 days
18 comments so far
View NormG's profile
NormG
6216 posts in 3090 days
#1 posted 06-07-2014 09:23 PM
I have the 12” craftsman model. I had to do the same thing with mine and used thin metal washers.
-- Norman - I never never make a mistake, I just change the design.
View MrRon's profile
MrRon
4928 posts in 3330 days
#2 posted 06-07-2014 10:54 PM
Looking at the manual, it looks pretty good. The blade guides and frame are surprising. They look like features that come on more expensive machines. I hope it serves you well. Keep us posted as to how it holds up.
View Buckethead's profile
Buckethead
3194 posts in 1955 days
#3 posted 06-07-2014 11:33 PM
That looks just like the rikon bench top band saw I’ve been seeing in the fliers from my local WoodCraft store. Looks like a win!
-- Support woodworking hand models. Buy me a sawstop.
MoshupTrail
#4 posted 06-08-2014 01:05 AM
@MrRon – you are correct! The guides are all ball bearing rollers, and the frame is rock solid steel.
@Buckethead – I noticed the resemblance to Rikon too.
View Joe Lyddon's profile
Joe Lyddon
10210 posts in 4139 days
#5 posted 06-09-2014 03:52 AM
COOL lil bandsaw… nice FIX too!
View Surfside's profile
Surfside
3389 posts in 2260 days
#6 posted 06-09-2014 09:15 PM
Nice review! The cut looks pretty accurate. Good idea on replacing the blade, sample blades just suck.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View lab7654's profile
lab7654
266 posts in 2333 days
#7 posted 06-12-2014 01:28 AM
Just FYI, a click-click sound can mean a blade that’s ready to break. The stock blade probably just has an inferior weld.
-- Tristin King -- When in doubt, sand it.
View vbraddy17's profile
vbraddy17
11 posts in 1533 days
#8 posted 06-12-2014 12:17 PM
Nice review. I’m in the market as well for a small band saw. Thanks for the info.
View Farrout's profile
Farrout
185 posts in 3241 days
#9 posted 06-14-2014 02:50 PM
I have a 10” Craftsman and found that putting a premium blade on it made a big difference.
-- If we learn from our mistakes, I should be a genius!
View bleinmiller's profile
bleinmiller
1 post in 1422 days
#10 posted 09-30-2014 04:51 PM
Great review, I hadn’t thought to check Menards. Interesting how many times I’ve seen Rikon come up as a “same saw”. It was mentioned in a recent article that a Rikon, Craftsman, and HF benchtop were the same saw.
I’d like to know how common this is and if it also extends to larger, full height machines.
View CharlesA's profile
CharlesA
3334 posts in 1884 days
#11 posted 09-30-2014 04:55 PM
Not so sure about the HF. Their 14” is definitely not a Rikon, and their benchtop is a 9” that resembles it, but not sure.
View pillpod's profile
pillpod
6 posts in 1409 days
#12 posted 10-12-2014 08:24 PM
Hi,
I’m looking to buy a small bandsaw for the purpose of making bandsaw boxes. Have you attempted to cut anything close the thickness capacity that this saw can handle? If so, how did it do and would you recommend it?
Thanks!
MoshupTrail
#13 posted 10-12-2014 09:48 PM
Not exactly. I was trying to cut a shape on a 4×4 and noticed that I had to go slowly or risk slowing the saw to a stop. I have noticed that the blade that comes with it is not the highest quality. I would strongly recommend a replacement from Highland Woodworking. If your band saw boxes are small, say less than 3-4 inches, you could use this without much difficulty. Five inches will depend on the wood, and six is probably getting iffy. I think my blade is a 6 tpi. Maybe if I had a 3 or 4 tpi blade it might work better on thick blocks too.
View OldWrangler's profile
OldWrangler
731 posts in 1681 days
#14 posted 10-26-2014 04:38 AM
2 cents worth….. I was reading this as I am looking at several 10” band saws. I occurred to me I would or should stick my nose in with a recommendation. Timber Wolf blades are hard to beat. They come sharp, stay sharp and last about twice as long as Olsens and other more expensive brands. They are frequently on Ebay at great prices. And if you want to avoid blade drift, never use a blade with more than 3 teeth per inch (in any size)
P.S. I think I am leaning towards buying the Megaforce. Got some features the others don’t.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
MoshupTrail
#15 posted 11-23-2015 07:15 PM
Update: The motor has been starting real slow since last winter. It takes a while kind of loping along and then finally something takes and it speeds up to normal and it’s fine. But this weekend something went pop and the motor just hums. Trying to google and see if I can replace just the motor. Anyone know how to find one? I can do the wrench turning.
showing 1 through 15 of 18 comments
