Amazing improvement on my table saw
Review by jakep_82 posted 05-02-2014 09:02 PM 5949 views 2 times favorited 20 comments Add to Favorites Watch
Amazing improvement on my table saw No-picture-s No-picture-s Click the pictures to enlarge them
I’ve already replaced the belts on most of my machines with link belts, but I never really felt like it was a huge improvement. After swapping the belts on my table saw I realize just how much difference they can make.
I have a 15 year old Grizzly G1023 which has a triple 3L belt pulley. I bought the saw for a song on Craigslist because it had a blown motor, but I had no idea how it ran. After I got the motor fixed I found out it had a significant thump at startup, as well as some noticeable vibration. My new Tenryu combo blade left noticeable saw marks on every cut. After making the swap the startup thump is completely gone, and that same blade now produces glass smooth cuts. I couldn’t be happier.
One other note about where I bought this belt. I ordered from Ozark Woodworker and they shipped the same day. I had the belt in my hands within 3 days of ordering, and the shipping was free. Excellent customer service.
If you have a cabinet saw with a little vibration I would strongly recommend trying this belt.
http://www.ozarkwoodworker.com/38x-1ft-Link-V-Belt-Type-3L-BDH-DuroDrive-Replacement-Belts_p_917.html
View jakep_82's profile
jakep_82
105 posts in 2547 days
20 comments so far
View mantwi's profile
mantwi
312 posts in 2137 days
#1 posted 05-03-2014 01:11 AM
Thanks for the heads up on this source. I too have an older G1023 and after new bearings and motor were installed thought I’d switch to a link belt just to see if it really made a difference. Woodcraft had 1/2” belts and they are too wide. Fortunately my saw does cut smoothly as is but being the obsessive compulsive type I really want a link belt on it. Now I can sleep again.
View Woodknack's profile
Woodknack
12469 posts in 2621 days
#2 posted 05-03-2014 05:39 AM
Yep, they work well. My saw was fairly smooth (or so I thought) but always had a slight shudder as the blade stopped. Switched to a link belt and holy moly did it make a difference.
HillbillyShooter
5811 posts in 2533 days
#3 posted 05-03-2014 01:40 PM
Thanks for your review and the source. I have link belts on just about all my machines except the triple belts on my TS and planer. I’ll check this out.
View ras61's profile
ras61
92 posts in 1762 days
#4 posted 05-03-2014 05:59 PM
Are these Duro Drive belts better than other link belts?
-- "South Carolina is too small for a republic and too large for an insane asylum" - James L. Petigru, 1860
View patcollins's profile
patcollins
1687 posts in 3106 days
#5 posted 05-03-2014 08:44 PM
Thinking that may be the same belt that Harbor Freight sales
View oldnovice's profile
oldnovice
7380 posts in 3609 days
#6 posted 05-03-2014 09:42 PM
I added that, and turned pulleys, to my Craftsman TS over 25 years ago and I still marvel at the improvement it made.
Many years ago, as part of job, I worked with the USPS to add vibration sensing and FFT software to some of the machines as vibrations, of any kind, and those that change are indications of potential problems.
Sort of goes opposite of the old song ”Good Vibrations”.
View Dusty56's profile
Dusty56
11830 posts in 3929 days
#7 posted 05-04-2014 02:18 AM
Any real life photos of your belt ?
$8 /foot with 3 foot minimum order should be mentioned in your “review”.
http://www.harborfreight.com/vibration-free-link-belt-43771.html
5’ for $25 if you need 1/2” wide belt : )
I’ve had excellent results with the Accu-Link brand from HF
jakep_82
#8 posted 05-04-2014 02:27 AM
I have the Harbor Freight belt on my jointer and it works well. I can’t say that it made a huge improvement because it already ran pretty smooth, but it does seem to work well.
I looked around for quite a while to find the best price on 3/8” link belt and Ozark seems to be the lowest. I’m glad I ordered from them and I won’t hesitate to buy other stuff from them.
View b2rtch's profile
b2rtch
4868 posts in 3289 days
#9 posted 05-06-2014 07:52 PM
I have the HF version on all my equipment including my Unisaw (someone on LJ told me that I could not install these belts on a Unisaw)
-- Bert
View TobiasZA's profile
TobiasZA
154 posts in 1780 days
#10 posted 05-06-2014 08:04 PM
I have these belts on my drill press, jointer and table saw. They have been on for about fifteen years now and are still running beautifully. If I remember correctly, I bought them from Lee Valley. They are definitely worth every cent.
Cheers
Tobias
View LJackson's profile
LJackson
295 posts in 1835 days
#11 posted 05-06-2014 09:47 PM
Mostly off topic, but how did you get the motor fixed? I blew the motor on my drill press and was just looking at purchasing a new one, figuring it couldn’t be repaired. It is expensive to replace.
jakep_82
#12 posted 05-06-2014 10:20 PM
My answer probably won’t help you. I happen to have a good friend that works at an electric motor repair shop. He owed me a favor and I cashed it in on my saw. It needed a new primary winding which likely would have cost more than a new motor, but he covered the materials and the entire repair was free for me. If the motor just has a blown capacitor it’s easy and inexpensive to fix. If anything is wrong with the windings you’re better off getting scrap value for the copper and buying a new motor.
LJackson
#13 posted 05-08-2014 05:05 PM
I likely overheated the motor, and it probably needs new windings. I figured that my only solution was a new motor. I didn’t hear a cap snap, nor smell the tell-tail odour.
jakep_82
#14 posted 05-08-2014 05:18 PM
I wish I had a better answer. Unfortunately rewinding motors is almost an art form, and it’s very time consuming. My friend had actually never worked on a motor as small as my puny 3HP. Most of what he works on are 20HP up to 1000+HP. On motors that big it’s much easier to justify the cost of the repair versus buying new.
LJackson
#15 posted 05-08-2014 06:40 PM
No worries. I’m glad for the information you’ve provided. It’s a learning experience, as I’ve never burnt a motor before. When it happened, I knew pretty quickly what I’d done, and just a little research confirmed my suspicion.
Now I’m looking to get a 1HP motor to replace the 1/2HP one I killed. I figure that would reduce my chance of killing it again. Do you have any hints on where to find such a motor? It seems to be hard to find a motor of that power that runs on 110VAC and a standard 15 or 20 amp circuit. Also, it needs to be…1725 rpm I think. It would be a big bonus if the shaft diameter was identical to the one that I’ve currently got, but I’m not going to go so far. I can probably obtain an adapter.
