Penn State Industries 2.5HP Tempest S-Series Cyclone Dust Collector Temp1425S
Review by English posted 05-13-2014 10:48 PM 15027 views 7 times favorited 19 comments Add to Favorites Watch
Penn State Industries 2.5HP Tempest S-Series Cyclone Dust Collector  Temp1425S Penn State Industries 2.5HP Tempest S-Series Cyclone Dust Collector  Temp1425S Penn State Industries 2.5HP Tempest S-Series Cyclone Dust Collector  Temp1425S Click the pictures to enlarge them
I am a retired engineer. I have a 672 sq. ft. shop. I purchased my 2.5 hp Tempest S in Jan 2014. I built a isolated support stand out of 2” x 4” board and mounted the Tempest so that the top was at 110” about 10” from the ceiling. I installed a 6” sheet metal duct system made of 6” 26 gauge snap lock duct and 6” 26 gauge fittings. I was able to find the 26 gauge 6” duct, 90° elbows and reducers at Ferguson. I found the flue style wyes at Home Depot online. The 6” blast gates are shop made.
At start-up the Tempest was much louder than noted in the specs. The spec calls for 76 db out of the box. It was at 92 db. I first changed the discharge pipe from the blower to the filters from a metal duct to clear flexible pipe. This lowered the db reading to 86 db. I isolated the dust collector from the suction duct with a 6” section of 6” flexible duct. This lowered the db reading to 85 db. I then built a Muffler it is 38” long and 12” in diameter with a 6” inlet and outlet, it has a 1 ½” layer of acoustic foam and a 1 ½” layer of fiberglass insulation. To my surprise this only lowered the db to 81 db. My collector is installed in a corner with the motor blower unit only 10” from the ceiling. As I tested to see where the noise was coming from I decided it was from sound attenuation by the walls and ceiling in that corner, so I installed 1 ½” egg crate acoustic foam in the corner on both sides and the ceiling for 36”. This lowered the db reading to 76 db. 76 db is very tolerable, so I plan to leave it as is.
My worst case run of duct is 7” of static; the collector is pulling 1000 cfm at that SP. I have found that I can leave both 4” gates to the table saw and a 6” gate to the miter saw open and still get excellent dust pick up. I have 19 gates in my system and 200 ft total of 6” duct. The unit works great, no more big clouds of dust in the shop. I have installed a pressure gauge on my filters to let me know when they need cleaning, I also separated the filters by building a 2nd filter clean out base and installing a bullhead wye before the filters, this puts them in parallel. I installed a 6” blast gate between each filter and the wye. This allows me to close one gate at the top of one filter and open the re-circulation blast gate at the bottom of the same filter which reverses the flow through the filter and aids in the filter cleaning. I do this each day and my filter pressure readings are the same as they were when the unit was installed. The filter gates can be seen on the pictures above.
I highly recommend the 2.5 hp Tempest S. It is a great deal!!!
-- John, Suffolk Virgina
View English's profile
English
660 posts in 1711 days
19 comments so far
View djwong's profile
djwong
176 posts in 3454 days
#1 posted 05-14-2014 03:53 AM
That is really interesting about sound attenuation by the walls and ceiling, and your noise improvements by using egg crate foam. I have an Oneida 2.5hp super gorilla, and the noise is the one thing I hate about it, in my 400sqft garage shop. Thanks for posting your experiences with the Penn.
-- David W. Cupertino, CA
View Ken90712's profile
Ken90712
17614 posts in 3423 days
#2 posted 05-14-2014 11:22 AM
Great information on this product and what you did to improve the noise level. Very nice set-up
View Woodknack's profile
Woodknack
12455 posts in 2614 days
#3 posted 05-14-2014 01:05 PM
Good review and the sound reduction experiments are interesting.
View b2rtch's profile
b2rtch
4868 posts in 3282 days
#4 posted 05-14-2014 02:27 PM
Excellent review.
I have a 5HP Clear View, the suction is not what it should be, part of the reason being that I have an elbow right at the suction on the cyclone.
I should have a 5’ length of straight duct but I just do not have the space for it.
-- Bert
View sikrap's profile
sikrap
1121 posts in 3593 days
#5 posted 05-14-2014 07:13 PM
I have the same unit and I agree that it does a great job. My issue was with PSI because of parts being missing. The CS there is not great, but it is a great unit for the money.
