Bosch 4100 left and rear extensions
Review by Holbs posted 05-18-2014 03:29 AM 4732 views 0 times favorited 7 comments Add to Favorites Watch
Bosch 4100 left and rear extensions No-picture-s No-picture-s Click the pictures to enlarge them
Wish I had known about these accessories sooner! For the last year, using the bosch 4100 table saw has been great, but these support extensions make me feel much more safer. These 2 extensions are a must have for the few left out there that use the bosch 4100. Granted, these supports do not replace TRUE structure table outfeed supports but for what it is, they are highly acceptable and affordable ($27 each?).
View Holbs's profile
Holbs
1984 posts in 2206 days
7 comments so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2546 days
#1 posted 05-19-2014 03:27 PM
I have the same ones, and indeed, they are a necessity. Just be careful with how tight you tighten the knobs, they just need a light touch.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1251 posts in 1890 days
#2 posted 05-19-2014 04:27 PM
Looks great. Where do you buy them?
And: Would you happen to know if they fit the Bosch GTS10 as well?
-- "Do or Do not. There is no try." - Yoda
Holbs
#3 posted 05-19-2014 11:13 PM
Ed… does your left sliding extension bar on the outfeed side, “rub” against the plastic chassis? Mine does. Unsure if my plastic is slightly warped or if I installed the bar holder backwards :)
Kaer… I bought mine on Amazon. One piece was $29, other was $25. Unsure if fits GTS10 as the bar holders fit pre-machined holes on the underside of the 4100.
BinghamtonEd
#4 posted 05-20-2014 12:49 PM
I’m not sure if it’s rubbing on the chassis, or maybe just the two rod holders (front and back) are not perfectly in line, but it did have some rubbing/tightness when opening and closing it. I put a coat of Johnson’s paste wax on it while waxing the table/fence and it helped a lot.
kaerlighedsbamsen
#5 posted 05-20-2014 08:02 PM
Might wanna check them out. Or perhaps make some myself. Thanks for clarifying!
View Hawaiilad's profile
Hawaiilad
3290 posts in 3198 days
#6 posted 05-23-2014 05:38 AM
Do the rods slide under the table when you want to store the saw? First time I have seen them as well…thanks for sharing
-- Larry in Hawaii,
Holbs
#7 posted 05-23-2014 05:45 AM
yes, the rods slide under the table. so you can collapse them out of the way, even if you used the gravity stand. The outfeet assembly sticks out an inch or so to give room for the fence end mechanism. They have knobs that you can tighten to lock into place.