-- Dave, Colonie, NY
View Binn's profile
Binn
93 posts in 3188 days
#6 posted 05-15-2014 02:34 PM
I would also reccomend coating all the duct work with Quiet Coat a sound barrier that you can get from Quiet Solutions. It is a waterbased coating to deaden sound, the company coats some on a drum cymbal and it does a great job stopping the ringing from the cymbal. They suggest coating the metal to keep from vibriating. Check it out !
-- Barry, Louisiana
View mantwi's profile
mantwi
312 posts in 2130 days
#7 posted 05-16-2014 01:33 AM
You can dampen the vibration considerably by using rubber blocks as washer/sound insulators at the points where the unit is fastened to the wall or ceiling. I worked for a company out of Nashville on a local recording studio and we isolated every potential source of vibration this way. It’s kinda like rubber motor mounts which keep the engine in a car from vibrating it to pieces. In addition to this use QuietBrace available at HD. It’s a modern version of the old Celotex sheathing and is very dense and designed for sound proofing. At under $9.00 a sheet a couple of layers would be both affordable and effective.
View bluekingfisher's profile
bluekingfisher
1311 posts in 3214 days
#8 posted 05-16-2014 07:55 AM
It would appear you have applied your professional skills to your woodworking hobby? Your system looks very efficient and will of course be beneficial to your health.
Have you incorporated a remote switching system? I did on mine although the magnetic switch on the 2HP chip collector did initially cause me some issues. I had to circumvent the coil starter in the switch and operate the switch on/off function by means of a cheap plug in remote switch operating on a 3A breaker. Works great. I have also considered rigging up an auto open/close system for my blast gates but as yet haven’t taken the time to figure out an operating plan. perhaps one day I’ll add it to my ‘to do list’.
Thanks for sharing
David
-- No one plans to fail, they just, just fail to plan
English
#9 posted 05-16-2014 02:11 PM
Barry,
Thanks for the comment. I have considered putting sound dampening on the cyclone, as for the duct-work the only time it produces noise is when sawdust is traveling down the duct. At those times a wood working machine is running and I am using hearing protection, so not a problem in my one man shop.
Mantwi,
Thanks for the comment. My DC is mounted on a 2×4 four legged stand that only touches the building on the concrete floor. No contact with the walls or ceiling. It rests on a 3/4” sheet of plywood that is inset into the top of the stand. The full circumference of the Cyclone rests on the plywood with 10 bolts. The egg crate foam has taken care if the sound attenuation.
David.
Thanks for your comment. I have not yet install a remote. I plan to use PSI’s 220V Long Ranger Heavy Duty Motor Starter Multigate Switch. This will start the DC from the opening of any gate. Automatic blast gates are out of my price range.
View WoodNDust's profile
WoodNDust
228 posts in 2340 days
#10 posted 05-16-2014 08:32 PM
From what I see in the pictures, you have a very clean install. Do you have more pictures of the ductwork and machine connections?
English
#11 posted 05-16-2014 10:00 PM
WoodNDust, More pictures can be viewed here: https://englishwoodworking.shutterfly.com/pictures/9
View Bobsboxes's profile
Bobsboxes
1369 posts in 2898 days
#12 posted 05-18-2014 04:26 AM
John, great idea on filter clean-outs. I enjoyed your approach on noise control. I have the PSI gate system, for controlling my cyclone. I got my gate switches from Amizon. Check out my projects page to see more. I could also get you the part # of the switches I ordered. I have been using my setup for a couple of years with no problems. Great review.
-- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain
View rum's profile
rum
148 posts in 2820 days
#13 posted 05-20-2014 04:42 AM
John, thanks for the excellent review!
I also like your over the blade table saw collector setup, cleverly done!
View CyberDyneSystems's profile
CyberDyneSystems
288 posts in 2422 days
#14 posted 05-27-2014 07:30 PM
Great review and instructional article.
Your location was akin to putting it in a loudspeaker. The closer a source of sound is located to corners of a room, the louder it becomes. Particularly in the lower frequencies. That said, it is understandable that the corner will be a convenient location.
We have a very loud system in my work shop. After several years of putting up with it, I simply framed up a box around it, sheeted with gypsum and some old homosote sheets we had. With penetrations only where the pipes go in, it is VERY quiet now.
-- Without the wood, it's just working
View scottfl's profile
scottfl
11 posts in 928 days
#15 posted 07-02-2016 03:17 AM
Penn state has discontinued their cyclone dust collectors!
